title: "Configure escalation chains in Grafana IRM | Grafana Cloud documentation"
description: "Configure escalation chains to define the sequence of notifications and actions Grafana IRM takes when an alert group is created."
# Configure escalation chains
Escalation chains define the sequence of actions taken when an alert is triggered in Grafana IRM. They automate your incident response workflow by executing ordered steps until an alert is acknowledged, resolved, or all steps complete.
An effective escalation chain:
- Ensures alerts reach the right people at the right time
- Implements tiered response procedures based on severity
- Automates notification and escalation processes
- Prevents alerts from being missed
## Create and manage escalation chains
### Create a new escalation chain
1. Navigate to **IRM** &gt; **Escalation Chains** in the Grafana Cloud menu
2. Click **New escalation chain**
3. Enter a unique name and optional team assignment
4. Click **Add escalation step** to add steps to your chain
5. Configure steps and arrange them using drag-and-drop
6. Click **Save**
### Edit or delete an escalation chain
- To edit: Select a chain and click **Edit**, then make changes and save
- To delete: Select a chain, click **Delete**, and confirm
> Note
> Before deleting, check the **Linked integrations and routes** panel. Changes to the chain affect all associated integrations and routes.
### Manage escalation chains with Terraform
You can use the [Grafana Terraform provider](https://registry.terraform.io/providers/grafana/grafana/latest/docs) to define and manage your escalation chains as code. This enables version control and easier reuse of your on-call workflows.
#### Notify a specific user, user group, or schedule
To notify individual responders or teams (such as a person, user group, or on-call schedule), use the corresponding step type in the [`grafana_oncall_escalation` resource](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/oncall_escalation). Then define the object to notify using the associated `*_to_notify` parameters:
- `notify_persons` + `persons_to_notify`: Notifies specific users
- `notify_persons_next_each_time` + `persons_to_notify_next_each_time`: Round robin notification
- `notify_on_call_from_schedule` + `notify_on_call_from_schedule`: Notifies the currently on-call person from a schedule
- `notify_next_on_call_from_schedule` + `notify_on_call_from_schedule`: Notifies all users from the next upcoming on-call shift in a schedule
- `notify_user_group` + `group_to_notify`: Notifies a defined Slack user group
#### Notify a channel
To post alert groups in a Slack, MS Teams, or Telegram channel, you must define the channel in the `grafana_oncall_route` resource. Then, in the `grafana_oncall_escalation` resource, use the `notify_whole_channel` step to send a message to that channel when the escalation chain is triggered. Please note that this step is only available for Slack channels and that it will trigger a notification for *all* users in the channel, so it should be used with care.
To notify an entire Slack channel:
1. Use the `slack_channel_id` in your `grafana_oncall_route` resource.
2. Use the `notify_whole_channel = true` step type in your `grafana_oncall_escalation` resource.
> Note
> The route defines where the alert group is delivered, and the escalation controls when and whether the whole channel is notified. You can’t post an alert group to one channel and notify a different one.
For more detailed set up instructions, refer to [Manage Grafana IRM in Grafana Cloud using Terraform](/docs/grafana-cloud/developer-resources/infrastructure-as-code/terraform/terraform-oncall/).
## Types of escalation steps
### Notification steps
- **Notify users**: Send notifications to specific users or groups
- **Notify from on-call schedule**: Alert currently on-call users
- **Notify next on-call shift from Schedule**: Notify all users from the next on-call shift in a schedule. If there isn’t a next shift in the lookahead window (14 days), this step is skipped and escalation continues. If the next shift has multiple users (parallel slots or layers), all of them are notified.
- **Notify all team members**: Alert everyone in a specified team
- **Notify Slack channel/user group**: Send notifications to Slack users
- **Round robin notifications**: Rotate through a list of users sequentially
- **Notify users one by one (round robin)**: Notify users sequentially, cycling through users for **different alert groups**. For example, if users A, B, and C are in the list, the first alert group notifies A, the second alert group notifies B, and the third alert group notifies C. Users are sorted alphabetically by their username. To notify multiple users **within the same alert group** until someone acknowledges, use **Notify users** steps with **Wait** steps between them in the escalation chain.
### Timing and control steps
- **Wait**: Pause for a specified duration before proceeding to the next escalation step
- **Repeat escalation**: Loop the previous escalation steps up to five times. To repeat more than five times, structure your escalation chain with multiple repeat steps. Each repeat escalation step has its own counter that is exhausted after reaching five repetitions, then advances to the next step.
