This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/visualize-data/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Visualize and explore Frontend Observability data
After instrumenting and configuring your application, use the visualization and exploration features in Frontend Observability to analyze user behavior, diagnose performance issues, and identify errors.
Explore user data
Sessions
- Sessions - Analyze individual user sessions and journeys
- User actions - Review user interactions and behavior patterns
- Geolocation insights - Understand where your users are located
- Geolocation visualizations - Analyze geographic distribution of traffic
Performance analysis
- Performance - Monitor application performance metrics
- HTTP insights - Analyze API calls and network requests
Error monitoring
- Errors overview - View and filter application errors
- Errors - Analyze error patterns and troubleshoot issues
Custom tabs
- Custom tabs - Surface Grafana dashboards as tabs inside your application (Experimental)
Correlate with backend data
Frontend Observability integrates with Application Observability to provide end-to-end visibility:
- Correlate frontend errors with backend traces
- Track requests from browser through backend services
- Identify performance bottlenecks across the full stack
Before you begin
Make sure you have:
- Instrumented your application with the Faro Web SDK
- Data flowing into Frontend Observability
Next steps
After exploring your data:
- Create alerts to get notified about issues
- Integrate with other tools to enhance observability
Was this page helpful?
