title: "Configure routing rules in Grafana IRM | Grafana Cloud documentation"
description: "Configure routing rules to evaluate incoming alerts against Jinja2 templates and direct them to the correct escalation chain."
# Configure routing rules in Grafana IRM
Alert routes in Grafana IRM determine how incoming alerts are processed based on their content. By creating routes with specific conditions, you can direct different alerts to the appropriate escalation chains, ensuring the right teams are notified for each type of alert.
## About alert routes
Routes act as filters that evaluate incoming alerts and direct them to specific escalation chains. When an alert arrives, Grafana IRM evaluates it against each route in order, and the **first matching route** determines how the alert will be handled.
Routes are configured per integration. Each integration has its own set of routes, so you can tailor routing to each alert source’s data structure.
Key features of alert routes:
- Routes use [Jinja2 templates](#routing-templates) to create flexible matching conditions
- Routes are evaluated in order (top to bottom), with the first match taking precedence
- Each route connects to a specific escalation chain
- Routes can publish alerts to communication channels (Slack, Microsoft Teams)
- Routes can be assigned to specific teams
## How routing works
The alert routing process follows these steps:
1. An alert arrives through an integration (like Prometheus, Grafana Alerting, or a webhook)
2. The alert’s payload is evaluated against each route’s routing template in sequence
3. The first route with a template that evaluates to `True` is selected
4. The alert is sent to the escalation chain specified by the matching route
5. If configured, the alert is also published to the specified communication channels
## Create and manage routes
Routes are managed from the integration that receives the alerts. Each integration’s settings include these tabs:
- **Alert Templates**: Configure how alerts are displayed and processed.
- **Routes**: Define which escalation chains handle different alerts.
- **Settings**: Manage alert grouping and other integration-specific options.
To create a new alert route:
1. In Grafana IRM, navigate to **Integrations**.
2. Select the integration where you want to add a route.
3. Click **Add route**.
4. In the **Routing Template** section, define conditions for alert matching (refer to [Routing templates](#routing-templates)).
5. Select the appropriate escalation chain from the **Escalation Chain** dropdown.
   - If needed, click **Add new escalation chain** to create a new chain in a separate tab.
   - After creating the chain, return to the routes page and click **Reload list**.
6. Optional: In the **Publish to ChatOps** section, select communication channels for alert notifications.
7. Click **Save** to create the route.
To manage existing routes:
- **Change route order**: Use the up/down arrows to reorder routes. Remember that routes are evaluated in order, and the first match wins.
- **Edit a route**: Click the route to open its settings, make changes, and save.
- **Delete a route**: Click the three dots menu on the route and select **Delete Route**.
## Routing templates
Routing templates use [Jinja2](https://jinja.palletsprojects.com/) syntax to create conditions for matching alerts. A template must evaluate to `True` for the route to be selected.
### Basic routing examples
Match alerts with “database” in the title:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
{{ "database" in payload.title | lower }}
Match critical severity alerts:
```none
{{ payload.severity == "critical" }}
Match alerts from a specific service:
```none
{{ payload.service == "payment-processor" }}
Match alerts with specific labels:
```none
{{ payload.labels.environment == "production" }}
### Combined conditions
You can combine multiple conditions using logical operators:
Match critical database alerts:
```none
{{ "database" in payload.title | lower and payload.severity == "critical" }}
Match either production or staging environment alerts:
```none
{{ payload.labels.environment == "production" or payload.labels.environment == "staging" }}
Match non-development environment alerts:
```none
{{ payload.labels.environment != "development" }}
### Accessing payload data
The routing template has access to the complete alert payload through the `payload` variable. The exact structure depends on the integration and incoming alert format.
Common payload fields include:
- `payload.title` - Alert title
- `payload.message` - Alert message
- `payload.severity` - Alert severity level
- `payload.labels` - Alert labels (as a dictionary)
- `payload.annotations` - Alert annotations (as a dictionary)
Use `{{ payload }}` in a template to print the entire alert structure for debugging.
## Label-based routing
For integrations that support structured labels (like Prometheus, Grafana Alerting), you can route based on label values:
```none
{{ labels.team == "database" }}
This provides additional flexibility compared to payload-based routing, especially for alerts with well-structured metadata.
## Example routing strategies
### Team-based routing
Direct alerts to teams based on labels or service names:
```none
# Database team route
{{ labels.team == "database" or "database" in payload.title | lower }}
# Frontend team route
{{ labels.team == "frontend" or "frontend" in payload.title | lower }}
# Default route (catches all remaining alerts)
{{ True }}
### Severity-based routing
Create different escalation chains based on alert severity:
```none
# Critical alerts route
{{ payload.severity == "critical" or labels.severity == "critical" }}
# Warning alerts route
{{ payload.severity == "warning" or labels.severity == "warning" }}
# Info alerts route
{{ payload.severity == "info" or labels.severity == "info" }}
### Environment-based routing
Route differently based on the environment:
```none
# Production route (high priority escalation)
{{ labels.environment == "production" }}
# Staging route (medium priority escalation)
{{ labels.environment == "staging" }}
# Development route (low priority escalation)
{{ labels.environment == "development" }}
## Best practices
- **Order matters**: Place more specific routes above more general ones
- **Default route**: Create a catch-all route at the bottom that matches all alerts (`{{ True }}`)
- **Test templates**: Use the template preview feature to test your conditions with sample payloads
- **Use descriptive names**: Give routes clear names that describe their purpose
- **Documentation**: Add comments in complex templates to explain the logic
- **Simplify conditions**: Break complex conditions into multiple routes when possible
- **Review regularly**: Periodically review routes to ensure they’re still appropriate
## Next steps
- [Configure escalation chains](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/escalation-chains) to define notification steps
- [Customize alert templates](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/customize-alert-templates) to customize alert appearance
- Learn about [incoming webhooks](/docs/grafana-cloud/observe-and-act/respond-to-incidents/integrations/custom-integrations/incoming-webhooks) for additional alert sources