  For example:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
1. Notify user
2. Wait 5 minutes
3. Repeat escalation (5 times max)  ← Repeats steps 1-2 up to 5 times
4. Wait 5 minutes
5. Repeat escalation (5 times max)  ← Repeats steps 1-4 up to 5 times
- **Time-based escalation**: Continue only during specified time periods
- **Threshold-based escalation**: Continue escalation only if more than X alerts occur within Y minutes (requires `num_alerts_in_window` and `num_minutes_in_window` parameters)
### Action steps
- **Resolve incident automatically**: Mark the alert group as “Resolved automatically” without user intervention
- **Trigger outgoing webhook**: Send data to an external system using a configured outgoing webhook
- **Declare incident**: Create a new incident with specified severity. Limited to one incident per route at a time; additional alerts are grouped into the active incident
## Notification types
When configuring escalation steps, you can specify which set of [notification rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders) to use:
- [Default notifications](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/#default-notification-rules): Standard alert notifications as configured in the user’s profile
- [Important notifications](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/#important-notification-rules): High-priority notifications that use more aggressive channels or frequencies
Each user can customize their [notification rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/notify-responders/personal-notification-rules) in the IRM tab of their user.
## Example escalation chains
### Basic notification chain
1. Notify primary on-call person (important)
2. Wait 5 minutes
3. Notify primary again (important)
4. Wait 10 minutes
5. Notify backup on-call person (important)
### Critical system
2. Notify Slack channel #critical-alerts
3. Wait 5 minutes
4. Notify backup on-call person (important)
5. Wait 2 minutes
6. Notify all team members (important)
7. Wait 2 minutes
8. Declare incident with severity “critical” if not acknowledged
### Multi-team escalation with shadow schedule
Interleave notifications from different schedules while maintaining separate tracking for each schedule’s rotation:
1. Notify from on-call schedule (Primary Schedule) — current on-call
2. Wait 5 minutes
3. Notify from on-call schedule (Shadow Schedule) — escalate to shadow/backup team
4. Wait 5 minutes
5. Notify next on-call shift from Schedule (Primary Schedule) — next shift in primary rotation
This pattern allows you to escalate to a backup team while continuing to work through the primary rotation.
## Configure Business hours vs. after hours escalation
Use on-call schedules to route alerts to different responders based on the time of day.
Before creating this escalation chain, you must create two on-call schedules:
**Schedule 1: Business Hours Team**
- Type: Simple schedule or calendar-based schedule
- Coverage: Monday-Friday, 9 AM - 5 PM
- Participants: Team members (rotating or all participants)
**Schedule 2: After Hours Individual**
- Coverage: Monday-Friday, 5 PM - 9 AM (next day), plus all weekend
- Participant: A specific individual
For more information about creating schedules, refer to [Create on-call schedules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules/create-schedules).
### Escalation chain configuration
Create an escalation chain with the following steps:
1. Notify from on-call schedule: “Business Hours Team” (important)
2. Wait 5 minutes (optional but recommended)
3. Notify from on-call schedule: “After Hours Individual” (important)
### How it works
When an escalation step attempts to notify from a schedule that has no one on-call, that step is automatically skipped and the escalation continues to the next step.
- **During business hours (Monday-Friday, 9 AM - 5 PM)**: Step 1 notifies the person who is on-call in the Business Hours Team schedule. If they don’t acknowledge, step 2 waits 5 minutes, then step 3 attempts to notify the After Hours Individual schedule. However, since no one is on-call in that schedule during business hours, step 3 is skipped.
- **After hours (evenings, nights, and weekends)**: Step 1 attempts to notify the Business Hours Team schedule, but since no one is on-call, that step is skipped. Step 2 waits 5 minutes, then step 3 notifies the person who is on-call in the After Hours Individual schedule.
This approach ensures that alerts are routed to the appropriate responder immediately, without waiting for business hours to begin.
### Alternative: Use a single 24/7 schedule
Instead of creating separate schedules, you can create one schedule with different shifts that covers all hours:
- Business hours shifts assigned to team members
- After-hours and weekend shifts assigned to a specific individual
This approach is simpler to manage and scales better as your team grows.
## Best practices
- **Start simple**: Begin with basic notification steps before adding complexity
- **Test thoroughly**: Verify chains with non-production alerts first
- **Document your chains**: Maintain explanations of each chain’s purpose
- **Include wait steps**: Add appropriate delays between notifications
- **Use important notifications sparingly**: Reserve for truly critical alerts
- **Consider time zones**: Create chains respecting global team distribution
## Next steps
- [Configure routing rules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/routing-rules) to direct alerts to your chains
- [Customize alert templates](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/customize-alert-templates) to customize alert appearance
- [Set up on-call schedules](/docs/grafana-cloud/observe-and-act/respond-to-incidents/on-call-schedules) to automate rotation
