title: "Cloud Provider Observability | Grafana Cloud documentation"
description: "Includes information about using the Cloud Provider app to monitor Azure, AWS, and Google Cloud Platform"
# Cloud Provider Observability
Cloud Provider Observability provides a unified experience for you to manage multiple cloud environments, and streamline your monitoring and troubleshooting.
## Overview
When you monitor and troubleshoot your cloud environment, you need different tools for each provider. This can raise costs and interfere with workflow and efficiency, not to mention a longer time to find and resolve issues. Cloud Provider Observability offers:
- Straightforward setup
- Instantaneous service discovery after setup
- Preconfigured views for your data, including dedicated logs for each provider
- Machine learning-powered predictions for proactive capacity planning and resource optimization
- Seamless scaling
> Note
> Cloud Provider Observability doesn’t support AWS PrivateLink or Azure Private Link.
## Explore
[Azure observability
Easy set-up, granular configuration, and out-of-the-box monitoring for your Azure services.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/azure/)
[AWS observability
A single place to gain better visibility into the health and performance of your AWS infrastructure and large scale applications.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/aws/)
[GCP observability
Easy set-up, granular configuration, and out-of-the-box monitoring for your GCP services.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/gcp/)
[RBAC roles and permissions
Use RBAC to provide user access to Cloud Provider Observability.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/rbac/)
[Configure dashboards and views
Configure dashboards and views for Cloud Provider Observability.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/configure-dashboards-and-views/)
[Analyze cloud resources
Analyze cloud resources with the Knowledge graph.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/knowledge-graph-integration/)
[Analyze alerts and build dashboards
Analyze alerts and build dashboards with Grafana Assistant.](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/grafana-assistant-integration/)
