This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/customize-incident-response.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/respond-to-incidents/manage-incidents/customize-incident-response/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Customize incident response process
Grafana IRM provides customizable incident settings that let you tailor your incident response workflow to match your organization’s processes and terminology. By configuring these settings, you can standardize your incident management process and ensure consistency across teams.
Before you begin
To configure incident settings in Grafana IRM, you need:
- A Grafana Cloud account with Admin permissions
- Access to the Grafana IRM application and an understanding of your incident response process.
Access incident settings
You can review and update incident settings at any time.
- In the Grafana Cloud main menu, go to IRM > Settings.
- Select the Incidents tab.
- Configure incident response settings
Configure incident severity levels, statuses, roles, and custom fields in Grafana IRM. - Customize incident channel prefixes
Configure incident channel prefixes in Grafana IRM - Configure incident announcements
Configure incident announcements in Slack to keep your team informed during critical events - Configure incident briefings
Configure incident briefings in Grafana IRM to automatically post standardized information into new incident Slack channels - Private incidents
Learn how to use private incidents for sensitive situations in Grafana IRM.
Was this page helpful?
