Source phone numbers for Grafana IRM notifications
Grafana IRM sends phone calls and SMS notifications from a set of dedicated phone numbers. The numbers depend on your Grafana Cloud plan. For SMS, IRM uses a local number for your country where one is available, which improves deliverability and makes messages easier to recognize. Otherwise, IRM uses one of the international numbers from the following lists. To make sure calls and messages from IRM aren’t blocked, add the numbers for your plan to your contacts. If you use the Grafana mobile app, sync the IRM phone numbers to your contacts to get the numbers for your plan automatically.
In many countries, IRM sends SMS messages using the Grafana IRM alphanumeric sender ID, in addition to or instead of a phone number.
Note
These lists can change over time, so check back here for the latest numbers. In some cases, depending on your country, mobile provider, or roaming status, the number that calls or texts you might differ from those listed. Always test SMS and phone call notifications to your device to confirm you receive them as expected.
On paid plans, IRM uses the following phone numbers:
CountryE.164 formatUsed for
Australia+61468162680Calls and SMS
Australia+61875441310Calls
Finland+358454907754Calls and SMS
Germany+4915888658175Calls and SMS
Philippines+639221200249SMS
Sweden+46721498393SMS
United Kingdom+447888874366Calls and SMS
United States+15595464967Calls and SMS
United States+16505353920Calls and SMS
United States+16572270147Calls and SMS
Free tier
On the Free tier, IRM uses the following phone numbers:
United States+12298602584Calls and SMS
Next steps
