Phone and SMS notifications
Set up phone calls and SMS notifications in Grafana IRM to receive notifications about alert groups and incidents. While the Grafana mobile app with push notifications is the recommended primary notification method, phone calls and SMS serve as valuable backup options, especially for critical alerts.
Prerequisites
Before you begin, ensure you have the following:
  • A Grafana Cloud account with access to Grafana IRM
  • A phone number that can receive SMS messages or phone calls for verification
  • A phone number in a country IRM supports on your plan, as listed in Supported countries for phone and SMS notifications
  • Access to your Grafana Cloud profile settings
Verify your phone number
You must verify your phone number with Grafana IRM before you can add phone or SMS notifications to your notification rules.
Follow these steps to verify your phone number:
  1. Navigate to the IRM tab of your Grafana Cloud Profile
  2. Select Phone verification
  3. Enter your phone number in E.164 format (refer to Phone number format)
  4. Select the checkbox to agree to receive SMS messages from Grafana Labs and to the SMS privacy notice and terms. You must select it before you can request a code by SMS or by phone call.
  5. Choose how you want to receive your verification code:
    • Click Send verification code to receive the code by SMS.
    • Click Call to get the code to receive the code through an automated phone call.
  6. Enter the verification code to complete verification.
You only need to complete one of these methods to verify your number—either SMS or a phone call, not both.
Tip
If your number can’t receive SMS—for example, a landline—use Call to get the code instead. IRM reads the verification code to you over an automated phone call.
Verification isn’t available in every country, and in some countries IRM can only send the code by phone call. Refer to Phone number verification for the country lists.
Phone number format
To verify your phone number in Grafana IRM, you must enter it using E.164 format, an international standard for phone numbers. If your number isn’t formatted correctly, IRM can’t send you a verification code.
E.164 format uses the following structure:
  • Start with a plus sign (+)
  • Follow with your country calling code
  • Then your area code and local number, with no spaces, parentheses, or dashes
Note
In many countries, local numbers include a leading 0 (called a trunk code). When using E.164, remove this 0 after the country code. For example, 020 (United Kingdom) becomes +442071838750.
Format examples
CountryLocal formatE.164 format
United States(623) 377-1955+16233771955
United Kingdom020 7183 8750+442071838750
Germany030 901820+4930901820
India091 12345678+919112345678
Manually verify a user’s phone number
If a user can’t complete either self-service verification flow—SMS or phone call—for example, because they aren’t receiving the verification code, an administrator can manually mark the number as verified.
Note
This action requires the User Settings Admin RBAC role (grafana-irm-app.user-settings:admin). The Mark as verified button only appears when an administrator views another user’s profile, not their own. Manual phone verification is only available on paid plans, not on the Free tier.
To manually verify a user’s phone number:
  1. Navigate to IRM > Users and select the user.
  2. Open the Overview tab.
  3. In the Phone connector, click Mark as verified.
IRM verifies the phone number and sends the user an SMS confirmation.
If the user had a previously verified phone number, IRM also sends an SMS to that number to notify them it’s been disconnected.
For more information about the User Settings Admin role, refer to Roles and permissions for Grafana IRM.
Add phone notifications to your notification rules
After verifying your phone number, you can add phone calls and SMS to your notification rules:
  1. Navigate to the IRM tab of your Profile
  2. Click Notification rules
  3. Edit either your Default notification rules or Important notification rules
  4. Click Add notification step
  5. Select Notify by and choose either SMS or Phone call
  6. Set the appropriate timing
  7. Click Save
For more information about configuring notification rules, refer to Configure notification rules.
Improve phone and SMS notification delivery
Your mobile device settings can affect how reliably phone call and SMS notifications from Grafana IRM reach you. The following settings help make sure notifications get through and stand out on your device.
Sync IRM phone numbers to your contacts
With the Grafana mobile app, you can sync the phone numbers used by Grafana IRM to your mobile device’s contacts. This makes it easier to recognize IRM calls and optionally allow them to override Do Not Disturb (DnD) or silent mode.
When enabled, this setting creates a contact named Grafana IRM that includes the phone numbers IRM uses to call and text you. The contact is managed by the mobile app and automatically updated with any IRM numbers when the app is opened.
Note
You must grant the mobile app access to your contacts for this feature to work. In the Grafana mobile app, go to Settings > Sync Grafana IRM contact. If access is denied, the contact can’t be synced.
Allow IRM contact to override Do Not Disturb
Syncing the IRM contact doesn’t automatically override DnD. To make sure IRM calls or messages come through during urgent situations, manually configure your device settings.
iOS: Enable Emergency Bypass
  1. Open your Contacts and find the Grafana IRM contact
  2. Tap Edit in the top-right corner
  3. Tap Ringtone or Text Tone
  4. Enable Emergency Bypass
  5. Tap Done
This allows calls and messages from IRM to ring even when your device is in silent mode or DnD is active.
