title: "Link related incidents | Grafana Cloud documentation"
description: "Learn how to link incidents in Grafana IRM and organize them into parent and child incidents"
# Link related incidents
Large or complex problems often involve more than one incident. Link incidents in IRM so responders can see how incidents connect, move between them quickly, and track parts of a larger incident separately.
You can link incidents in two ways:
- **Related**: The incidents are connected, but neither is part of the other. For example, two outages share the same upstream cause.
- **Parent and child**: The child incident tracks part of the parent incident. For example, a regional database failure is the parent of the incidents for each affected service. An incident can have one parent and any number of children.
Links are two-way. When you link incident A to incident B, the link appears on both incidents.
## Before you begin
You can link incidents that you have access to, including private incidents.
## View related incidents
Every incident page has a **Related incidents** tab that lists the incidents linked to it. The tab groups them into:
- **Parent incident**: The incident this incident is part of, if any.
- **Child incidents**: The incidents that track parts of this incident.
- **Related incidents**: Other incidents linked to this one.
Each entry shows the title, ID, and status of the linked incident. Click the title to open the linked incident.
If a linked incident is private and you don’t have access to it, it doesn’t appear in the list.
## Link incidents
To link the current incident to another incident:
1. Open the incident and select the **Related incidents** tab.
2. Click **Link incident**.
3. In **Relationship**, select how this incident relates to the other incident:
   - **Relates to**: Neither incident is part of the other.
   - **Is parent of**: The selected incident becomes a child of this incident.
   - **Is child of**: This incident becomes a child of the selected incident.
4. In **Incident**, search for the incident by title and select it.
5. Click **Link incident**.
IRM rejects a parent and child link if the child already has a different parent, or if the link would make an incident its own ancestor. You can link two incidents in only one way at a time. To change the relationship, unlink the incidents first, and then link them again.
## Declare a child incident
To declare a child of the current incident:
1. Open the parent incident.
2. On the **Related incidents** tab, click **Declare child incident**. You can also select **Declare child incident** from the incident menu.
3. Complete the declaration form. The form names the parent incident.
4. Click **Declare incident**.
To learn more about the declaration form, refer to [Declare an incident](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/declare-incident).
You can also declare child incidents automatically from other tools by adding the `parent_incident_id` parameter to an incident incoming webhook. To learn more, refer to [Configure Incident incoming webhooks](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/integrations/custom-integrations/incoming-webhooks/incident-webhooks).
## Unlink incidents
To remove a link:
1. Open either incident and select the **Related incidents** tab.
2. Click **Unlink incident**, the trash can icon next to the linked incident.
3. Click **Unlink** to confirm.
IRM removes the link from both incidents. The incidents themselves don’t change.
## Manage links with the API
Use the Incident API to manage links programmatically:
- `IncidentsService.AddIncidentRelationship` links two incidents.
- `IncidentsService.RemoveIncidentRelationship` removes a link.
- `IncidentsService.CreateIncident` accepts a `parentIncidentID` to declare a child incident.
- `IncidentsService.GetIncident` returns the links for an incident in `incidentRelationships`.
The `relationshipType` value describes the incident in `incidentID`. For example, `isParentOf` makes `incidentID` the parent of `relatedIncidentID`.
To learn more, refer to [Incident API reference](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/reference/incident-api/reference).
## Next steps
- [Declare an incident](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/declare-incident)
- [Configure Incident incoming webhooks](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/integrations/custom-integrations/incoming-webhooks/incident-webhooks)
- [Incident API reference](https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/reference/incident-api/reference)
