This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Create and assign a configuration pipeline in Fleet Management
Grafana Fleet Management is a Grafana Cloud feature that helps you configure and manage collector instances at scale. After you onboard your collectors to the service, you can use the Fleet Management interface to configure them remotely.
- Use a Grafana Cloud integration to create a configuration pipeline
Learn how to use Grafana Cloud integrations to create configuration pipelines in Grafana Fleet Management - Create a custom Alloy configuration pipeline
Learn how to create a custom Grafana Alloy configuration pipeline in Grafana Fleet Management - Create a custom OpenTelemetry Collector configuration pipeline
Learn how to create a custom OpenTelemetry Collector configuration pipeline in Grafana Fleet Management - Self-monitoring pipelines
Learn how the self-monitoring pipelines work in Grafana Fleet Management - Configuration deployment strategies
Learn best practices for managing your configuration pipelines in Grafana Fleet Management - Pipeline attribute injection
Learn how to inject variable collector attributes into pipelines in Grafana Fleet Management - Pipeline export injection
Learn how to inject pipeline exports into pipelines in Grafana Fleet Management
Was this page helpful?
