title: "Configure alert escalation and routing in Grafana IRM | Grafana Cloud documentation"
description: "Configure alert routing, grouping, escalation chains, labels, and templates per integration in Grafana IRM."
# Configure alert escalation and routing in Grafana IRM
Grafana IRM’s escalation and routing features control which incoming alerts reach which responders, how alerts are grouped, and how they escalate over time. By configuring routes, grouping, escalation chains, labels, and alert templates per integration, you can minimize alert fatigue and make sure critical issues reach the right people quickly.
For a conceptual walkthrough, refer to [Introduction to routing and escalation in Grafana IRM](/docs/grafana-cloud/observe-and-act/respond-to-incidents/introduction/routing-and-escalation). For implementation recommendations, refer to [IRM best practices](/docs/grafana-cloud/observe-and-act/respond-to-incidents/guides/best-practices).
## Key escalation and routing capabilities
- **Routing**: Direct alerts to the correct escalation chain based on payload content or labels.
- **Alert grouping**: Combine related alerts into a single alert group to reduce noise.
- **Escalation chains**: Define the sequence of notifications and actions when an alert group is created.
- **Labels**: Tag and organize alerts for filtering, routing, and incident workflows.
- **Alert templates**: Control how alert content is formatted across channels and how alerts are grouped, resolved, and acknowledged.
## How escalation and routing work together
When an alert payload arrives at an integration, IRM evaluates the integration’s routes top to bottom and selects the first match. The matched route determines which escalation chain handles the alert, and IRM evaluates the integration’s grouping configuration to decide whether the alert joins an existing alert group or creates a new one. The escalation chain then runs its steps until someone acknowledges or resolves the alert group.
## Topics in this section
- [Configure escalation chains in Grafana IRM](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/escalation-chains/)
  Configure escalation chains to define the sequence of notifications and actions Grafana IRM takes when an alert group is created.
- [Configure alert grouping](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/alert-grouping/)
  Configure how Grafana IRM groups related alerts to reduce noise and streamline incident response.
- [Configure routing rules in Grafana IRM](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/routing-rules/)
  Configure routing rules to evaluate incoming alerts against Jinja2 templates and direct them to the correct escalation chain.
- [Labels in Grafana IRM](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/labels/)
  Learn how labels work in Grafana IRM for alert routing, incident categorization, and service dependency tracking.
- [Customize alert templates in Grafana IRM](/docs/grafana-cloud/observe-and-act/respond-to-incidents/escalation-and-routing/customize-alert-templates/)
  Customize Jinja2 alert templates to control how Grafana IRM formats, groups, resolves, and acknowledges alerts.
