title: "Shift swaps and overrides | Grafana Cloud documentation"
description: "Learn how to swap shifts and manage overrides in Grafana IRM"
# Shift swaps and overrides
Grafana IRM provides flexibility for on-call schedules through shift swaps and overrides. These features allow you to make temporary adjustments to schedules without modifying the underlying rotation pattern.
## About shift swaps and overrides
When managing on-call rotations, teams often need to accommodate schedule changes due to vacations, sick leave, or other personal conflicts. Grafana IRM offers two features to handle these situations:
- **Shift swaps**: Enable team members to request coverage for their shifts and allow others to volunteer to take those shifts
- **Overrides**: Let you specify a temporary replacement user for specific time periods
Both features help teams maintain coverage during absences without disrupting the primary schedule configuration.
## Which feature should I use?
Choose the appropriate feature based on your situation:
Expand table
| Feature         | Best used when                                       | Process                                                    |
| **Shift swaps** | You need coverage but don’t know who’s available     | Create a request that team members can volunteer to accept |
| **Overrides**   | You’ve already coordinated with a specific colleague | Directly assign the replacement to cover your shift        |
### Restrictions
A shift swap is possible for any kind of schedule. Web overrides are possible for web schedules and Terraform schedules for which `enable_web_overrides` is enabled (this setting is disabled by default). Web overrides are not possible for iCal imported schedules.
## Shift swaps
Shift swaps allow on-call users to request coverage for their shifts when they are unavailable. This collaborative approach distributes the workload fairly across the team.
### Key features
- **Request-based system**: Create requests for shift coverage that team members can volunteer to take
- **Notifications and reminders**: Automated alerts to inform team members about open requests
- **Mobile app support**: Manage shift swaps on the go through the Grafana mobile app
- **Calendar integration**: Automate shift swap requests with calendar integration
### Shift swap workflow
1. Team member creates a shift swap request for a specific time period
2. Notification is sent to eligible team members
3. Another team member takes the swap request
4. Schedule is updated automatically (replacing every occurrence of the requester with the taker in the specified time-window)
5. Both team members receive confirmation notifications
For detailed instructions on creating, accepting, and managing shift swaps, refer to [Manage shift swaps](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/manage-swaps).
For information on automating shift swaps with calendar integration, refer to [Automate shift swaps](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/automate-swaps).
## Overrides
Overrides directly assign a replacement user for a defined time period. This feature gives you precise control over schedule adjustments when you’ve already coordinated coverage with a specific colleague.
### Key features
- **Direct replacement**: Explicitly assign a specific user to cover any shifts that occur during the override
- **Temporary changes**: Make one-time adjustments without altering the underlying schedule
- **Date and time precision**: Set exact start and end times for the override period
- **Override calendar**: Use a calendar app to manage override schedules in your existing systems
### Override workflow
1. Team member identifies when they need coverage
2. They coordinate with another team member to cover the shift
3. Admin or team member creates an override specifying:
   - The time period for the override
   - The user who will provide coverage
4. Schedule is automatically updated to reflect the override
For step-by-step instructions on creating and managing overrides, refer to [Add overrides](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/shift-swaps-overrides/add-overrides).
## Role-based access control (RBAC)
If RBAC is enabled in your Grafana IRM instance, users need the following permissions to work with shift swaps and overrides:
- **SCHEDULES\_WRITE**: To create, update, take, or delete shift swaps and overrides
- **SCHEDULES\_READ**: To view shift swap requests and overrides
For more information about RBAC in Grafana IRM, refer to [Manage access](/docs/grafana-cloud/observe-and-act/respond-to-incidents/set-up/manage-access).
