This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/monitor-cloud-provider/configure-dashboards-and-views/customize-drilldown-metrics.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/monitor-cloud-provider/configure-dashboards-and-views/customize-drilldown-metrics/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Customize drilldown metrics
Customize which metrics appear when you view individual instances of a cloud provider service. You can select specific metrics, rename and reorder their panels, configure display units, update the legend, configure aggregation, update the existing query or add a custom query, and tailor the view for different instance types.
Before you begin
- Ensure you have Cloud Provider plugin Editor permissions (AWS Editor, Azure Editor, or GCP Editor)
- Navigate to the Configure dashboards and view settings page for the service you want to customize
Drilldown instance views
Drilldown instance views are the charts and graphs that appear when you click into a specific instance from the instances table for a service. For example, if you’re monitoring AWS EC2, each EC2 instance has its own drilldown view showing metrics like CPU utilization, disk operations, and network throughput.
Cloud Provider Observability offers drilldown instance views for the following cloud provider services:
- Amazon Web Services
- AWS Bedrock AgentCore
- AWS DynamoDB
- AWS EC2
- AWS ElastiCache
- AWS Lambda
- AWS RDS
- AWS Route 53
- AWS Route 53 Resolver
- AWS S3
- Microsoft Azure
- Azure Container Apps
- Azure Database for MySQl - Flexible Server
- Azure FrontDoor
- Azure PostgreSQL Flexible Servers
- Azure Virtual Machines
- Azure Virtual Networks
- Google Cloud Platform
- GCP AlloyDB
- GCP Cloud SQL
- GCP Compute Engine
Customize metrics
To select which metrics to include in your drilldown instance views:
- Navigate to the Configure dashboards and view settings page by clicking the Configure button for your service.
- Scroll to the Customize the panels that will be displayed in the drilldown instance view section and click the toggle to enable editing. By default the current instance drilldown metrics are selected.
- Deselect any metrics you want to remove from your drilldown view.
- In the Select metrics area, use the search box to filter available metrics.
- Select the boxes next to the metrics you want to include in your drilldown view.
- Click the Add custom query button to add a custom query to the panels. After you click the button a Custom Query checkbox is selected in your list of metrics and a new custom query panel is added to the panels.
Recommended metrics: Metrics marked as “Recommended” are suggested based on common usage patterns for this service type. These metrics provide a good starting point for monitoring.
Configure panels
After selecting your metrics, you can customize the following panel options:
- update panel titles and order
- edit custom queries
- include multiple queries
- add aggregation
- add legend labels
- select the units used
Each row represents a row in the instance drilldown dashboard, and two panels display on each row.
To customize the panels in your drilldown instance views:
- In the Select the order of the panels on the page section, you’ll see your selected metrics organized into rows.
- Each panel shows:
- The panel title that you can edit.
- A Unit dropdown where you can select the display unit (for example, Bytes, Percent (0-100))
- A Legend text box where you can enter the legend label or template.
- An Aggregation dropdown where you can select the aggregation.
- A drag handle (≡) to reorder panels.
- To update a panel title, click the edit icon and enter the new title.
- To add an aggregation, click the Aggregation dropdown and select your preferred option.
- To update the metrics labels, enter your preferred option into the Legend field. This field accepts templating formatting.
- For Custom Query panels, edit the Query by entering the PromQL query into the Query text box. Click the Test query in Explore button to validate the query is accurate.
- To combine queries, click and drag the handle for the query to move it to another panel and drop it.
- To reorder panels, click and drag the handle to move a panel to a different position or row.
- To change the unit, click the Unit dropdown and select your preferred option.
- Click Save to apply your changes.
Reset to default configuration
To restore the default metric configuration for a service:
- On the Configure dashboards and view settings page, look for the Reset button in the drilldown metrics configuration section.
- Click Reset.
- Disable the Customize the panels that will be displayed in the drilldown instance view toggle.
- Click Save.
Your custom metric selections, ordering, and unit configurations are replaced with the default settings.
Caution
If the Customize the panels that will be displayed in the drilldown instance view toggle is enabled, the default metrics panels display as time series only. To get the statistics or tables included in the default instance page, you must click the Reset button, disable the toggle, and click Save.
Customization scope
Drilldown metrics customizations are shared across your organization or stack. All users see the same configured metrics when viewing instance drilldown pages.
Related topics
Was this page helpful?
