Use Assistant health checks
Note
Assistant health checks is currently in public preview. Grafana Labs offers limited support, and breaking changes might occur prior to the feature being made generally available.
Automatic health checks are off by default in the Kubernetes Monitoring app. If you already saved a preference in this browser, the app keeps your choice.
When you turn on health checks, Grafana Assistant checks the resource when you open a Cluster, namespace, workload, Pod, container, or Node detail page. It can query Prometheus and Loki in the background. The Assistant health check banner at the top of the page summarizes issues in plain language so you can spot problems without scanning every panel.
A completed health check shows the following details.
  • A health status of Healthy, Degraded, Unhealthy, or Unknown
  • A one-sentence summary of what the Assistant detected
**Assistant health check** notice on a workload detail page
Assistant health check notice on a workload detail page
Investigate with the Assistant health check
To investigate a finding, click the chat icon (Dive deeper in Assistant) on the right side of the health check banner. The Grafana Assistant panel opens and explains what is happening and any next steps. You can ask follow-up questions of Grafana Assistant without re-explaining what you’re looking at, because it receives the context of the page you’re on.
Refresh the check
When automatic checks are on, click Re-run health check (the refresh icon) in the banner after the current check finishes. Use it to confirm a fix or get an updated status without reloading the page.
Manage preference for health checks
In the Kubernetes Monitoring app, use the main menu to open Configuration. Select the Manage app tab and turn Auto-run assistant health checks on or off.
You can also open the Manage app tab from a resource’s detail page.
  • When checks are off, click Enable in Manage app in the Assistant health checks are disabled notice.
  • When checks are on, click Manage assistant preferences in the health check banner.
The app shows the notice or the banner only after it confirms that Grafana Assistant is available and the current Assistant terms have been accepted. Until then, you may see only the Assistant health check heading.
**Manage app** tab where health check preferences can be set
Manage app tab where health check preferences can be set
Turn off automatic checks to avoid their background queries and Assistant usage. You can still ask about your data from any panel that has the Grafana Assistant icon.
The app saves your preference in your browser’s local storage. Other browser profiles keep their own settings.
