On-call schedules
Use on-call schedules in Grafana IRM to establish automatic rotation management and alert escalation. With on-call schedules, you can:
  • Ensure consistent coverage for alerts and incidents
  • Distribute on-call responsibilities across your team
  • Define custom rotation patterns that match your team’s needs
  • Manage schedule changes and temporary coverage adjustments
  • Monitor and improve schedule quality
Key concepts
Before creating schedules in Grafana IRM, understand the following key components:
  • Rotations: Recurring patterns that determine when team members are on-call, such as weekly or monthly cycles
  • Shifts: Specific time periods when a team member is responsible for responding to incidents and alerts
  • Schedule layers: Multiple concurrent rotation patterns that define different response priorities (a higher-level layer overrides a lower tier rotation)
  • Time zones: Settings that ensure accurate schedule display and management for distributed teams across regions
  • Overrides: Temporary schedule modifications to accommodate time off, shift swaps, or special coverage needs
Schedule types
Grafana IRM offers three flexible ways to manage on-call schedules:
IRM app managed schedules
Create and manage schedules directly through the Grafana IRM web UI:
  • Design custom rotation patterns that match your team’s needs
  • Configure multiple rotation layers
  • Preview and validate schedule coverage in real-time
  • Handle overrides and time zone adjustments
To learn more, refer to Create on-call schedules.
Calendar import (iCal)
Import schedules from calendar applications like Google Calendar:
  • Manage rotations using familiar calendar tools
  • Import schedules via iCal URLs
  • Automatically sync schedule changes
  • Set up override calendars for temporary coverage adjustments
  • Support priority levels for overlapping shifts
  • View and monitor schedules through the IRM schedule interface
To learn more, refer to Import schedules.
Infrastructure as code
Manage schedules programmatically through Terraform and version control:
  • Define schedules as code
  • Track schedule changes in version control
  • Automate schedule creation and updates
  • Integrate with CI/CD pipelines
  • Ensure consistent schedule configuration
  • Scale schedule management across teams
To learn more, refer to Schedules as code.
Schedule quality
Monitor and improve your schedule effectiveness:
Quality metrics
  • Coverage gaps
  • Distribution balance
  • User workload
  • Schedule predictability
Quality score
The schedule quality score (0-100) helps you assess and improve your schedules:
ScoreRatingDescription
81-100GreatWell-balanced, consistent coverage
61-80GoodMinor improvements possible
41-60MediumSome gaps or imbalances
21-40LowSignificant improvements needed
0-20PoorMajor coverage issues
Note
If the schedule includes users which were deleted or users without the required permissions to be on-call, that will also affect the quality score.
Combine schedules and escalation levels
By defining an escalation chain including several “Notify schedule” steps with a “Wait” step between them, you can organize different levels of on-call responsibility:
Primary level
  • First line of defense for incident response
  • Handles initial incident assessment and resolution
  • Typically staffed by team members most familiar with the system
Secondary level
  • Provides backup support when primary cannot respond
  • Activated if primary doesn’t acknowledge within set timeframe
  • Often includes more experienced team members or specialists
Tertiary level
  • Final escalation point for critical incidents
  • Ensures coverage when primary and secondary are unavailable
  • May include senior team members or management
Benefits of layered schedules
  • Distributes on-call workload across teams
  • Provides clear escalation paths
  • Ensures continuous coverage for critical systems
  • Allows for specialized response teams
Next steps
