title: "Release notes for Fleet Management | Grafana Cloud documentation"
description: "Release notes for the Grafana Fleet Management APIs and application"
# Release notes for Fleet Management
> Warning
> This page is no longer maintained and will be retired on September 30, 2026. Refer to [What’s New](/whats-new/?tags=Fleet%20Management) to learn about updates to Grafana Fleet Management.
Grafana Fleet Management release notes include important changes to the Fleet Management APIs and application. Notes are kept for a rolling six-month window, except for deprecations and breaking changes, which are kept for longer. The changes are categorized by the following types:
- **Features** create a brand new feature.
- **Enhancements** update an existing feature.
- **Fixes** correct a bug or unintended behavior.
- **Breaking changes** require changes to existing customer integrations to prevent unexpected behavior.
- **Deprecations** mark a feature or functionality as obsolete and planned for future removal.
## May 4, 2026
Expand table
| Type        | Description        |
| Feature     | Add the Alloy component editor for building custom configuration pipelines from a searchable catalog of schema-backed components, with form-based fields, reference dropdowns, and validation.        |
| Feature     | Support `collector_id` sent as Loki structured metadata for self-monitoring logs to avoid stream cardinality issues.        |
| Enhancement | Flatten the Grafana Cloud navigation menu to make Fleet Management more findable. The application is now only one level deep: **Connections** &gt; **Fleet Management**.        |
| Enhancement | Make Instrumentation Hub pipelines read-only.        |
| Fix         | Prevent Grafana Cloud global keyboard shortcuts from triggering inside configuration editors. Before the fix, typing letters in the editor that form keyboard shortcuts (such as `ge`) performed the shortcut action, sometimes taking users out of the Fleet Management code editor. |
| Fix         | Update backend source descriptors so Grafana-sourced pipelines can be edited, activated, or deactivated.        |
| Fix         | Preserve the pipeline source when a pipeline is edited. Before the fix, the source type disappeared from the application after a pipeline was edited.        |
## April 20, 2026
Expand table
| Enhancement | Improve readability of the **Logs** tab by displaying timestamps on log entries, adding a case-insensitive search box for filtering logs, and enabling word wrap, JSON formatting, and expandable log details. Timestamps are also now shown on remote configuration error logs in the Health tab. |
| Enhancement | Add a Configuration tab, Edit and Duplicate quick actions, a status badge, and a View history link to the pipeline details drawer on the Remote configuration tab.        |
| Enhancement | Improve configuration code editor to fill available space and keep action buttons always visible.        |
| Enhancement | Allow opening of the pipeline editor in a new tab from the **Remote configuration** list and details drawer by making the edit/view action a real link that supports right-click, middle-click, and Ctrl/Cmd-click.        |
| Fix         | Set pipeline history code editors to read-only mode.        |
| Fix         | Improve load performance by removing matched collector count from **Remote configuration** tab.        |
| Fix         | Return a clear `400 BAD REQUEST` validation error with message `id is not a valid integer` when calling the `DeletePipeline` API with a non-numeric `id`. Previously, such requests produced inconsistent errors.        |
| Fix         | Preselect the Grafana Cloud Prometheus and Loki data sources (or the user’s saved choice) in the collector details **Health** and **Logs** tabs, so queries no longer fall back to an unrelated data source and fail.        |
| Fix         | Fix blank configuration editors in the pipeline details drawer and **Edit configuration** page so content renders correctly.        |
## April 10, 2026
Expand table
| Feature     | Add pipeline details drawer with a **Matched collectors** tab for quick access from the list of configuration pipelines. Clicking on a pipeline opens the details view.                                            |
| Feature     | Display the number of collectors matched to all pipelines on the **Remote configuration** tab        |
| Enhancement | Add operating system selection grid to the Alloy installation workflow.        |
| Enhancement | Add detection for stale rollout of effective configuration. After two minutes of unresolved `pending` state, the **Configuration** tab in the details view displays a warning that the collector might be offline. |
| Fix         | Include `collector_id` label in the URL filter for the **Explore logs** button in the collector details view. Before the fix, the filter was empty, forcing users to manually set labels.                          |
## March 24, 2026
Expand table
| Feature     | Display a collector’s effective configuration on the **Configuration** tab of its details view. If the effective and server configurations differ, show both, along with a status message.                            |
| Feature     | Add a remote configuration dashboard to the **Health** tab in the collector details view. The dashboard reports the latest configuration load status, the load status over time, and any remote configuration errors. |
| Enhancement | Improve bulk collector updates and deletions for large fleets by chunking and queuing API calls from the UI.        |
