title: "Data privacy in Session Replay | Grafana Cloud documentation"
description: "Learn how Session Replay handles data privacy, who can access recordings, and how to configure Session Replay to comply with regulations like GDPR, ePrivacy, and CCPA"
# Data privacy in Session Replay
> Note
> Session Replay is currently in [private preview](/docs/release-life-cycle/). Grafana Labs offers support on a best-effort basis, and breaking changes might occur prior to the feature being made generally available.
Understand how Session Replay handles data privacy, who can access session recordings, and how to configure Session Replay to help meet your organization’s privacy requirements and comply with regulations such as GDPR, ePrivacy, and CCPA.
Session Replay is built on the Faro Web SDK and shares its session lifecycle, storage, and transport. Everything documented in [Data privacy in Frontend Observability](/docs/grafana-cloud/monitor-applications/frontend-observability/settings-and-policies/data-privacy/) and [Comply with CNIL requirements for Frontend Observability](/docs/grafana-cloud/monitor-applications/frontend-observability/settings-and-policies/cnil-compliance/) applies to Session Replay as well. This page describes what Session Replay adds on top of Faro: the additional data captured for recording, where those recordings are sent, who can access them, and the additional privacy considerations that come with recording user sessions.
> Caution
> By enabling Session Replay for your Grafana Cloud stack and instrumenting it in your application, you assume full responsibility for disclosing session recording to your end users and obtaining any consent required by applicable law, such as ePrivacy, GDPR, and CCPA. Grafana Labs doesn’t display a consent banner or otherwise obtain end-user consent on your behalf.
## What data Session Replay sends
Session Replay sends a structured representation of the browser session, not a video or pixel recording. It sends:
- **DOM snapshots and mutations**: The initial structure of the page when recording starts, plus incremental changes such as added or removed nodes and attribute and text changes. This includes rendered text content, subject to any masking that you apply.
- **User interactions**: Pointer movements, clicks, scrolls, viewport resizes, and input events. Input values are masked by default.
- **Page URLs and navigation events**: Full URLs, including path and query string. Personally identifiable information (PII) in URLs is not masked by default.
- **Session metadata**: Session ID, recording ID, app name, timestamps, and stack and organization identifiers used to correlate the recording with your other Faro telemetry.
Session Replay doesn’t capture:
- Video or audio content.
- Network request and response bodies, which are handled by separate Faro instrumentation.
- Console logs, which are handled by separate Faro instrumentation.
- Browser extensions or bookmarks.
### Other data that might be recorded
Besides form inputs, which are masked by default, recordings can include:
- **Page URLs**: Including query strings, which might contain identifiers or user-specific parameters such as tokens, session IDs, or user IDs. URLs aren’t masked by default. Before you enable Session Replay, review your application’s URL structure and avoid placing sensitive values in query strings.
- **Rendered text**: All visible text on the page is masked by default through `maskTextSelector: '*'`. If you relax this setting, page copy, labels, and other text appear in replays.
- **Input placeholder text**: The `placeholder` attribute on form fields isn’t masked. Avoid using real personal data such as example email addresses or names as placeholders.
- **DOM structure**: The full structure of the page as the browser renders it, which might reflect logged-in state, feature flags, or account-specific content.
- **Canvas content, cross-origin iframes, and inline images**: Not captured by default. Each requires explicit opt-in through configuration.
Bookmarks and media content such as audio and video are not captured.
## Prevent sensitive data from being recorded
You can control what Session Replay records using the following mechanisms:
- **Default masking**: All input values and text content are masked client-side, before anything leaves the browser. No configuration is required.
- **SDK configuration**: Use the `maskTextSelector`, `blockSelector`, `maskInputOptions`, and `ignoreSelector` options to tighten or customize masking. Refer to [Privacy and masking options](/docs/grafana-cloud/monitor-applications/frontend-observability/session-replay/instrument/#privacy-and-masking-options) for the full reference.
- **`beforeSend` hook**: Use the `beforeSend` hook to filter or transform events programmatically before they’re sent. Return `null` to drop an event entirely.
- **Disable Session Replay**: Session Replay is off by default. It must be explicitly enabled per Grafana Cloud stack and then instrumented in your application. Refer to [Turn Session Replay on and off](#turn-session-replay-on-and-off).
## Who can access session recordings
Session Replay events are sent to the Grafana Cloud stack you configure in the Faro Web SDK. Access to recordings is controlled the same way as access to any other data in that stack:
- **Users in your organization**: Access is controlled through Grafana authentication, team membership, and role-based access control (RBAC). For details on restricting recording access to specific users or teams, refer to [Session Replay role-based access control](/docs/grafana-cloud/monitor-applications/frontend-observability/session-replay/rbac/).
- **Grafana Labs staff**: Can access recordings through internal administrative tooling for the purposes of operating and supporting the service, subject to Grafana Labs’ security and privacy practices.
Session Replay data isn’t shared with third parties and isn’t combined with marketing or advertising systems.
## Data retention
Session recordings are retained for 30 days, aligned with the default retention for Grafana Cloud logs and traces. Retention isn’t currently configurable for Session Replay.
## Legal basis and consent
Session Replay operates as a client-side instrumentation inside your own web application, so the legal basis for recording end-user sessions, and any consent required, is your responsibility.
> Caution
> This section is not legal advice. Data protection laws change frequently and vary by jurisdiction. Consult your legal team for guidance specific to your users and use case.
