This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability/integrate-rum.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability/integrate-rum/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Integrate Application Observability with Frontend Observability
You can integrate Application Performance Monitoring (APM) with Real User Monitoring (RUM) and include services that are monitored with Grafana Cloud Frontend Observability in the Service Map and Service Graph.
Generate metrics for web applications and mobile devices
- Navigate to Observability > Configuration > Traces metrics generation in your Grafana Cloud instance.
- Select the Filter rules tab.
- Edit the span kind rule to add Client and Producer. Keep Server and Consumer selected so that metrics continue to be generated for your backend services.
For more information, refer to the Configure Traces metrics generation documentation.
Navigate between frontend and backend monitoring seamlessly
After generating metrics for web applications and mobile devices, you can:
- easily navigate between Application Observability Services and Real User Monitoring services.
- navigate between traces in Application Observability and user sessions in Frontend Observability.
For more details, refer to the Frontend Observability documentation on the APM integration.
Was this page helpful?
