title: "Incident insights | Grafana Cloud documentation"
description: "Visualize incident data to track metrics and trends in Grafana IRM."
# Incident insights
Incident insights in Grafana IRM enables you to visualize, analyze, and track incident response data. Use these insights to measure your organization’s response effectiveness, identify trends, and continuously improve your incident management processes.
## About incident insights
Incident insights provide:
- A pre-built dashboard with key incident response metrics
- The ability to build custom dashboards using the Grafana Incident data source
- Flexible filtering and exploration by labels, severity, and other dimensions
- Customizable dashboard templates to fit your organization’s needs
- Embedding of incident metrics into existing Grafana dashboards
Incident insights are included with all Grafana IRM plans at no additional cost.
## Set up incident insights
The incident insights dashboard is created automatically when you enable the feature.
To set up and access incident insights for the first time:
1. In the Grafana Cloud main menu, navigate to **Alerts &amp; IRM** &gt; **IRM**.
2. Select **Insights**, then click the **Incidents** tab.
3. Click **Set up Insights dashboard**.
4. You are redirected to the insights dashboard upon completion.
During setup, Grafana IRM:
- Configures the Grafana Incident data source
- Generates a service account and token with viewer permissions
- Creates the pre-built Insights dashboard
To revisit the dashboard later, select **Insights** from the left menu.
## Understand your incident metrics
Grafana IRM tracks several core metrics to help you understand and improve your incident response:
- **Mean Time To Resolution (MTTR):**
  The average time from when an incident starts to when it is resolved.
  **Formula:** `incidentEnd - incidentStart`
  - If `incidentEnd` is not set manually, it defaults to the time the incident was marked as resolved (`closedTime`).
- **Mean Time To Detect (MTTD):**
  The average time from when an incident starts to when it is declared.
  **Formula:** `incidentCreated - incidentStart` The result of that formula is available as `time_to_discovery`.
Incident field definitions:
Expand table
| Field             | Description                                                    | Editable? |
| `incidentStart`   | Actual start of the incident (editable, even after resolution) | Yes       |
| `incidentCreated` | Timestamp when the incident was declared                       | No        |
| `incidentEnd`     | Actual end of the incident (editable, even after resolution)   | Yes       |
| `closedTime`      | When the incident was administratively resolved                | No        |
> Note
> If you edit `incidentStart` or `incidentEnd` after an incident is resolved, metrics such as MTTR and MTTD update automatically.
### Query syntax
The Incident data source uses the [incident query syntax](/docs/grafana-cloud/observe-and-act/respond-to-incidents/reference/incident-query-syntax), which is also used to filter the incident in Grafana IRM You can reuse any bookmarked or saved expressions from Grafana IRM.
#### Example queries
- Critical or security-related incidents:
  ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
  ```none
  or(severity:critical label:security)
- Active incidents within a timeframe:
  ```none
  status:active started:${__from:date}, ${__to:date}
- Resolved incidents without a specific label:
  ```none
  status:resolved -label:value
- Resolved incidents with multiple specific labels:
  ```none
  status:resolved or(label:'squad:incident' label:PIR)
## Filter incidents
When filtering by multiple values:
- **Label filters** (e.g., `service_name:accounts service_name:orders`) use **AND** logic. Only incidents with *all* specified label values will match.
- Other filters (like `status:active status:resolved`) use **OR** logic.
> Note
> This behavior is different from other filters. If your query returns no results, check your label filter logic.
## Correct or modify incident timelines
If your metrics are inaccurate due to late declaration or resolution of an incident:
- Adjust `incidentStart` or `incidentEnd` using the timeline editor.
- `incidentCreated` cannot be changed. If this affects your MTTD, consider annotating the incident or filtering it out in your analysis.
## Create custom insights dashboards
You can create custom dashboards to visualize incident data that matters most to your teams:
1. In Grafana Cloud, go to **Dashboards** &gt; **New Dashboard**.
2. Add a new panel.
3. Select the Grafana Incident data source.
4. Build queries using the syntax described in the following sections.
5. Choose visualizations to highlight key metrics.
### Use variables in queries
The Query Editor supports [Grafana Variables](/docs/grafana/latest/dashboards/variables/), which allows you to create interactive dashboards. Variables allow you to create dynamic dashboards where users can select different values to update the visualizations.
The Incident data source recognizes the following variable names:
Expand table
| Variable name | Query type | Filters by                               |
| `statuses`    | Status     | Incident status (active, resolved, etc.) |
| `severities`  | Severity   | Incident severity levels                 |
| `labels`      | Label      | Incident labels                          |
| `roles`       | Role       | Incident roles                           |
> Note
> The variable **name** (not display name) must match exactly as above, including case.
### Example: Creating a variable for incident labels
1. Create a new dashboard query variable.
2. Set the **Name** field to exactly `labels`.
4. Select “Labels” as the query type to return label values.
5. Configure the variable to allow multi-selection.
Example query using variables:
```none
or(status:$statuses) or(severity:$severities) or(label:$labels)
> Note
> Some older queries (such as `status:resolved or($labels)`) may no longer work. Update your dashboards to use the current variable names.
## Troubleshoot dashboard variables or queries
If your dashboard variables or queries are not working, you may be using an outdated Insights dashboard template. To update, consult the latest dashboard template examples or rebuild your dashboard using the current variable names and query syntax.
> Note
> Insights queries ignore Drill incidents, unless you explicitly query with `isdrill:true`.
## Analyze incident data
Key metrics for incident analysis include:
- **Mean Time To Resolution (MTTR):** Average time from incident start to resolution
- **Mean Time To Detect (MTTD):** Average time from incident start to declaration
- **Incident frequency:** Number of incidents over time, by severity or service
- **Team impact:** Distribution of incidents across teams and services
- **Root cause patterns:** Common themes in incident causes identified through labels
- **Time of day patterns:** When incidents are most likely to occur
## Best practices
- Start with the pre-built dashboard to understand available metrics
- Create custom dashboards for specific teams or services
- Use consistent labeling to enable meaningful filtering and grouping
- Track trends over time rather than focusing on point-in-time metrics
- Compare related metrics such as MTTR alongside incident count
## Next steps
- [Learn about alert groups insights](/docs/grafana-cloud/observe-and-act/respond-to-incidents/measure-and-improve/alert-group-insights) to complement your incident metrics
- [Configure incident management](/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/customize-incident-response) to improve your processes
- [Set up dashboards](/docs/grafana/latest/dashboards/build-dashboards/create-dashboard/) for custom visualizations