### Attest to compliance
By enabling Session Replay for your Grafana Cloud stack and instrumenting it in your application, you attest that:
- You have identified the legal basis, such as consent or legitimate interests, for recording end-user sessions in the jurisdictions where your application is used.
- You have informed your end users about session recording in your privacy notice or consent banner.
- You have complied with applicable law and obtained any consent required before implementing Session Replay and before recording begins.
- You have configured masking, sampling, and other Session Replay controls to minimize the data recorded to what’s necessary for your purpose.
### Permitted and prohibited uses
Session Replay is intended for internal operational purposes only:
- **Debugging**: Understanding user interface (UI) issues that aren’t visible or are only partially visible through backend telemetry.
- **Incident response**: Investigating customer-reported or internally detected UI problems.
Don’t use Session Replay for purposes prohibited by applicable law, such as profiling for advertising, tracking end users, or any use that violates your end users’ data protection rights.
### Consent requirements by jurisdiction
Different jurisdictions have different requirements for tracking technologies like Session Replay. The following is a non-exhaustive overview and not intended as legal advice. Consult with your legal counsel on your implementation compliance obligations.
- **Opt-in jurisdictions**: In jurisdictions that require opt-in consent, such as the European Economic Area, Switzerland, the United Kingdom, and South Korea, Session Replay must be off by default and only turned on after the end user consents, such as through a cookie banner. It must be turned off again if the end user withdraws consent.
- **Opt-out jurisdictions**: In jurisdictions that allow opt-out models, Session Replay can be on by default, but end users must have the ability to opt out at any time.
- **All jurisdictions**: When you present Session Replay in a cookie banner or consent management platform (CMP), categorize it as an analytics tracker.
- **Opt-out controls**: Ensure you have a method for users to opt out of tracking, such as a Privacy Choices link in the footer of your webpage.
## Turn Session Replay on and off
Turning Session Replay on or off is a two-layer decision: the stack-level setting controls whether Grafana Cloud accepts Session Replay data at all, and the SDK instrumentation controls whether your application produces any.
### Stack-level (Grafana Cloud)
Session Replay is disabled by default. It must be enabled per Grafana Cloud stack.
- **To turn it on for a stack**: [Open a Grafana Support ticket](/docs/grafana-cloud/security-and-account-management/support/) listing the Grafana Cloud stacks you’d like to enable Session Replay on.
- **To turn it off for a stack**: [Open a Grafana Support ticket](/docs/grafana-cloud/security-and-account-management/support/) asking to disable Session Replay for the listed stacks. Existing recordings remain accessible for the remainder of the 30-day retention window and are then automatically deleted.
### Application-level (SDK)
After Session Replay is enabled for your stack, recordings are only produced by applications that include the `@grafana/faro-instrumentation-replay` package in their Faro Web SDK configuration.
- **To turn it on for an application**: Install the `@grafana/faro-instrumentation-replay` package and pass a `ReplayInstrumentation` instance to `initializeFaro`. Refer to [Instrument Session Replay](/docs/grafana-cloud/monitor-applications/frontend-observability/session-replay/instrument/).
- **To turn it off for an application**: Remove `ReplayInstrumentation` from the `instrumentations` array in your `initializeFaro` call and redeploy your application. Sessions started after the redeploy aren’t recorded. Recordings from previous sessions follow the 30-day retention window.
## Integrate Session Replay with your cookie banner
If applicable law requires you to obtain user consent before recording sessions, integrate Session Replay with your existing cookie banner or consent management platform (CMP).
> Note
> Faro, and therefore Session Replay, uses browser web storage (`sessionStorage` or `localStorage`) rather than HTTP cookies. However, ePrivacy and similar laws may treat all client-side identifiers the same as cookies for consent purposes. Present Session Replay to your end users through your cookie banner even though it doesn’t technically set a cookie.
### Categorize Session Replay in your banner
Categorize Session Replay as an **analytics** tracker in your cookie banner. Describe it accurately based on [What data Session Replay sends](#what-data-session-replay-sends). For example: “We record a structured playback of your interactions with this application, such as pointer movements, clicks, and page navigations, so we can debug UI issues and investigate issues with our website and systems.”
### Load Session Replay only after consent
In jurisdictions that require opt-in consent, conditionally initialize Faro with Session Replay only after the end user consents. This is the same pattern documented for Frontend Observability in [CNIL compliance](/docs/grafana-cloud/monitor-applications/frontend-observability/settings-and-policies/cnil-compliance/#implement-user-consent-before-data-collection):
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
if (userHasConsentedToAnalytics()) {
  const { getWebInstrumentations, initializeFaro } = await import('@grafana/faro-web-sdk');
  const { ReplayInstrumentation } = await import('@grafana/faro-instrumentation-replay');
  initializeFaro({
    url: 'YOUR_GRAFANA_CLOUD_URL',
    app: {
      version: '1.0.0',
    instrumentations: [...getWebInstrumentations(), new ReplayInstrumentation()],
Replace `userHasConsentedToAnalytics()` with the API from your consent management platform or your own consent logic.
### Stop Session Replay when consent is withdrawn
The same guidance as Faro applies: reload the page so the Faro Web SDK—including Session Replay—isn’t initialized again. Existing recordings in Grafana Cloud follow the 30-day retention window and are then automatically deleted. Refer to [Handle consent withdrawal](/docs/grafana-cloud/monitor-applications/frontend-observability/settings-and-policies/cnil-compliance/#handle-consent-withdrawal) in the Faro CNIL compliance guide for details.
