title: "Phone and SMS notifications | Grafana Cloud documentation"
description: "Set up and use phone calls and SMS notifications in Grafana IRM"
# Phone and SMS notifications
Set up phone calls and SMS notifications in Grafana IRM to receive notifications about alert groups and incidents. While the [Grafana mobile app](/docs/grafana-cloud/alerting-and-irm/irm/mobile-app/) with push notifications is the recommended primary notification method, phone calls and SMS serve as valuable backup options, especially for critical alerts.
## Prerequisites
Before you begin, ensure you have the following:
- A Grafana Cloud account with access to Grafana IRM
- A phone number that can receive SMS messages or phone calls for verification
- Access to your Grafana Cloud profile settings
Grafana IRM supports phone calls and SMS to most countries by default. Refer to the [Supported countries and limitations](#supported-countries-and-limitations) section for specific exceptions and requirements.
## Verify your phone number
You must verify your phone number with Grafana IRM before you can add phone or SMS notifications to your [notification rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/personal-notification-rules).
Follow these steps to verify your phone number:
1. Navigate to the **IRM** tab of your Grafana Cloud **Profile**
2. Select **Phone verification**
3. Enter your phone number in E.164 format (refer to [Phone number format](#phone-number-format))
4. Choose how you want to receive your verification code:
   - Click **Send verification code** to receive the code by SMS.
   - Click **Call to get the code** to receive the code through an automated phone call.
5. Enter the verification code to complete verification.
You only need to complete one of these methods to verify your number — either SMS or a phone call, not both.
> Tip
> If your number can’t receive SMS — for example, a landline — use **Call to get the code** instead. IRM reads the verification code to you over an automated phone call.
### Phone number format
To verify your phone number in Grafana IRM, you must enter it using E.164 format, an international standard for phone numbers. If your number isn’t formatted correctly, IRM can’t send you a verification code.
E.164 format uses the following structure:
- Start with a plus sign (+)
- Follow with your country calling code
- Then your area code and local number, with no spaces, parentheses, or dashes
> Note
> In many countries, local numbers include a leading 0 (called a trunk code). When using E.164, remove this 0 after the country code. For example, 020 (UK) becomes +442071838750.
#### Format examples
Expand table
| Country | Local format   | E.164 format    |
| US      | (623) 377-1955 | `+16233771955`  |
| UK      | 020 7183 8750  | `+442071838750` |
| Germany | 030 901820     | `+4930901820`   |
| India   | 091 12345678   | `+919112345678` |
### Manually verify a user’s phone number
If a user can’t complete either self-service verification flow — SMS or phone call — for example, because they aren’t receiving the verification code, an administrator can manually mark the number as verified.
> Note
> This action requires the **User Settings Admin** RBAC role (`grafana-irm-app.user-settings:admin`). The **Mark as verified** button only appears when an admin views another user’s profile, not their own. Manual phone verification is restricted to paid organizations and is not available for free-tier or trial organizations.
To manually verify a user’s phone number:
1. Navigate to **IRM &gt; Users** and select the user.
2. Open the **Overview** tab.
3. In the **Phone** connector, click **Mark as verified**.
IRM verifies the phone number and sends the user an SMS confirmation.
If the user had a previously verified phone number, IRM also sends an SMS to that number to notify them it’s been disconnected.
For more information about the User Settings Admin role, refer to [User roles and permissions](/docs/grafana-cloud/observe-and-act/respond-to-incidents/set-up/manage-access/#user-roles-and-permissions).
## Add phone notifications to your notification rules
After verifying your phone number, you can add phone calls and SMS to your notification rules:
1. Navigate to the **IRM** tab of your **Profile**
2. Click **Notification rules**
3. Edit either your **Default notification rules** or **Important notification rules**
4. Click **Add notification step**
5. Select **Notify by** and choose either **SMS** or **Phone call**
6. Set the appropriate timing
7. Click **Save**
For more information about configuring notification rules, refer to [Configure notification rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/personal-notification-rules).
## Improve phone and SMS notification delivery
Your mobile device settings can affect how reliably phone call and SMS notifications from Grafana IRM reach you. The following settings help make sure notifications get through and stand out on your device.
### Sync IRM phone numbers to your contacts
With the [Grafana mobile app](/docs/grafana-cloud/alerting-and-irm/irm/mobile-app/), you can sync the phone numbers used by Grafana IRM to your mobile device’s contacts. This makes it easier to recognize IRM calls and optionally allow them to override Do Not Disturb (DnD) or silent mode.
When enabled, this setting creates a contact named **Grafana IRM** that includes all known phone numbers used by IRM to send SMS or make phone calls. The contact is managed by the mobile app and automatically updated with any IRM numbers when the app is opened.
> Note
> You must grant the mobile app access to your contacts for this feature to work. In the Grafana mobile app, go to **Settings** &gt; **Sync Grafana IRM contact**. If access is denied, the contact cannot be synced.
### Allow IRM contact to override Do Not Disturb
Syncing the IRM contact doesn’t automatically override DnD. To make sure IRM calls or messages come through during urgent situations, manually configure your device settings.
#### iOS: Enable Emergency Bypass
1. Open your **Contacts** and find the **Grafana IRM contact**
2. Tap **Edit** in the top-right corner
3. Tap **Ringtone or Text Tone**
4. Enable **Emergency Bypass**
5. Tap **Done**
This allows calls and messages from IRM to ring even when your device is in silent mode or DnD is active.
#### Android: Override Do Not Disturb
The process for overriding DnD on Android varies by manufacturer and version. Refer to your device settings to configure exceptions for the IRM contact.
