This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/manage-swaps.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/manage-swaps/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Manage shift swaps
Shift swaps allow on-call users to request coverage when they’re unavailable. Other team members can volunteer to take over these shifts, providing flexibility in on-call scheduling.
Learn how to manage shift swaps from the Grafana mobile app
Before you begin
To manage shift swaps, you need:
- Correct permissions in Grafana IRM (
SCHEDULES_WRITEpermission if RBAC is enabled) - A schedule where you want to request or take a shift swap
How shift swaps work
When you create a shift swap request:
- The request becomes visible to all users with access to the schedule
- Team members can volunteer to take the shift
- Once accepted, the replacement user receives all notifications during the swap period for the shifts originally assigned to the requester
- The original schedule remains unchanged for future rotations
Request a shift swap
You can request shift swaps from the web UI or the Grafana mobile app.
Request from the web UI
- Navigate to IRM > Schedules
- Select the schedule where you want to request a shift swap
- Click Add > Shift Swap Request
- Set the Swap Start date and time (past dates are not allowed)
- Set the Swap End date and time
- (Optional) Add a description to provide context for your request
- Click Create
The shift swap request appears immediately in the schedule view and notifications are sent to your team.
Request from the mobile app
- Open the Grafana mobile app
- Navigate to the Schedules tab
- Tap the + button and select Shift Swap Request
- Set the start and end times for the swap
- Tap Create
Take a shift swap
When you take a shift swap, you assume the requester’s on-call duties for the specified time period.
- Select the schedule containing open shift swap requests
- Locate an open shift swap request in the Shift Swaps section or in the schedule timeline
- Review the shift details, including the time period and any description provided
- Click Take Swap to accept the request
- Confirm your decision when prompted
Once you take a shift swap, you’ll receive all notifications and alerts during the swap period that would have gone to the original on-call user.
Cancel a shift swap
You can cancel your own shift swap requests at any time:
- Select the schedule containing your shift swap request
- In the Shift Swaps section, find your request
- Click the Delete (trash) icon next to the request
- Confirm the deletion when prompted
If someone has already taken your shift swap, removing the request reverts the swap and returns on-call responsibility to you. If the swap has already started, only the remaining period will be reverted.
View existing swap requests
To review existing swap requests:
- Select the schedule you want to view
- Look for events marked with the swap request icon in the schedule timeline
- Alternatively, scroll to the Shift Swaps section to see a list of all swap requests
Notifications and reminders
Grafana IRM sends notifications to ensure users are informed about shift swaps:
- Push notifications are sent to users with schedule alerts enabled
- Slack notifications (if configured) inform teams of open requests
Reminder schedule
Shift swap reminders are sent at the following intervals before the swap start time:
- 4 weeks
- 3 weeks
- 2 weeks
- 1 week
- 3 days
- 2 days
- 1 day
- 12 hours
Notifications are sent during working hours (9 AM – 5 PM local time) based on the user’s mobile device timezone.
Automate shift swaps
To enable auto-generated shift swap requests based on calendar events:
- Navigate to IRM > Schedules > Settings
- Under Calendar Integration, enable calendar integration
- Follow the prompts to authenticate and connect your calendar
- Configure which calendar events should trigger shift swap requests
For detailed instructions on setting up automated shift swaps, refer to Automate shift swaps.
Troubleshooting shift swaps
Unable to take a shift swap
If you can’t take a shift swap:
- Verify that you have
SCHEDULES_WRITEpermission - Check that the shift swap hasn’t already been taken by someone else
- Confirm that you’re not already scheduled for that time period
Missing notifications
If notifications for shift swaps aren’t being received:
- Verify that push notifications are enabled in user settings
- Check Slack channel configuration if using the integration for Slack
- Check that notification services are properly configured in Grafana IRM
Related topics
Was this page helpful?
