This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/intro-kubernetes-monitoring.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/intro-kubernetes-monitoring/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Introduction to Kubernetes Monitoring
Kubernetes environments are complex and change constantly. These moving parts make it hard for teams to prevent issues from causing problems quickly or manage for efficiency. Kubernetes Monitoring gives you the visibility into your infrastructure and tools to fix problems fast and prevent them from happening again.
Reactive response benefits
Reactive problem solving helps teams respond to issues as they appear. Quick issue identification, alerts, data correlation, and other features are built into Kubernetes Monitoring to shorten troubleshooting time.
Priority issues at forefront
The Kubernetes Overview page surfaces what needs triage without making you dig through dashboards. Active issues are grouped into three categories: Availability, Stability, and Infrastructure.
Real-time alerts
Real-time alerts inform you as soon as problems begin. You can jump from alert to runbook for a quick solution, create your own alerts, and copy a built-in alert to customize it.
Logs and metrics correlation
While Kubernetes doesn’t provide a native storage solution for logs, Kubernetes Monitoring uses Grafana Loki as its log aggregator. Since Loki and Prometheus share labels, you can correlate metrics and logs to identify root causes faster without configuring and using multiple technologies.
Proactive management benefits
The features available in Kubernetes Monitoring help you create and implement a proactive strategy with a data-driven approach.
Early error detection
You can use built-in alerting for issues such as CPU throttling to learn which settings need fine tuning. Network bandwidth and saturation is available by object. The time range selector in Kubernetes Monitoring provides a look into the history of an object, which shows patterns such as spikes. Outlier Pod detection can find Pods with CPU usage differences that may lead to issues.
Cost visibility and management
Nodes, load balancers, and Persistent Volumes usually cost extra from your provider, making it important to keep track of them. Auto-scaling architectures let you adapt in real-time to changing demand, but can lead to rapidly rising costs. Kubernetes Monitoring shows these costs so you can decide what costs can be reduced. With cost prediction, you can view potential, future costs.
Resource efficiency management
You can reduce the risk of an unstable infrastructure by monitoring resource usage to:
- Ensure that there are enough allocated resources and decrease the risk of Pod eviction, as well as prevent declining performance of your microservices and applications.
- Eliminate unused or stranded resources.
Then you can make scheduling adjustments, such as setting affinities and anti-affinities, to improve performance and reliability.
Resource usage forecasts
By looking at a prediction of resource usage, you can better forecast for a project or activity.
What is out of the box
The out-of-the-box features that are part of Kubernetes Monitoring include:
- The ability to explore and troubleshoot your Kubernetes infrastructure in a single interface
- A built-in deployment process using Helm chart that includes the option to use eBPF technology to automatically instrument applications with Grafana Beyla. This collects telemetry data for applications on the Cluster without adding SDKs.
- The Kubernetes Overview home page, which shows issues that should be triaged
- Efficiency data throughout the app for checking and improving resource usage
- Cost data globally available for analyzing and managing your infrastructure costs and potential savings
- Alerts specific to Kubernetes Monitoring. You can respond to and troubleshoot alerts, and select built-in alerting rules to view and copy for customization.
- Energy usage data provided by Kepler
- Immediate, in-context access to other Grafana Cloud applications for quicker analysis and resolution, including:
- Recording rules to increase the speed of queries and the evaluation of alerting rules
- Predictions for CPU and memory usage, powered by machine learning
- Selected set of metrics to assist in providing only the metrics you need
Get started
There are two recommended ways to get started:
- Configure with Instrumentation Hub, currently in public preview, when you want to get started quickly. It installs the Alloy collector, performs zero-instrumentation on your code with Beyla, activates the Kubernetes Monitoring product, and builds the Knowledge Graph. You can later refine your settings with the Helm chart.
- Configure with the Grafana Kubernetes Monitoring Helm chart when you want refined control over your initial installation. There’s no manual set up, and the chart includes automatic updates for all components that it installs.
Other configuration methods
There are other available methods you can use to configure Kubernetes Monitoring for your infrastructure data.
To configure data about an application running in Kubernetes, refer to Application metrics.
Was this page helpful?