## Phone and SMS notification behavior
Grafana IRM applies default behavior to reduce notification noise and let you take action directly from a phone call. This includes how SMS messages are bundled together and how pressing a key during a phone call can acknowledge, resolve, or silence an alert group.
### SMS bundling behavior
IRM reduces alert noise and distraction by bundling SMS notifications:
1. The first alert group triggers an immediate SMS notification
2. A 2-minute waiting period follows, during which additional alerts are bundled
3. After this period, a single SMS with all alert information is sent
Notifications are bundled based on their importance. Alerts from “default” and “important” notification policies are bundled separately.
#### Example bundled notification
If you need to be notified about 5 alert groups from 2 different integrations (3 from “Grafana Alerting” and 2 from “Health Check”), you receive:
1. An immediate notification for the first alert group
2. A bundled SMS for the remaining alerts after 2 minutes
The bundled SMS appears as:
text ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```text
Grafana IRM: Alert groups #101, #102, #103 and 1 more, from stack: TestOrg, integrations: GrafanaAlerting and 1 more.
### Respond to an alert during a phone call
When Grafana IRM calls you about an alert group, the call plays the alert message and then prompts you to respond using your phone’s keypad:
- **Press 1** to acknowledge the alert group
- **Press 2** to resolve the alert group
- **Press 3** to silence the alert group for 30 minutes
- **Press 4** to repeat the message
If you don’t press a key, or you press an invalid one, the call ends with the message “We didn’t receive any input. Goodbye!” The alert group’s status doesn’t change.
> Note
> The **Test call** button used during [phone number verification](#verify-your-phone-number) only plays the alert message. It doesn’t include the keypress prompt. To try the interactive menu, use a real alert notification.
#### Voicemail doesn’t acknowledge or resolve alerts
Answering a phone call notification, including when it’s picked up by voicemail, doesn’t acknowledge, resolve, or silence the alert group by itself. IRM only takes action when it receives a keypress (1, 2, or 3) during the call. A completed call that doesn’t register a keypress only adds a “phone call … was successful” entry to the alert group’s timeline. It doesn’t change the alert group’s status or stop escalation.
If an alert group’s status changes unexpectedly after a call goes to voicemail, open the alert group details page and check its timeline to confirm what happened:
- An entry like **Acknowledged/Resolved via phone call** means IRM received a keypress during the call. If nobody intentionally pressed a key, your voicemail greeting or phone system may be generating DTMF tones that IRM interprets as input.
- An entry that only shows the call was successful, with no acknowledgment or resolution, means the call completed but IRM didn’t receive a keypress.
## Supported countries and limitations
Grafana IRM supports phone calls and SMS to most countries worldwide through our service provider, Twilio. However, there are important considerations regarding availability and reliability.
> Note
> In some cases, IRM isn’t able to make phone calls or send SMS to certain regions or specific phone numbers due to restrictions implemented by the service provider. We recommend using the [Grafana mobile app](/docs/grafana-cloud/alerting-and-irm/irm/mobile-app/) with push notifications as your primary notification method, with phone calls and SMS as backup options.
### Phone call support
Phone calls are supported for all available countries, provided that they are not restricted by the service provider.
Twilio may block phone calls to countries or phone numbers that they deem high-risk. Twilio determines country and phone number risk levels based on various factors, including:
- Historical fraud patterns in specific regions
- Unusual calling patterns or volumes
- Reports of fraudulent activity associated with specific numbers
If you experience issues receiving phone call notifications, complete the following steps:
1. Test your phone notification setup during non-critical times
2. Verify your phone number is correctly formatted (refer to [Phone number format](#phone-number-format))
3. Use the Grafana mobile app as your primary notification method
4. Contact support if you consistently can’t receive calls to a verified number
### SMS support
IRM supports SMS notifications to all countries by default, except for the following regions that aren’t supported by our service provider, Twilio:
- Crimea (+7978)
- Cuba (+53)
- Iran (+98)
- North Korea (+850)
- Syria (+963)
If your phone number is in one of these regions, you can’t receive SMS notifications from Grafana IRM.
### Source phone numbers
IRM sends phone calls and SMS notifications from a set of dedicated phone numbers. For SMS, IRM uses a local number for your country where one is available, which improves deliverability and makes messages easier to recognize. Otherwise, IRM uses one of the international numbers from the following list. To make sure calls and messages from IRM aren’t blocked, add these numbers to your contacts.
In many countries, IRM sends SMS messages using the `Grafana IRM` alphanumeric sender ID, in addition to or instead of a phone number.
IRM uses the following phone numbers:
Expand table
| Country        | E.164 format    |
| US             | `+15595464967`  |
| US             | `+16505353920`  |
| US             | `+16572270147`  |
| Finland        | `+358454907754` |
| United Kingdom | `+447888874366` |
| Philippines    | `+639221200249` |
> Note
> This list can change over time, so check back here for the latest numbers. In some cases, depending on your country, mobile provider, or roaming status, the number that calls or texts you may differ from those listed. Always test SMS and phone call notifications to your device to confirm you receive them as expected.
## Costs and rate limits
- **Costs**: There are no additional costs for outgoing calls or SMS notifications
- **Rate limits**: There are no specific rate limits, but we reserve the right to stop sending SMS or calls in case of abnormal volume
## Next steps
Now that you’ve set up phone and SMS notifications, explore these related topics:
- [Configure notification rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/personal-notification-rules) to control when and how phone and SMS notifications are sent
- [Respond to alerts](/docs/grafana-cloud/observe-and-act/respond-to-incidents/respond-to-alerts) to learn about all the ways you can acknowledge, resolve, and silence alert groups
- [Set up live call routing](/docs/grafana-cloud/observe-and-act/respond-to-incidents/guides/live-call-routing) to route incoming calls to the currently on-call engineer
