title: "Monitor multiple databases | Database Observability documentation"
description: "Configure Database Observability to monitor multiple database instances with deployment patterns and labeling strategies."
# Monitor multiple databases
As your infrastructure grows beyond a single database, you need to monitor multiple database instances. This guide covers deployment patterns, configuration strategies, and labeling best practices for managing multiple databases with Database Observability.
## Before you begin
Complete setup for at least one database:
- [Set up MySQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/mysql/)
- [Set up PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/postgres/)
You also need:
- Grafana Alloy running and connected to Grafana Cloud
- Grafana Cloud remote write credentials for Prometheus and Loki
## Choose a deployment pattern
Choose a deployment pattern based on your infrastructure and scale requirements.
### Single Alloy instance
One Alloy instance monitors all databases.
text ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```text
│  Grafana Alloy  │
│    │ MySQL 1 │──┼────▶│ mysql-1  │
│    │ MySQL 2 │──┼────▶│ mysql-2  │
│    │ PG 1    │──┼────▶│ postgres │
**Advantages:**
- Simple to deploy and manage
- Single configuration file
- Lower resource overhead
**Disadvantages:**
- Single point of failure
- Network latency to remote databases
- Scaling limits
**Best for:**
- Small to medium deployments (&lt; 20 databases)
- Databases in same network/region
- Development and staging environments
### Distributed Alloy instances
Deploy Alloy alongside each database or group of databases.
```text
│  Region A  │    │  Region B  │    │  Region C  │
│ │ Alloy  │ │    │ │ Alloy  │ │    │ │ Alloy  │ │
│ │ MySQL  │ │    │ │ PG     │ │    │ │ MySQL  │ │
**Advantages:**
- High availability (one Alloy failure doesn’t affect others)
- Low latency to local databases
- Scales horizontally
- Aligns with infrastructure boundaries
**Disadvantages:**
- More instances to manage
- Distributed configuration
- Higher total resource usage
**Best for:**
- Large deployments (20+ databases)
- Multi-region infrastructure
- Production environments requiring high availability
## Configure multiple databases
### Single Alloy with multiple databases
Add a component block for each database:
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
// Database 1: MySQL orders
local.file "mysql_orders_secret" {
  filename  = "/var/lib/alloy/mysql_orders_dsn"
  is_secret = true
prometheus.exporter.mysql "orders" {
  data_source_name  = local.file.mysql_orders_secret.content
  enable_collectors = ["perf_schema.eventsstatements"]
database_observability.mysql "orders" {
  forward_to       = [loki.relabel.orders.receiver]
  targets          = prometheus.exporter.mysql.orders.targets
loki.relabel "orders" {
  forward_to = [loki.write.default.receiver]
  rule {
    target_label = "instance"
    replacement  = "orders.db.example.com:3306"
  rule {
    target_label = "job"
    replacement  = "integrations/db-o11y"
  rule {
    target_label = "app"
    replacement  = "order-service"
discovery.relabel "orders" {
  targets = database_observability.mysql.orders.targets
  rule {
  rule {
  rule {
prometheus.scrape "orders" {
  targets    = discovery.relabel.orders.output
  forward_to = [prometheus.remote_write.default.receiver]
// Database 2: PostgreSQL users
local.file "pg_users_secret" {
  filename  = "/var/lib/alloy/pg_users_dsn"
  is_secret = true
prometheus.exporter.postgres "users" {
  data_source_names  = [local.file.pg_users_secret.content]
  enabled_collectors = ["stat_statements"]
  autodiscovery {
    enabled = true
database_observability.postgres "users" {
  data_source_name = local.file.pg_users_secret.content
  forward_to       = [loki.relabel.users.receiver]
  targets          = prometheus.exporter.postgres.users.targets
loki.relabel "users" {
  rule {
    replacement  = "users.db.example.com:5432"
  rule {
  rule {
    replacement  = "user-service"
discovery.relabel "users" {
  targets = database_observability.postgres.users.targets
  rule {
  rule {
  rule {
prometheus.scrape "users" {
  targets    = discovery.relabel.users.output
// Shared outputs
prometheus.remote_write "default" {
  endpoint {
    url = "https://prometheus-prod-01-us-east-0.grafana.net/api/prom/push"
    basic_auth {
      username = sys.env("GRAFANA_CLOUD_PROMETHEUS_USERNAME")
      password = sys.env("GRAFANA_CLOUD_API_KEY")
loki.write "default" {
  endpoint {
    url = "https://logs-prod-us-east-0.grafana.net/loki/api/v1/push"
    basic_auth {
      username = sys.env("GRAFANA_CLOUD_LOKI_USERNAME")
### Mixed database types
You can monitor both MySQL and PostgreSQL from the same Alloy instance:
```alloy
// MySQL databases
database_observability.mysql "mysql_1" { /* ... */ }
database_observability.mysql "mysql_2" { /* ... */ }
// PostgreSQL databases
database_observability.postgres "pg_1" { /* ... */ }
database_observability.postgres "pg_2" { /* ... */ }
Each component is independent and can have different configurations.
## Choose a labeling strategy
Consistent labels help you filter and organize databases in Database Observability dashboards.
