Last reviewed: March 4, 2026
Configure incident response settings
Grafana IRM provides configurable settings for incident severity levels, statuses, roles, and custom fields. These settings help standardize your incident management process and ensure consistency across teams.
To access these settings, go to IRM > Settings and select the Incidents tab.
Severity levels
Incident severities in Grafana IRM provide a consistent way to measure the impact of incidents. Customizing these severity levels helps your team understand the urgency of an incident and respond appropriately.
Severity levels can influence your incident response process, such as who is engaged and how quickly you respond. To maximize their effectiveness, define each severity level clearly and ensure your team understands the expected response for each level.
Pre-configured severity levels
Grafana IRM provides the following severity levels by default:
SeverityDescription
CriticalUrgently requires immediate attention.
MajorSignificant, blocking problem that requires help.
MinorMay be affecting customers, but no one is blocked.
PendingSeverity to be decided and should be determined as soon as possible.
If your organization uses different terminology or prioritization systems, you can customize these severity levels or add new ones to fit your needs.
When you declare a new incident without choosing a severity, it defaults to Pending. You can change this default to any active severity level. Refer to Set the default severity for instructions.
You can configure which severity level is automatically selected when declaring a new incident. This is useful if your organization primarily responds to high-impact incidents and wants to default to a higher severity.
To set the default severity:
  1. In the Grafana Cloud main menu, go to IRM > Settings.
  2. Select the Incidents tab.
  3. Under Severities, locate the Default severity dropdown at the bottom of the severity list.
  4. Select the severity level you want to use as the default.
The change takes effect immediately. Any new incident declared without an explicit severity selection uses the configured default.
To reset to the original behavior, select Pending (or whichever severity your organization considers the lowest priority) from the dropdown.
Add incident severity levels
You can add custom severity levels to match your organization’s terminology and priorities.
  3. Under Severities, click Add new Severity.
  4. Provide the following information:
    • Label: A name for the severity level (such as P1, Critical, or High).
    • Level: A numerical value indicating the severity’s priority (e.g., 1 for highest priority).
    • Description: Optionally, provide details about when to use this severity level.
    • Icon: Optionally, select an icon to visually represent the severity.
  5. Click Save.
Edit incident severities
You can update existing severity levels to better align with your organization’s processes.
  3. Under Severities, click the pencil icon next to the severity you want to edit.
  4. Modify the Label, Description, or Icon as needed.
  5. Click Save.
Note
The Level field cannot be changed after a severity is created. To use a different level, create a new severity with the desired level and archive the old one.
Note
Ensure your custom severity levels map to the corresponding pre-configured severity levels in Grafana IRM. For example, define your highest severity as Critical to match the default mapping.
Example: Mapping custom severities
If your organization uses P1-P4 as severity levels, you might map them as follows:
Custom severityPre-configured severity
Priority 1Critical
Priority 2Major
Priority 3Minor
Priority 4Pending
Archive and unarchive incident severities
Archiving severities allows you to remove those that aren’t relevant without deleting them permanently.
  3. Under Severities, click the Archive icon next to the severity you want to archive.
  4. To unarchive, locate the severity in the archived list and click Unarchive
Delete incident severities
If a severity level is no longer needed, you can delete it.
  3. Under Severities, click the Trash icon next to the severity you want to delete.
  4. Click Confirm remove to permanently delete the severity.
Statuses
Incident statuses in Grafana IRM indicate whether an incident is ongoing or resolved. They help responders and stakeholders quickly understand if incident response is still in progress.
Default incident statuses
Grafana IRM provides the following default statuses:
StatusDescription
ActiveThe incident is happening now
ResolvedThe incident is resolved
You can customize these statuses or add new ones to better reflect your organization’s incident process.
Add incident statuses
You can create custom incident statuses to match your organization’s incident lifecycle.
  3. Under Statuses, click Add new Status.
    • Name: A name for the status (such as Monitoring, Escalated, or Closed).
    • Description: Optionally, describe the purpose of this status to help your team apply it consistently.
    • Icon: Optionally, select an icon to visually represent the status.
    • Color: Optionally, assign a color to make the status more recognizable.
  5. Click Save.
Edit incident statuses
You can customize existing statuses to ensure they match your organization’s workflow.
  3. Under Statuses, click the pencil icon next to the status you want to edit.
  4. Modify the Name, Icon, Color, or Description as needed.
  5. Click Save.
Archive and delete incident statuses
You can archive or delete statuses depending on their usage and relevance.
Archive a status
If a status has been used in incidents, archiving prevents future use while preserving historical data.
  3. Under Statuses, click Archive next to the status you want to archive.
To unarchive a status, locate it in the archived list and click Unarchive.
Delete a status
You can only delete a status that has never been used in incidents.
  3. Under Statuses, click the trash icon next to the status you want to delete.
  4. Click Confirm remove to permanently delete the status.
Reorder incident statuses
You can customize the order in which statuses appear in dropdown menus.
  3. Under Statuses, drag and drop statuses to reorder them as needed.
  4. Your changes are saved automatically.
Roles
Incident roles in Grafana IRM help identify who is involved in an incident and what they are responsible for. Assigning roles ensures clarity in communication, decision-making, and task management during incident response.
Pre-configured incident roles
Grafana IRM includes the following recommended key roles by default:
  • Commander: Oversees the incident by managing communication, tasks, and necessary updates.
  • Investigator: Responsible for diagnosing and resolving the incident.
You can customize these roles or create additional roles to match your organization’s incident response process.
Add a new incident role
You can create custom roles to fit your organization’s specific incident response requirements.
  3. Scroll to the Roles section.
  4. Click Add new role.
  5. Provide the following information:
    • Name: The name of the role (such as Scribe, Support, or Operations Lead).
    • Description: Optionally, describe the role’s responsibilities to provide clarity for your team.
    • Key Role: Optionally, check this box if this role is critical to your incident response process.
  6. Click Add to create the role.
Edit an incident role
You can modify existing roles to ensure they align with your organization’s processes.
  4. Click the pencil icon next to the role you want to edit.
  5. Modify the Name, Description, or Key Role designation as needed.
  6. Click Update to save your changes.
Archive an incident role
Archiving a role prevents its use in future incidents but preserves historical data for incidents where the role was previously used.
  4. Click the lock icon next to the role you want to archive.
  5. Click Confirm archive to archive the role.
To restore an archived role, find it in the archived list and click Unarchive.
Delete an incident role
If a role is no longer relevant and has not been used in any incidents, you can delete it permanently.
  4. Click the trash can icon next to the role you want to delete.
  5. Click Confirm remove to permanently delete the role.
Note
Deleting a role is irreversible. If you might need the role later, consider archiving it instead.
Custom fields
Grafana IRM allows you to add custom incident fields to capture organization-specific metadata relevant to your incident management process.
This feature provides the flexibility to customize incidents according to your unique workflows and requirements, ensuring that important details are properly recorded.
The Fields section on the Incidents settings tab lists all incident metadata fields. Built-in fields appear at the top of the table and can’t be edited or removed. Fields you create appear under the Custom section. The Mandatory column indicates which fields must be completed before an incident can be resolved, including when you resolve it from Slack. Refer to Use custom fields in Slack.
Supported data types
You can define custom fields with various input types to capture important incident details and perform incident analysis.
When creating custom fields, you can choose from the following input types:
  • Text: A simple text input for freeform data
  • Number: A numerical input for quantitative data
  • Single-select: A dropdown menu that allows selection of one predefined option
  • Multi-select: A dropdown menu that allows selection of multiple predefined options
Add a custom field
To create a custom field:
  1. In the Grafana Cloud main menu, click IRM > Settings.
  3. Locate the Fields section.
  4. Click + Add field.
  5. Configure the following settings:
    • Name: Enter a descriptive name for the custom field (for example, Region, or Service Impacted).
    • Description: (Optional) Add a description that explains the purpose of this field to your team. In Slack, the description appears as a hint below the field.
    • Type: Select the field input type (Text, Number, Single-select, or Multi-select).
    • Mandatory: Toggle this option if the field must be completed before resolving an incident.
  6. Click Save.
Edit a custom field
To modify an existing custom field:
  3. Scroll to the Fields section.
  4. Under Custom, click the pencil icon next to the field you want to modify.
  5. Update any of the following:
    • Name
    • Description
    • Type
    • Mandatory status
  6. Click Save.
Delete a custom field
Warning
Deleting a custom field permanently removes it and cannot be undone. Consider editing the field instead if you might need it later.
To delete a custom field:
  4. Under Custom, click the trash icon next to the field you want to remove.
  5. Click Confirm remove.
Use custom fields during an incident
You can add or update custom field values for both active and resolved incidents:
  1. Navigate to the incident page.
  2. Locate the Custom Fields section in the right sidebar.
  3. Click the section to expand it.
  4. Enter values based on the field type:
    • Text fields: Type your text directly
    • Number fields: Enter a numerical value
    • Single-select fields: Choose one option from the dropdown menu
    • Multi-select fields: Select one or more options from the dropdown menu
Note
When resolving an incident, you must complete all mandatory custom fields before the incident can be resolved.
Best practices
Consider these recommendations when configuring custom fields:
  1. Use clear, descriptive field names that align with your organization’s terminology
  2. Add helpful descriptions to guide users on how to use each field
  3. Use single-select or multi-select fields when possible to maintain consistent data
  4. Limit the number of custom fields to prevent information overload during incident response
  5. Make fields mandatory only when the information is essential for incident analysis
