This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/measure-and-improve.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/measure-and-improve/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Insights and reporting
Grafana IRM provides insights and reporting capabilities to help you measure, analyze, and improve your incident response processes. These tools give you visibility into alert groups handling efficiency, incident resolution times, and team performance metrics.
Alert groups insights
Alert group insights provide visibility into your alert groups routing and escalation performance. You can access:
- Alert groups metrics: Track alert groups volume, response times, and notification patterns
- Alert groups logs: Monitor changes to your alerting configuration and track maintenance events
- Pre-built dashboards: Visualize key alert groups handling metrics in customizable dashboards
Incident insights
Incident insights help you understand and improve your incident management processes. With incident insights, you can:
- Monitor incident metrics: Track MTTR, incident volume, and resolution trends
- Build custom dashboards: Create visualizations tailored to your organization’s needs
- Filter and analyze: Segment data by severity, team, service, and other dimensions
Next steps
- Configure alert group insights to track alert group metrics and logs
- Set up incident insights to visualize incident data
Was this page helpful?
