This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data/error-awareness.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data/error-awareness/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Errors overview
The Errors page displays errors reported using the Faro Web SDK. You can search, filter, and sort errors. Clicking an error displays more context on the error.
Filter, search, and sort
At the top of the errors list, you can:
- Filter errors by app to see errors produced by a specific application.
- Search errors by error type and message.
- Change the sort order.
Error context
Click an error to view additional context including the timestamp, metadata like session id and browser info, and any stack traces for the error.
If there are multiple collected instances of the error, you can click the newer and older buttons to view each instance.
Was this page helpful?
