title: "Create and assign a configuration pipeline in Fleet Management | Grafana Cloud documentation"
description: "Learn how to create and assign configuration pipelines in Grafana Fleet Management"
# Create and assign a configuration pipeline in Fleet Management
Grafana Fleet Management is a Grafana Cloud feature that helps you configure and manage collector instances at scale. After you [onboard your collectors](/docs/grafana-cloud/send-data/fleet-management/set-up/onboard-collectors/) to the service, you can use the Fleet Management interface to configure them remotely.
- [Use a Grafana Cloud integration to create a configuration pipeline](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/integrations/)
  Learn how to use Grafana Cloud integrations to create configuration pipelines in Grafana Fleet Management
- [Create a custom Alloy configuration pipeline](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/create-custom-alloy-pipeline/)
  Learn how to create a custom Grafana Alloy configuration pipeline in Grafana Fleet Management
- [Create a custom OpenTelemetry Collector configuration pipeline](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/create-custom-otel-pipeline/)
  Learn how to create a custom OpenTelemetry Collector configuration pipeline in Grafana Fleet Management
- [Self-monitoring pipelines](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/self-monitoring-pipelines/)
  Learn how the self-monitoring pipelines work in Grafana Fleet Management
- [Configuration deployment strategies](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/config-deployment-strategies/)
  Learn best practices for managing your configuration pipelines in Grafana Fleet Management
- [Pipeline attribute injection](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/pipeline-attribute-injection/)
  Learn how to inject variable collector attributes into pipelines in Grafana Fleet Management
- [Pipeline export injection](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/configuration-pipelines/pipeline-export-injection/)
  Learn how to inject pipeline exports into pipelines in Grafana Fleet Management
