title: "Schedules as code | Grafana Cloud documentation"
description: "Manage on-call schedules with Terraform and API"
# Schedules as code
This topic explains how to manage on-call schedules in Grafana Incident Response Management (IRM) using Infrastructure as Code (IaC).
## Why use Infrastructure as Code for schedules?
Instead of manually creating and updating on-call schedules through the UI, you can define them as code for better reliability and team collaboration.
- **Automation &amp; efficiency**: Eliminate manual schedule setup and reduce human error.
- **Consistency &amp; standardization**: Standardize rotation patterns across multiple teams.
- **Version Control &amp; collaboration**: Track schedule changes in Git and enable team reviews and approvals for schedule modifications.
- **DevOps integration**: Integrate schedule updates into your existing CI/CD workflows.
- **Scale with confidence**: Manage dozens of teams and replicate successful schedule patterns across your organization.
## Choose your approach
Grafana IRM supports two primary methods for managing schedules as code:
1. **Terraform with the Grafana provider** - Ideal for teams already using Terraform or wanting declarative configuration.
2. **Grafana IRM API directly** - Ideal for custom integrations or dynamic schedule management.
## Manage on-call schedules with Terraform
Terraform allows you to define on-call schedules as code, ensuring reproducibility and version control. Using the Grafana Terraform provider, you can create and manage on-call schedules within Grafana IRM.
### Before you begin
You need:
- A Grafana Cloud account using IRM
- A Grafana [Service Account token](/docs/grafana/latest/administration/service-accounts/#service-account-tokens) or a [Grafana IRM API token](/docs/grafana-cloud/observe-and-act/respond-to-incidents/set-up/admin-settings/#access-irm-api-endpoints) with appropriate permissions
- Terraform installed ([Install Terraform](https://developer.hashicorp.com/terraform/downloads))
- Grafana provider configured ([Terraform Provider Documentation](https://registry.terraform.io/providers/grafana/grafana/latest/docs))
For initial Terraform setup, refer to [Infrastructure as Code](/docs/grafana-cloud/observe-and-act/respond-to-incidents/set-up/infra-as-code).
### Understand on-call schedules and shifts in Terraform
Before creating schedules with Terraform, it’s important to understand the key concepts and components.
- **Schedule**: A container that holds one or more shifts and defines the overall on-call calendar.
- **Shift**: The actual rotation pattern that determines who is on-call and when.
#### Key schedule configuration parameters
When configuring schedules in Terraform, pay attention to these parameters:
- **`name`** : A descriptive name for your schedule (e.g., “Backend Team Primary Rotation”)
- **`type`** : Schedule type - use `"calendar"` to define shifts via Terraform
- **`time_zone`** : The time zone for the schedule (e.g., “UTC”, “America/New\_York”, “Europe/London”)
- **`shifts`** : List of shift IDs that belong to this schedule
- **`team_id`** : Associates the schedule with a specific team for better organization
- **`slack`** : Slack workspace integration settings for notifications
For a detailed list of available resources, refer to the [Grafana oncall schedule terraform Schema](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/oncall_schedule).
#### Key shift configuration parameters
When configuring shifts in Terraform, pay attention to:
- **`name`** : A descriptive name for your shift
- **`start`** : The date and time when the shift pattern begins
- **`duration`** : How long each person/group stays on-call
- **`frequency`** : How often the pattern repeats (`daily`, `weekly`, `monthly`)
- **`by_day`** : Which days of the week the shift applies to
- **`level`** : Indicates the shift priority, useful when overriding shifts
- **`type`** : The type of shift (`rolling_users` or `single_event`)
For a detailed list of available resources, refer to the [Grafana oncall shift terraform Schema](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/oncall_on_call_shift).
#### Shift types
Grafana IRM supports the following shift types:
- **`rolling_users`** : The most common and flexible shift type for creating recurring rotations where users alternate being on-call. Use this for weekly rotations, daily handoffs, or any pattern where the same users rotate in a predictable order.
- **`single_event`** : Creates a one-time shift for a specific date and time. Useful for covering special events, holidays, or temporary coverage.
- **`recurrent_event`** : **Deprecated** - Creates recurring shifts based on specific dates and times. Use `rolling_users` instead for new implementations, as it provides better flexibility and is actively maintained.
##### Rolling users shift patterns
The `rolling_users` shift type offers the most flexibility for on-call rotations:
- **Individual rotations**: Each user takes turns being on-call alone: `[[user1], [user2], [user3]]`
- **Co-primary rotations**: Multiple users share on-call duties simultaneously: `[[user1, user2], [user3, user4]]`
- **Mixed patterns**: Combine individual and group rotations: `[[user1], [user2, user3], [user4]]`
### Example: Creating an on-call schedule with Terraform
The following example shows a basic on-call schedule configuration:
terraform ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```terraform
provider "grafana" {
  alias = "oncall"
  url        = "<Stack-URL>"
  auth       = "<Service-account-token>"
  oncall_url = "<OnCall-URL>"
resource "grafana_oncall_schedule" "example_schedule" {
  provider = grafana.oncall
  name      = "Primary On-Call Schedule"
  type      = "calendar"
  time_zone = "UTC"
### Set up an on-call rotation via Terraform
The following example demonstrates how to set up a weekly rotation where two users alternate on-call duties.
