title: "Manage shift swaps | Grafana Cloud documentation"
description: "Learn how to request, accept, and manage shift swaps in Grafana IRM on-call schedules"
# Manage shift swaps
Shift swaps allow on-call users to request coverage when they’re unavailable. Other team members can volunteer to take over these shifts, providing flexibility in on-call scheduling.
[Learn how to manage shift swaps from the Grafana mobile app](/docs/grafana-cloud/alerting-and-irm/irm/mobile-app/)
## Before you begin
To manage shift swaps, you need:
- Correct permissions in Grafana IRM (`SCHEDULES_WRITE` permission if RBAC is enabled)
- A schedule where you want to request or take a shift swap
## How shift swaps work
When you create a shift swap request:
- The request becomes visible to all users with access to the schedule
- Team members can volunteer to take the shift
- Once accepted, the replacement user receives all notifications during the swap period for the shifts originally assigned to the requester
- The original schedule remains unchanged for future rotations
## Request a shift swap
You can request shift swaps from the web UI or the Grafana mobile app.
### Request from the web UI
1. Navigate to **IRM** &gt; **Schedules**
2. Select the schedule where you want to request a shift swap
3. Click **Add** &gt; **Shift Swap Request**
4. Set the **Swap Start** date and time (past dates are not allowed)
5. Set the **Swap End** date and time
6. (Optional) Add a description to provide context for your request
7. Click **Create**
The shift swap request appears immediately in the schedule view and notifications are sent to your team.
### Request from the mobile app
1. Open the Grafana mobile app
2. Navigate to the **Schedules** tab
3. Select the schedule where you want to request a shift swap
4. Tap the **+** button and select **Shift Swap Request**
5. Set the start and end times for the swap
7. Tap **Create**
## Take a shift swap
When you take a shift swap, you assume the requester’s on-call duties for the specified time period.
2. Select the schedule containing open shift swap requests
3. Locate an open shift swap request in the **Shift Swaps** section or in the schedule timeline
4. Review the shift details, including the time period and any description provided
5. Click **Take Swap** to accept the request
6. Confirm your decision when prompted
Once you take a shift swap, you’ll receive all notifications and alerts during the swap period that would have gone to the original on-call user.
## Cancel a shift swap
You can cancel your own shift swap requests at any time:
2. Select the schedule containing your shift swap request
3. In the **Shift Swaps** section, find your request
4. Click the **Delete** (trash) icon next to the request
5. Confirm the deletion when prompted
If someone has already taken your shift swap, removing the request reverts the swap and returns on-call responsibility to you. If the swap has already started, only the remaining period will be reverted.
## View existing swap requests
To review existing swap requests:
2. Select the schedule you want to view
3. Look for events marked with the swap request icon in the schedule timeline
4. Alternatively, scroll to the **Shift Swaps** section to see a list of all swap requests
## Notifications and reminders
Grafana IRM sends notifications to ensure users are informed about shift swaps:
- Push notifications are sent to users with schedule alerts enabled
- Slack notifications (if configured) inform teams of open requests
### Reminder schedule
Shift swap reminders are sent at the following intervals before the swap start time:
- 4 weeks
- 3 weeks
- 2 weeks
- 1 week
- 3 days
- 2 days
- 1 day
- 12 hours
Notifications are sent during working hours (9 AM – 5 PM local time) based on the user’s mobile device timezone.
## Automate shift swaps
To enable auto-generated shift swap requests based on calendar events:
1. Navigate to **IRM** &gt; **Schedules** &gt; **Settings**
2. Under **Calendar Integration**, enable calendar integration
3. Follow the prompts to authenticate and connect your calendar
4. Configure which calendar events should trigger shift swap requests
For detailed instructions on setting up automated shift swaps, refer to [Automate shift swaps](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/automate-swaps).
## Troubleshooting shift swaps
### Unable to take a shift swap
If you can’t take a shift swap:
- Verify that you have `SCHEDULES_WRITE` permission
- Check that the shift swap hasn’t already been taken by someone else
- Confirm that you’re not already scheduled for that time period
### Missing notifications
If notifications for shift swaps aren’t being received:
- Verify that push notifications are enabled in user settings
- Check Slack channel configuration if using the integration for Slack
- Check that notification services are properly configured in Grafana IRM
## Related topics
- [Shift swaps and overrides overview](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides)
- [Add overrides](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/add-overrides)
- [Automate shift swaps](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/automate-swaps)
