This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data/custom-tabs.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data/custom-tabs/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Custom tabs in Frontend Observability
Caution
Custom tabs are an experimental feature. Functionality may change as we gather feedback.
Custom tabs let you surface any Grafana dashboard as a tab directly inside a Frontend Observability application. Use them to bring team-specific dashboards such as custom performance views, business metrics, or RUM reports into context without navigating away.
After you configure them, custom tabs appear alongside the built-in navigation tabs (Sessions, Errors, Performance, and so on) for every team member with access to the application.
Before you begin
- You must have Editor or Admin organization role, or the Frontend Observability Editor or Frontend Observability Admin plugin role, to add a custom tab.
- To delete a custom tab, you must have the Grafana Admin organization role. Plugin roles, including Frontend Observability Admin, don’t currently grant delete permission for custom tabs.
Add a custom tab
- Open Frontend Observability in Grafana Cloud and select your application.
- Navigate to Settings.
- Under Custom tabs, enter a Tab name and select the target Grafana dashboard by name.
- Click Create tab. The tab appears in the application navigation after an automatic refresh.
Delete a custom tab
Only users with the Grafana Admin organization role can delete custom tabs.
- Open Frontend Observability and select your application.
- Navigate to Settings > Custom tabs.
- Click the delete icon next to the tab you want to remove.
- Confirm the deletion.
Related documentation
Was this page helpful?