#### Define users
First, reference the users who will participate in the rotation:
```terraform
data "grafana_oncall_user" "user_one" {
  username = "user_one"
data "grafana_oncall_user" "user_two" {
  username = "user_two"
#### Create an on-call shift
Next, define the shift pattern:
```terraform
resource "grafana_oncall_on_call_shift" "week_shift" {
  name       = "Week shift"
  type       = "rolling_users"
  start      = "2025-03-01T00:00:00"
  duration   = 60 * 60 * 24  # 24 hours in seconds
  frequency  = "weekly"
  by_day     = ["MO", "TU", "WE", "TH", "FR", "SA", "SU"]
  week_start = "MO"
  rolling_users = [
    [data.grafana_oncall_user.user_one.id],
    [data.grafana_oncall_user.user_two.id]
  time_zone = "UTC"
> Tip
> To set up an on-call rotation with multiple users on-call together, use the `rolling_users` shift type and provide a list of lists. Each inner list represents a group of users who will be on-call together for that shift occurrence. Example:
> ```terraform
> rolling_users = [
  [user1, user2],  # both on-call together
  [user3]          # solo on-call for next rotation
> Both users in the same list will be notified and added to Slack groups as co-primary responders.
For all available parameters, refer to the [Grafana Terraform provider reference](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/oncall_on_call_shift).
#### Connect the shift to a schedule
Create a schedule and associate it with the shift:
```terraform
resource "grafana_oncall_schedule" "primary" {
  name      = "Primary"
  type      = "calendar"
  time_zone = "UTC"
  shifts    = [
    grafana_oncall_on_call_shift.week_shift.id
#### Add the schedule to an escalation chain
Finally, add the schedule to an escalation chain to use it for incident notifications:
```terraform
resource "grafana_oncall_escalation" "notify_schedule" {
  escalation_chain_id          = grafana_oncall_escalation_chain.default.id
  type                         = "notify_on_call_from_schedule"
  notify_on_call_from_schedule = grafana_oncall_schedule.primary.id
  position                     = 0
After applying your configuration with `terraform apply`, you can view your schedule in Grafana IRM under the **Schedules** tab or export it as an iCal link.
## Manage on-call schedules with the API
The Grafana IRM API provides granular control over on-call schedules, enabling dynamic updates and integrations with other systems.
### API endpoints
The On-Call Schedules API supports the following operations:
- List schedules: `GET /api/v1/schedules/`
- Create a schedule: `POST /api/v1/schedules/`
- Update a schedule: `PUT /api/v1/schedules/{schedule_id}`
- Delete a schedule: `DELETE /api/v1/schedules/{schedule_id}`
For complete API documentation, refer to the [Grafana IRM API Reference: Schedules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/reference/oncall-api/schedules).
### Example: Creating an on-call schedule via API
The following example shows how to create a schedule using a curl command:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
curl -X POST "https://<OnCall-API-URL>/api/v1/schedules/" \
-H "Authorization: Bearer $GRAFANA_API_KEY" \
-H "Content-Type: application/json" \
-d '{
  "name": "Primary On-Call Schedule",
  "team_id": "your-team-id",
  "type": "calendar",
  "time_zone": "UTC"
## Time zone considerations
When working with schedules as code, time zones are a critical consideration:
- Always specify the time zone for each rotation to avoid scheduling confusion
- Use consistent time zone formats across your configuration
- Consider the global distribution of your team when setting up rotations
- Test schedules across time zone boundaries to ensure proper handoffs
- Be aware of daylight saving time transitions when scheduling long-term rotations
## Best practices for schedules as code
Follow these best practices when managing your on-call schedules as code:
- **Use source control**: Store Terraform configurations and API scripts in a Git repository to track changes
- **Automate deployments**: Use CI/CD tools like GitHub Actions or Terraform Cloud for managing schedules across environments
- **Apply role-based access control (RBAC)**: Restrict who can modify schedules via API keys and IAM policies to prevent unauthorized changes
- **Test before applying**: Use `terraform plan` or API dry-runs to validate configurations before deploying to production
- **Document your approach**: Maintain documentation about your schedule structure and rotation patterns
- **Implement monitoring**: Set up alerts for schedule configuration changes or failures
- **Use variables and modules**: Leverage Terraform variables and modules to create reusable schedule patterns
## Additional resources
- [Grafana IRM API Reference: Schedules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/reference/oncall-api/schedules)
- [Terraform Provider for Grafana](https://registry.terraform.io/providers/grafana/grafana/latest/docs)
- [Getting Started with Terraform and Grafana IRM](/blog/get-started-with-grafana-oncall-and-terraform/)
