This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/csp-violation-tracking.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/frontend-observability/configure/csp-violation-tracking/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Track CSP violations
Faro provides a CSP instrumentation that automatically tracks Content Security Policy (CSP) violations using the browser’s native securitypolicyviolation event.
CSP violations typically indicate that a page attempted to load a disallowed resource or executed inline code that violates your policy. Capturing these violations helps you identify potential security misconfigurations or malicious content injection.
The CSP instrumentation listens for browser-emitted securitypolicyviolation events and sends them as structured Faro events to your collector.
What is collected
When a CSP violation occurs, the following properties are captured and sent as part of the securitypolicyviolation event:
blockedURI: The URI that was blocked by the policydocumentURI: The URI of the document where the violation occurredsourceFile: The file that contained the violating codestatusCode: The HTTP status code of the resourcelineNumber,columnNumber: The line and column number in the source filedisposition: Whether the policy was enforced or reported onlyeffectiveDirective: The effective directive that was violatedviolatedDirective: The original directive that triggered the violationoriginalPolicy: The full policy as delivered by the serverreferrer: The document referrer, if anysample: A snippet of the violating code, if available
The CSP instrumentation tags these events with the current session and page metadata, and then stores them as events in Loki.
Enable the CSP instrumentation
To use the CSP instrumentation, install and add it to your Faro initialization configuration.
npm install @grafana/faro-web-sdkThe CSP violations instrumentation is automatically included with the standard web instrumentations when using getWebInstrumentations().
import { initializeFaro, getWebInstrumentations } from '@grafana/faro-web-sdk';
initializeFaro({
url: 'https://my-collector-url/collect/{app-key}',
app: {
instrumentations: [...getWebInstrumentations(/* ... */)],
});That’s it. No further configuration is needed. As long as your page has a CSP policy in place, violations are tracked automatically.
Note
This instrumentation uses the browser’s built-in
securitypolicyviolationevent. If your CSP prevents loading the SDK itself, violations may not be captured.
Tips
- Use report-only mode during development to monitor violations without enforcing the policy.
- Since Faro does not currently support a report-to ingestion endpoint, this instrumentation is the recommended way to monitor CSP violations through Faro.
- You can test your CSP setup using online tools like CSP Evaluator.
- Combine CSP tracking with session and release metadata in Faro to trace violations to specific deployments.
Disabling the CSP instrumentation
You can disable the CSP violations instrumentation by excluding it from the web instrumentations.
initializeFaro({
app: {
instrumentations: [
...getWebInstrumentations({
enableContentSecurityPolicyInstrumentation: false,
});Was this page helpful?
