This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/sourcemap-uploads.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/sourcemap-uploads/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Source map uploads
Upload source maps privately to Grafana Cloud to get readable error messages and stack traces from your minified JavaScript applications.
Source maps connect minified production code to original source files. Frontend Observability uses source maps to deobfuscate JavaScript stack traces, giving you clear error messages for debugging without exposing your source code publicly.
Source maps and application security
JavaScript bundlers remove file names, function names, and code positions during production builds to reduce file size. Without source maps, error traces show meaningless character strings, making debugging impossible.
Hosting source maps publicly creates security risks. Users can download public source maps and reconstruct your codebase, exposing proprietary logic.
Grafana Cloud Frontend Observability solves this with private source map uploads. You upload source maps securely to Grafana Cloud using Faro JavaScript bundler plugins. These plugins work with the Faro Web SDK to provide deobfuscated error traces in Frontend Observability.
Before you begin
Ensure you have the following:
- A JavaScript application instrumented with the Faro Web SDK
- Telemetry data sending to a Faro Collector endpoint in Grafana Cloud
- Access to Grafana Cloud Frontend Observability
- An API key. Refer to the documentation about your preferred upload method to obtain an API key.
If you haven’t set up Frontend Observability yet, refer to the JavaScript quickstart guide.
Note
Faro JavaScript bundler plugins support client-side rendered applications only. Server-side rendering isn’t supported.
You can upload source maps using these methods:
- Bundler plugins: Configure Webpack or Rollup/Vite plugins to automatically generate and upload source maps during builds. Refer to Upload with bundlers.
- CLI tool: Use the Faro CLI to upload source maps separately from your build process. Refer to Upload with the CLI.
- cURL: Make direct API requests for constrained environments. Refer to Upload with cURL.
Was this page helpful?