| Enhancement | Add a reset filters option to the remote configuration page.        |
| Fix         | Fix a bug in the collector status filter so the chevron opens the dropdown menu and all selected statuses render as pills.        |
| Fix         | Filter reserved attributes by collector type in matching attribute dropdown.        |
| Fix         | Enable adding and editing of attributes in the collector detail view **Attributes** tab.        |
## March 2, 2026
Expand table
| Feature         | Enable users to add new Alloy collectors directly from the **Inventory** tab with an **Add collector** button.        |
| Fix             | Fix an issue where adding a custom attribute in the UI caused the collector to stop receiving any pipelines, not only in the UI but also in the `remotecfg` service itself.        |
| Fix             | Restore **Last connection** timestamp in the **Inventory** tab for collectors that unregister from Fleet Management and are marked inactive.        |
| Fix             | Fix an issue where saving collector details could remove existing local attributes.        |
| Fix             | Allow remote attributes to be added or removed from the collector detail view.        |
| Breaking change | Change the behavior of the `UpdateCollector` endpoint so requests that omit the `enabled` field default to the existing state of the collector. Prior to the change, requests to `UpdateCollector` that omitted the `enabled` field defaulted to `enabled = false` and the collector couldn’t be remotely configured. |
## February 13, 2026
Expand table
| Feature     | Enable filtering of the **Inventory** tab by collector type.        |
| Feature     | Add a button to the **Health** tab in the collector details drawer that directs to Alloy Health dashboards. The button appears only if the Alloy Health integration is installed. |
| Feature     | Add a duplicate button to the **Remote configuration** tab.        |
| Feature     | Enable bulk deleting of configuration pipelines from the **Remote configuration** tab.        |
| Enhancement | Add the BulkDeletePipelines endpoint to the Pipeline API. This endpoint deletes multiple pipelines by ID in a single, atomic operation.                                           |
| Enhancement | Improve select-all functionality with pagination for collectors and configuration pipelines.        |
| Fix         | Report the correct number of collectors shown when the **Inventory** list is filtered.        |
| Fix         | Allow users with `read` access to click on collectors to view details such as health status, logs, and configuration.                                                             |
## January 27, 2026
Expand table
| Feature     | Create the **Overview** tab with a dashboard for collector and pipeline statistics, including counts, limits, errors, and collector distribution across type, version, and operating system. |
| Enhancement | Add the `GetSummary` endpoint to the Tenant API. This endpoint provides aggregate statistics for collectors and pipelines in a stack.                                                        |
| Enhancement | Hide by default collectors that are inactive for three hours or more on the **Assign matching attributes** screen in the configuration pipeline workflow.                                    |
| Fix         | Restore `collector.` prefix to display name of reserved attributes.        |
| Fix         | Update UTF-8 character encoding to allow pipeline syntax validation to pass when those characters are included.        |
## December 15, 2025
Expand table
| Feature     | Beginning with Alloy v1.12.0, visually link configuration pipeline errors to the collectors running the faulty pipelines. Collectors with pipeline errors have a red health status. Pipeline errors are listed in the collector details view. |
| Feature     | Integrate Grafana Assistant in the configuration pipeline workflow with pre-configured prompts for explaining, validating, fixing, optimizing, or visualizing pipelines.        |
| Enhancement | Add `Collector App Reader` plugin role for fine-grained role-based access control (RBAC). The role grants designated users read-only access to Fleet Management resources.        |
## November 20, 2025
Expand table
| Feature         | Add support for private connectivity options: AWS PrivateLink, Azure Private Link, and GCP Private Service Connect.        |
| Feature         | Create new Tenant API, which currently consists of a single endpoint, `GetLimits`. Calls to this endpoint return all applicable collector, pipeline, and API limits for the stack. |
| Breaking change | Change the behavior of the `UnregisterCollector` endpoint to mark collectors inactive rather than deleting them.        |
## November 5, 2025
Expand table
| Feature | Add Source column to remote configuration tab to identify the origin of externally sourced pipelines. Column only appears if externally sourced pipelines are present. |
| Feature | Publish a GitHub Action to allow users to automatically sync configuration pipelines with Fleet Management using a CI/CD workflow.                                     |
## October 31, 2025
Expand table
| Deprecation | Deprecate `attributes` and `attribute_overrides` fields in the Collector API in favor of `local_attributes` and `remote_attributes` fields respectively. Users should update any integrations to use `local_attributes` and `remote_attributes` instead. |