### Required labels
These labels must be set correctly for Database Observability to function:
Expand table
| Label      | Requirement                    | Example                      |
| `instance` | Unique per database            | `orders.db.example.com:3306` |
| `job`      | Must be `integrations/db-o11y` | `integrations/db-o11y`       |
### Recommended labels
Add these labels to organize and filter databases:
Expand table
| Label         | Purpose           | Example values                        |
| `app`         | Application name  | `order-service`, `user-api`           |
| `team`        | Owning team       | `checkout`, `platform`                |
| `environment` | Deployment stage  | `production`, `staging`, `dev`        |
| `region`      | Geographic region | `us-east-1`, `eu-west-1`              |
| `cluster`     | Database cluster  | `orders-primary`, `orders-replica`    |
| `provider`    | Cloud provider    | `aws`, `gcp`, `azure`, `self-managed` |
### Label consistency
Labels must match between `loki.relabel` and `discovery.relabel`:
```alloy
// Logs labels
loki.relabel "mydb" {
  rule {
    replacement  = "mydb.example.com:3306"
  rule {
    target_label = "environment"
    replacement  = "production"
// Metrics labels - must match!
discovery.relabel "mydb" {
  rule {
    replacement  = "mydb.example.com:3306"  // Same value
  rule {
    replacement  = "production"  // Same value
For complete label guidance including best practices, environment variables, and troubleshooting, refer to the [Labels reference](/docs/grafana-cloud/monitor-applications/database-observability/reference/labels/).
## Add cloud provider integrations
Add a `cloud_provider` block in Grafana Alloy to correlate database telemetry with infrastructure metrics from AWS CloudWatch, Azure Monitor, or Google Cloud Monitoring. The block also enables the Cloud Provider Observability integration in Database Observability.
Configure Alloy using the platform setup guides:
- [AWS RDS MySQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/mysql/rds/), [AWS Aurora MySQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/mysql/aurora/), [AWS RDS PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/postgres/rds/), [AWS Aurora PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/postgres/aurora/)
- [Azure Database for MySQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/mysql/azure/), [Azure Database for PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/postgres/azure/)
- [Google Cloud SQL MySQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/mysql/cloudsql/), [Google Cloud SQL PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/set-up/postgres/cloudsql/)
The following examples show the `cloud_provider` block for each platform.
### AWS RDS / Aurora
```alloy
database_observability.mysql "rds" {
  data_source_name = local.file.rds_secret.content
  forward_to       = [loki.relabel.rds.receiver]
  targets          = prometheus.exporter.mysql.rds.targets
  cloud_provider {
    aws {
      arn = "arn:aws:rds:us-east-1:123456789012:db:mydb"
### Azure Database
```alloy
database_observability.postgres "azure" {
  data_source_name = local.file.azure_secret.content
  forward_to       = [loki.relabel.azure.receiver]
  targets          = prometheus.exporter.postgres.azure.targets
  cloud_provider {
    azure {
      subscription_id = "your-subscription-id"
      resource_group  = "your-resource-group"
      server_name     = "your-server-name"
### Google Cloud SQL
```alloy
database_observability.mysql "cloudsql" {
  data_source_name = local.file.cloudsql_secret.content
  forward_to       = [loki.relabel.cloudsql.receiver]
  targets          = prometheus.exporter.mysql.cloudsql.targets
  cloud_provider {
    gcp {
      connection_name = "my-project:us-central1:my-db"
The `connection_name` value is the Cloud SQL instance connection name in `project:region:instance` format. You can find it in the Google Cloud console on the instance details page.
The `cloud_provider` block also enables integration with [Cloud Provider Observability](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/). For navigation between query performance and cloud infrastructure metrics, refer to **Access Database Observability** in the Cloud Provider Observability documentation for your platform:
- [Preconfigured dashboards and alerts](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/aws/cloudwatch-metrics/metric-dashboards/#access-database-observability)
- [Preconfigured dashboards and alerts for Azure metrics](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/azure/azure-alerts/#access-database-observability)
- [Google Cloud Platform observability](/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/gcp/#access-database-observability)
## Troubleshoot multi-database setups
When databases don’t appear or data doesn’t correlate correctly, start with these multi-database-specific checks:
1. Verify that every database has a unique `instance` label.
2. Confirm the `instance` value matches exactly between the `loki.relabel` and `discovery.relabel` blocks for the same database.
3. Check that `job` is exactly `integrations/db-o11y` on every component.
For detailed troubleshooting steps, refer to the dedicated guides:
- [Troubleshoot Alloy](/docs/grafana-cloud/monitor-applications/database-observability/troubleshoot/alloy/)
- [Troubleshoot MySQL](/docs/grafana-cloud/monitor-applications/database-observability/troubleshoot/mysql/)
- [Troubleshoot PostgreSQL](/docs/grafana-cloud/monitor-applications/database-observability/troubleshoot/postgres/)
## Related documentation
- [Tune Alloy collection](/docs/grafana-cloud/monitor-applications/database-observability/configure/tune-alloy-collection/): Optimize per-database settings
- [Labels reference](/docs/grafana-cloud/monitor-applications/database-observability/reference/labels/): Complete label documentation
- [Verify telemetry status](/docs/grafana-cloud/monitor-applications/database-observability/configure/verify-telemetry-status/): Validate configuration health per database
