Admin settings for Grafana IRM
The Admin & API tab in Grafana IRM settings provides organization-wide configuration options that affect how users and teams interact with IRM.
To access these settings, go to Alerts & IRM > IRM > Settings > Admin & API.
Access IRM API endpoints
The Admin & API tab displays the base URLs for the IRM APIs. These values are specific to your Grafana Cloud stack and are configured automatically during plugin provisioning.
Use these endpoints for programmatic access or when setting up infrastructure as code.
For more detail about using the IRM APIs, refer to the API reference.
Notification channel visibility
Control which notification channels are available to users in their personal notification rules.
Use the toggles to show or hide specific notification channels, such as Slack or Microsoft Teams.
When an integration is installed, the toggle is enabled by default, allowing users to select the channel in their personal notification rules.
If a notification channel is disabled:
- The channel no longer appears in a user’s IRM profile.
- The associated configuration tab is hidden from the IRM profile UI.
Note
These toggles only control visibility for users. They don’t enable or disable the integration itself. To manage integrations, go to IRM > Integrations > Apps. For more detail, refer to IRM integrations.
Manage direct paging integrations
Control how direct paging integrations are created and managed in your organization.
By default, IRM automatically creates and manages a direct paging integration for each team. These integrations allow teams to be paged directly through the UI, messaging apps, or API.
When Manually manage direct paging integrations is enabled:
- IRM stops automatically creating direct paging integrations for new teams.
- Existing direct paging integrations remain unchanged and can be managed manually.
- You can create and delete direct paging integrations through the API or infrastructure as code tools like Terraform.
- IRM still deletes a team’s direct paging integration when the team is deleted.
Note
Enabling this setting doesn’t delete existing direct paging integrations. You can import existing integrations into your IaC tooling or delete and recreate them manually.
This setting is useful for teams that manage their direct paging integrations through infrastructure as code.
Disable QR code login for the mobile app
Control how users pair the Grafana mobile app with their Grafana Cloud account.
When Disable QR code login for the mobile app is enabled:
- Users can’t pair a device by scanning a QR code from Profile > Mobile app in Grafana Cloud.
- On mobile web, the Connect Mobile App deeplink isn’t offered for pairing.
- IRM doesn’t issue mobile pairing verification codes for your organization.
- Users must open the Grafana mobile app, enter their stack URL, and sign in through your organization’s web SSO flow.
When disabled, users can connect by scanning the QR code shown in their profile. For end-user steps, refer to Download the mobile app.
Note
This setting only blocks QR code and deeplink pairing. Users who are already connected keep receiving push notifications, and admins can still disconnect devices from IRM > Users.
To change this setting, you need the Settings Editor RBAC role (grafana-irm-app.other-settings:write).
In the OnCall plugin API, the field is disable_mobile_app_qr_code_login on the current organization resource.
Acknowledge reminders and auto-unacknowledge
To configure how long IRM waits before reminding an acknowledger, and whether to automatically revert an acknowledged alert group to unacknowledged if there is no response, go to Alerts & IRM > IRM > Integrations > Apps > Slack, then scroll to the Alert Groups section.
These settings (Acknowledge remind timeout and Unacknowledge timeout) are part of the Slack integration configuration and are only available when the Slack integration is installed on your stack.
Require resolution notes
Enforce documentation requirements when resolving alert groups.
When enabled, responders must provide a resolution note before resolving an alert group. This helps teams maintain a consistent response process and improve post-incident visibility.
This requirement also applies in Slack — if an alert group is resolved, you can’t use the 🤖 (:robot_face:)
reaction to remove the last remaining resolution note. For more information about Slack reactions, refer to the IRM Slack documentation.
Note
This requirement is enforced in the IRM UI, Slack, and bulk resolve operations. The OnCall public API resolve endpoint doesn’t enforce this requirement. If your team resolves alert groups through the API, consider adding resolution notes programmatically.
Require team membership for updates
Restrict resource updates to users who are members of the resource’s team.
This setting applies to the following resource types:
- Alert groups (acknowledge, resolve, silence, and other state changes)
- Integrations
- Escalation chains and policies
- On-call schedules and shifts
- Shift swaps
- Routes
- Outgoing webhooks
- Resolution notes
- Labels
When enabled:
- Users must be a member of a team to create or update resources owned by that team.
- For alert groups, this includes acknowledging, resolving, silencing, and other state changes.
- The restriction applies across all surfaces: the IRM UI, mobile app, Slack, Microsoft Teams, and the public API.
- Resource write permissions are still required in addition to team membership.
The following users bypass this restriction:
- Users with the Admin basic role or IRM Admin RBAC role.
- Service accounts.
- Users who were notified for the specific alert group (refer to the following section for details).
When disabled, any user with appropriate write permissions can update resources regardless of team membership.
Note
This setting only restricts write operations. All users with read access can still view resources from any team, subject to team visibility settings.
Cross-team escalation bypass for alert groups
When an escalation chain routes an alert group to a user from a different team — for example, a management schedule from another team — that user is automatically granted permission to act on the alert group, even if they are not a member of the integration’s team.
This bypass applies only when:
- The user received a notification for the specific alert group (via an escalation chain step or direct paging).
- The user is performing an action on that same alert group.
This ensures that intentional cross-team escalations remain actionable by the intended responders, consistent with how PagerDuty handles assigned contacts.
Note
The bypass is scoped to the individual alert group the user was notified for. It does not grant broader access to the team’s other resources (integrations, schedules, escalation chains, and so on).
For more detail on how teams work in IRM, refer to Teams.
Disable schedule updates in the past
Prevent modifications to on-call schedules for past events and enforce future-only scheduling.
When enabled:
- Users can’t create overrides or shift swaps with start times in the past.
- Users can’t delete overrides or shift swaps that are already in progress or in the past.
- When deleting a rotation, users can’t delete past shifts.
- When editing a rotation, users can only use the Save as new option.
- All new schedule entries must have a start date/time set to Now or a future date/time.
This setting only applies to web-based schedules.
For Terraform or API-based schedules, use the until parameter to end a rotation and create a new one.
Manage linked Slack profiles
Admins can view and manage linked Slack profiles on behalf of users in their organization. In the IRM Users list, any profile associated with a user is shown in the Linked profiles column.
Profiles can be automatically synced if the user’s email in Grafana matches the email used in Slack.
Sync all Slack profiles
To sync all linked profiles for IRM users:
- In your Grafana Cloud stack, go to Alerts & IRM > IRM > Users.
- In the Linked profiles column, click the Sync user profiles icon.
Any users with matching Slack profiles are synced and displayed in this column.
Unlink a Slack profile
To manually unlink a Slack profile for an individual user:
- Next to any user with a linked profile, click the options menu (three dots).
- Select Unlink Slack to remove the linked profile from this user on the current stack.
