This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/filter-bots.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/filter-bots/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Filter out bots from collecting data for Frontend Observability
Bots can skew Frontend Observability data and incur cost through additional volume and user-sessions produced. Bots can be filtered out from Frontend Observability data by configuring the RUM library to only collect data from real users.
Filter bots by user agent
The following example matches the user-agent against a list of commonly known user agents used by bots.
Filtering works as follows:
- If the user agent matches the regular expression, the sampling factor is set to 0, which means that no data is collected
- If the user agent doesn’t match the regular expression, the sampling factor is set to 1, which means that all data is collected, adjust the sampling factor for real users as needed
// regular expression capturing unwanted user-agents
let bots =
'(googlebot/|bot|Googlebot-Mobile|Googlebot-Image|Google favicon|Mediapartners-Google|bingbot|slurp|java|wget|curl|Commons-HttpClient|Python-urllib|libwww|httpunit|nutch|phpcrawl|msnbot|jyxobot|FAST-WebCrawler|FAST Enterprise Crawler|biglotron|teoma|convera|seekbot|gigablast|exabot|ngbot|ia_archiver|GingerCrawler|webmon |httrack|webcrawler|grub.org|UsineNouvelleCrawler|antibot|netresearchserver|speedy|fluffy|bibnum.bnf|findlink|msrbot|panscient|yacybot|AISearchBot|IOI|ips-agent|tagoobot|MJ12bot|dotbot|woriobot|yanga|buzzbot|mlbot|yandexbot|purebot|Linguee Bot|Voyager|CyberPatrol|voilabot|baiduspider|citeseerxbot|spbot|twengabot|postrank|turnitinbot|scribdbot|page2rss|sitebot|linkdex|Adidxbot|blekkobot|ezooms|dotbot|Mail.RU_Bot|discobot|heritrix|findthatfile|europarchive.org|NerdByNature.Bot|sistrix crawler|ahrefsbot|Aboundex|domaincrawler|wbsearchbot|summify|ccbot|edisterbot|seznambot|ec2linkfinder|gslfbot|aihitbot|intelium_bot|facebookexternalhit|yeti|RetrevoPageAnalyzer|lb-spider|sogou|lssbot|careerbot|wotbox|wocbot|ichiro|DuckDuckBot|lssrocketcrawler|drupact|webcompanycrawler|acoonbot|openindexspider|gnam gnam spider|web-archive-net.com.bot|backlinkcrawler|coccoc|integromedb|content crawler spider|toplistbot|seokicks-robot|it2media-domain-crawler|ip-web-crawler.com|siteexplorer.info|elisabot|proximic|changedetection|blexbot|arabot|WeSEE:Search|niki-bot|CrystalSemanticsBot|rogerbot|360Spider|psbot|InterfaxScanBot|Lipperhey SEO Service|CC Metadata Scaper|g00g1e.net|GrapeshotCrawler|urlappendbot|brainobot|fr-crawler|binlar|SimpleCrawler|Livelapbot|Twitterbot|cXensebot|smtbot|bnf.fr_bot|A6-Indexer|ADmantX|Facebot|Twitterbot|OrangeBot|memorybot|AdvBot|MegaIndex|SemanticScholarBot|ltx71|nerdybot|xovibot|BUbiNG|Qwantify|archive.org_bot|Applebot|TweetmemeBot|crawler4j|findxbot|SemrushBot|yoozBot|lipperhey|y!j-asr|Domain Re-Animator Bot|AddThis)';
let botsRegex = new RegExp(bots, 'i');
// set a sampling factor of 0 for bots
let samplingFactor = botsRegex.test(navigator.userAgent) ? 0 : 1;
// initialize the RUM library as usual, but pass the sampling factor
initializeFaro({
// ... usual configuration
sessionTracking: {
enabled: true,
persistent: true,
// apply the sampling factor
samplingRate: samplingFactor,
});For more information on sampling, refer to the Faro Web SDK documentation on sampling.
Was this page helpful?
