Last reviewed: March 4, 2026
Configure routing rules in Grafana IRM
Alert routes in Grafana IRM determine how incoming alerts are processed based on their content. By creating routes with specific conditions, you can direct different alerts to the appropriate escalation chains, ensuring the right teams are notified for each type of alert.
About alert routes
Routes act as filters that evaluate incoming alerts and direct them to specific escalation chains. When an alert arrives, Grafana IRM evaluates it against each route in order, and the first matching route determines how the alert will be handled.
Routes are configured per integration. Each integration has its own set of routes, so you can tailor routing to each alert source’s data structure.
Key features of alert routes:
  • Routes use Jinja2 templates to create flexible matching conditions
  • Routes are evaluated in order (top to bottom), with the first match taking precedence
  • Each route connects to a specific escalation chain
  • Routes can publish alerts to communication channels (Slack, Microsoft Teams)
  • Routes can be assigned to specific teams
How routing works
The alert routing process follows these steps:
  1. An alert arrives through an integration (like Prometheus, Grafana Alerting, or a webhook)
  2. The alert’s payload is evaluated against each route’s routing template in sequence
  3. The first route with a template that evaluates to True is selected
  4. The alert is sent to the escalation chain specified by the matching route
  5. If configured, the alert is also published to the specified communication channels
Create and manage routes
Routes are managed from the integration that receives the alerts. Each integration’s settings include these tabs:
  • Alert Templates: Configure how alerts are displayed and processed.
  • Routes: Define which escalation chains handle different alerts.
  • Settings: Manage alert grouping and other integration-specific options.
To create a new alert route:
  1. In Grafana IRM, navigate to Integrations.
  2. Select the integration where you want to add a route.
  3. Click Add route.
  4. In the Routing Template section, define conditions for alert matching (refer to Routing templates).
  5. Select the appropriate escalation chain from the Escalation Chain dropdown.
    • If needed, click Add new escalation chain to create a new chain in a separate tab.
    • After creating the chain, return to the routes page and click Reload list.
  6. Optional: In the Publish to ChatOps section, select communication channels for alert notifications.
  7. Click Save to create the route.
You choose the channel in Publish to ChatOps for each route, which is how you send different alerts to different channels. Microsoft Teams has no escalation chain step that posts to a channel, so the route is the only place you configure it. Refer to Choose a channel for a route.
To manage existing routes:
  • Change route order: Use the up/down arrows to reorder routes. Remember that routes are evaluated in order, and the first match wins.
  • Edit a route: Click the route to open its settings, make changes, and save.
  • Delete a route: Click the three dots menu on the route and select Delete Route.
Routing templates
Routing templates use Jinja2 syntax to create conditions for matching alerts. A template must evaluate to True for the route to be selected.
Basic routing examples
Match alerts with “database” in the title:
{{ "database" in payload.title | lower }}
Match critical severity alerts:
{{ payload.severity == "critical" }}
Match alerts from a specific service:
{{ payload.service == "payment-processor" }}
Match alerts with specific labels:
{{ payload.labels.environment == "production" }}
Name a route
Routes don’t have a separate name field. IRM identifies a route by its routing template, so a long template makes the alert group timeline hard to read.
To give a route a readable name, start its routing template with a Jinja2 comment on the first line:
{# Critical database alerts #}
{{ "database" in payload.title | lower and payload.severity == "critical" }}
When the first line is a comment, IRM shows the comment text wherever it names the route, such as the alert group assigned to route entry in the alert group timeline and in Slack, Microsoft Teams, and Telegram notifications. Names longer than 50 characters are truncated.
If the template doesn’t start with a comment, IRM shows the routing template itself, on a single line and truncated to 50 characters.
Combined conditions
You can combine multiple conditions using logical operators:
Match critical database alerts:
Match either production or staging environment alerts:
{{ payload.labels.environment == "production" or payload.labels.environment == "staging" }}
Match non-development environment alerts:
{{ payload.labels.environment != "development" }}
Accessing payload data
The routing template has access to the complete alert payload through the payload variable. The exact structure depends on the integration and incoming alert format.
Common payload fields include:
  • payload.title - Alert title
  • payload.message - Alert message
  • payload.severity - Alert severity level
  • payload.labels - Alert labels (as a dictionary)
  • payload.annotations - Alert annotations (as a dictionary)
Use {{ payload }} in a template to print the entire alert structure for debugging.
Label-based routing
For integrations that support structured labels (like Prometheus, Grafana Alerting), you can route based on label values:
{{ labels.team == "database" }}
This provides additional flexibility compared to payload-based routing, especially for alerts with well-structured metadata.
Example routing strategies
Team-based routing
Direct alerts to teams based on labels or service names:
# Database team route
{{ labels.team == "database" or "database" in payload.title | lower }}
# Frontend team route
{{ labels.team == "frontend" or "frontend" in payload.title | lower }}
# Default route (catches all remaining alerts)
{{ True }}
Severity-based routing
Create different escalation chains based on alert severity:
# Critical alerts route
{{ payload.severity == "critical" or labels.severity == "critical" }}
# Warning alerts route
{{ payload.severity == "warning" or labels.severity == "warning" }}
# Info alerts route
{{ payload.severity == "info" or labels.severity == "info" }}
Environment-based routing
Route differently based on the environment:
# Production route (high priority escalation)
{{ labels.environment == "production" }}
# Staging route (medium priority escalation)
{{ labels.environment == "staging" }}
# Development route (low priority escalation)
{{ labels.environment == "development" }}
Team hours routing
Route alerts differently depending on whether the integration’s team is working. The within_team_hours variable is True when the team assigned to the integration is within its team hours, and False outside them. It’s also True when the integration has no team, or the team has no team hours.
# After-hours critical route (pages the after-hours on-call)
{{ payload.severity == "critical" and not within_team_hours }}
# Business hours route
{{ within_team_hours }}
{{ True }}
The template preview doesn’t evaluate within_team_hours, so check this kind of route with a test alert. For details, refer to Route alerts by team hours.
Best practices
  • Order matters: Place more specific routes above more general ones
  • Default route: Create a catch-all route at the bottom that matches all alerts ({{ True }})
  • Test templates: Use the template preview feature to test your conditions with sample payloads
  • Use descriptive names: Name each route with a leading Jinja2 comment so the timeline shows its purpose instead of the full template, refer to Name a route
  • Documentation: Add comments in complex templates to explain the logic
  • Simplify conditions: Break complex conditions into multiple routes when possible
  • Review regularly: Periodically review routes to ensure they’re still appropriate
Next steps