Android: Override Do Not Disturb
The process for overriding DnD on Android varies by manufacturer and version. Refer to your device settings to configure exceptions for the IRM contact.
Phone and SMS notification behavior
Grafana IRM applies default behavior to reduce notification noise and let you take action directly from a phone call. This includes how SMS messages are bundled together and how pressing a key during a phone call can acknowledge, resolve, or silence an alert group.
SMS bundling behavior
IRM reduces alert noise and distraction by bundling SMS notifications:
  1. The first alert group triggers an immediate SMS notification
  2. A 2-minute waiting period follows, during which additional alerts are bundled
  3. After this period, a single SMS with all alert information is sent
Notifications are bundled based on their importance. Alerts from “default” and “important” notification policies are bundled separately.
Example bundled notification
If you need to be notified about five alert groups from two different integrations (three from “Grafana Alerting” and two from “Health Check”), you receive:
  1. An immediate notification for the first alert group
  2. A bundled SMS for the remaining alerts after 2 minutes
The bundled SMS appears as:
text
Grafana IRM: Alert groups #101, #102, #103 and 1 more, from stack: TestOrg, integrations: GrafanaAlerting and 1 more.
Respond to an alert during a phone call
When Grafana IRM calls you about an alert group, the call plays the alert message and then prompts you to respond using your phone’s keypad:
  • Press 1 to acknowledge the alert group
  • Press 2 to resolve the alert group
  • Press 3 to silence the alert group for 30 minutes
  • Press 4 to repeat the message
If you press 4, the call repeats the alert message and the keypad options. If you press a key other than 1, 2, 3, or 4, the call says “Invalid option, please try again” and repeats the keypad options. Each call allows three of these attempts in total. Repeats and invalid keys count toward the same limit.
If you don’t press a key, the call ends with “We didn’t receive any input. Goodbye!” If you exceed the limit, the call ends instead of prompting again. It says “Repeat limit reached. Goodbye!” if the last key was 4, or “Too many invalid attempts. Goodbye!” if the last key was invalid.
In all of these cases, the alert group’s status doesn’t change.
Note
The Test call button used during phone number verification only plays the alert message. It doesn’t include the keypress prompt. To try the interactive menu, use a real alert notification.
Voicemail doesn’t acknowledge or resolve alerts
Answering a phone call notification, including when it’s picked up by voicemail, doesn’t acknowledge, resolve, or silence the alert group by itself. IRM only takes action when it receives a keypress (1, 2, or 3) during the call. A completed call that doesn’t register a keypress only adds a “phone call … was successful” entry to the alert group’s timeline. It doesn’t change the alert group’s status or stop escalation.
If an alert group’s status changes unexpectedly after a call goes to voicemail, open the alert group details page and check its timeline to confirm what happened:
  • An entry like Acknowledged/Resolved via phone call means IRM received a keypress during the call. If nobody intentionally pressed a key, your voicemail greeting or phone system might be generating DTMF tones that IRM interprets as input.
  • An entry that only shows the call was successful, with no acknowledgment or resolution, means the call completed but IRM didn’t receive a keypress.
Supported countries and limitations
The countries IRM can call or text depend on your Grafana Cloud plan. The Free tier covers a smaller set of countries than paid plans. For the full lists, refer to Supported countries for phone and SMS notifications.
Note
In some cases, IRM isn’t able to make phone calls or send SMS to certain regions or specific phone numbers due to restrictions implemented by its service provider. Use the Grafana mobile app with push notifications as your primary notification method, with phone calls and SMS as backup options.
Source phone numbers
IRM sends phone calls and SMS notifications from a set of dedicated phone numbers. To make sure calls and messages from IRM aren’t blocked, add these numbers to your contacts. Refer to Source phone numbers.
Troubleshoot phone and SMS delivery
If you experience issues receiving phone call or SMS notifications, complete the following steps:
  1. Check that your country is supported on your plan in Supported countries for phone and SMS notifications
  2. Verify your phone number is correctly formatted (refer to Phone number format)
  3. Test your phone and SMS notification setup during non-critical times
  4. Use the Grafana mobile app as your primary notification method
  5. Contact support if you consistently can’t receive calls or SMS to a verified number
Costs and rate limits
  • Costs: There are no additional costs for outgoing calls or SMS notifications
  • Rate limits: There are no specific rate limits, but Grafana Labs reserves the right to stop sending SMS or calls in case of abnormal volume
Next steps
Now that you’ve set up phone and SMS notifications, explore these related topics:
