This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/customize-incident-response/incident-channels.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/customize-incident-response/incident-channels/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Customize incident channel prefixes
Creating dedicated incident channels helps keep communication organized during an incident and improves post-incident analysis. Channel prefixes in Grafana IRM determine the names of automatically created incident channels, making them easier to find and manage.
For example, if the channel prefix is security, the channel name will be formatted as #security-date-title.
Why customize channel prefixes?
Using customized channel prefixes allows you to:
- Differentiate incident channels by team, service, or severity.
- Ensure consistent naming conventions for better organization and searchability.
- Improve post-incident reviews by making channels easier to locate and analyze.
Tip
To maintain searchable and manageable incident channels, consider using different prefixes for various teams or services.
Add a channel prefix
You can create custom channel prefixes to fit your organization’s incident management practices.
- In the Grafana Cloud main menu, go to IRM > Settings.
- Select the Incidents tab.
- Scroll to the Prefixes section.
- Click Add Prefix.
- Provide the following information:
- Name: The prefix you want to use (such as
security,ops, orinfra). - Description: Optionally, describe the purpose of the prefix for your team’s reference.
- Click Add to create the prefix.
Edit a channel prefix
You can update existing prefixes to better align with your organization’s naming conventions or processes.
- Click the pencil icon next to the prefix you want to edit.
- Modify the Name or Description as needed.
- Click Update to save your changes.
Using channel prefixes
Once your prefixes are defined, you can specify which prefix to use when declaring an incident in Grafana IRM. Prefixes help standardize incident channel names, making them easier to search and analyze later.
Was this page helpful?
