Monitor your infrastructure
Monitor your infrastructure with the centralized observability applications Kubernetes Monitoring and Cloud Provider Observability. Get started quickly collecting and sending your data to Grafana Cloud with a Grafana integration.
Overview
Cloud Provider Observability provides you with access to a fast, scalable backend that you don’t have to manage. Instead of running your own exporter to pull AWS cloud data to a local observability system, you can use Grafana Cloud to keep your data in the cloud, with minimal setup overhead. You can monitor AWS, Azure, and GCP using a centralized experience.
Kubernetes Monitoring offers one platform for comprehensive monitoring and visibility. As you analyze the health of your Clusters, Pods, and containers, and perform troubleshooting, you remain within the same Kubernetes Monitoring app. This makes analysis and troubleshooting more efficient and effective, reducing mean time to resolution.
Configuring, installing, connecting, and maintaining components for a Prometheus-based observability stack often involve significant domain knowledge, and can be tedious and time consuming. Grafana integrations offer you a fast and easy way to get started with minimal effort. Integrations are built with a curated set of default metrics and preconfigured Grafana dashboards, driven by Grafana Alloy deployed into your environment.
Guidance and help
Not sure where to go?
Answer a few questions and Grot will show you a helpful next step.
Explore
