title: "Quality report | Grafana Cloud documentation"
description: "Review instrumentation quality for a service with actionable checks and remediation guidance."
# Quality report
The Quality report tab assesses how well a service is instrumented and provides actionable recommendations to improve data coverage. A well-instrumented service provides richer insights, more accurate baselines, and better root cause analysis.
## Quality score
The top of the report shows an overall quality rating (for example, “Good instrumentation” at 66%) with a progress bar. The rating reflects how many checks the service passes.
## Failed checks
Failed checks identify gaps in your telemetry data. Each failed check includes:
- A **Recommended** badge indicating it’s an improvement opportunity.
- A description explaining what’s missing and why it matters.
- A **Documentation** link to the relevant section on this page.
- An **Explore query** link (where applicable) to investigate the data directly.
## Passed checks
Passed checks confirm that specific instrumentation requirements are met.
## Check reference
The following sections describe each quality check and how to resolve it.
### Add the missing service.namespace attribute
Application Observability uses the `service.namespace` attribute to filter and group by a service’s namespace.
To address this issue, edit the attribute in your [instrumentation setup](/docs/grafana-cloud/send-data/otlp/send-data-otlp/#opentelemetry-environment-variables).
### Add the missing deployment.environment attribute
Application Observability uses the `deployment.environment.name` resource attribute (or the older `deployment.environment`) to map each service to the correct environment, for example `prod`, `staging`, or `dev`. Without it, services can appear ungrouped or assigned to the wrong environment, and the baselines feature doesn’t work.
Set the attribute in your [instrumentation setup](/docs/grafana-cloud/send-data/otlp/send-data-otlp/#opentelemetry-environment-variables). With standard OpenTelemetry instrumentation, add it to the resource attributes:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
OTEL_RESOURCE_ATTRIBUTES="deployment.environment.name=production"
### Don’t use slashes in the service name or namespace attributes
Don’t use slashes (`/`) in the `service.name` or `service.namespace` attributes. People often use slashes to namespace services. The OpenTelemetry specification has a specific namespace attribute. If you use the namespace attribute correctly, you can benefit from advanced group and filter features in Application Observability.
To address this issue, edit the attributes in your [instrumentation setup](/docs/grafana-cloud/send-data/otlp/send-data-otlp/#opentelemetry-environment-variables).
### Add missing Kubernetes attributes
If you use Kubernetes, include the `k8s.cluster.name`, `k8s.namespace.name`, and `k8s.pod.name` Kubernetes resource attributes to link Application and Kubernetes Observability and gain additional insights and easier workflows between the two products.
The easiest way to address this issue is to use the recommended [Grafana Kubernetes Monitoring Helm chart](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/helm-chart-config/helm-chart/).
Alternatively, for advanced use cases, manually set up Grafana Alloy or an OpenTelemetry Collector with the [k8sattributes processor](https://github.com/open-telemetry/opentelemetry-collector-contrib/blob/main/processor/k8sattributesprocessor/README.md) activated.
#### Enable Pod navigation links
To enable clickable Pod links in the service metadata that navigate directly to Kubernetes Monitoring, include at least one workload-type resource attribute that matches your workload. Only one is needed. Application Observability uses whichever is present to construct the link. The supported workload attributes are:
- `k8s.deployment.name`
- `k8s.statefulset.name`
- `k8s.daemonset.name`
- `k8s.cronjob.name`
- `k8s.job.name`
- `k8s.replicaset.name`
The `k8sattributes` processor extracts `k8s.deployment.name` by default, so Pod links work automatically for Deployment-based workloads. For other workload types (StatefulSet, DaemonSet, CronJob, Job), add the corresponding attribute to the processor’s metadata extraction list. You only need the attribute that matches your workload type. Extracting all of them isn’t required and may increase metric cardinality.
##### Grafana Kubernetes Monitoring Helm chart
If you use the recommended [Grafana Kubernetes Monitoring Helm chart](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/helm-chart-config/helm-chart/), Pod navigation links work for all workload types without additional configuration. The chart’s `applicationObservability` feature already extracts all supported workload attributes by default.
If you need to customize the extracted metadata, override the `applicationObservability.processors.k8sattributes.metadata` value in your `values.yaml`. For example, to add `k8s.statefulset.name` for a StatefulSet-based service:
YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```yaml
applicationObservability:
  enabled: true
  processors:
    k8sattributes:
      metadata:
        - k8s.namespace.name
        - k8s.pod.name
        - k8s.deployment.name
        - k8s.statefulset.name
        - k8s.node.name
##### Manual Grafana Alloy configuration
If you configure Grafana Alloy directly instead of using the Helm chart, add the workload attribute that matches your workload type to the `k8sattributes` processor `metadata` extraction list. For example, to support both Deployments and StatefulSets:
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
otelcol.processor.k8sattributes "default" {
  extract {
    metadata = [
      "k8s.namespace.name",
      "k8s.deployment.name",
      "k8s.statefulset.name",
      "k8s.node.name",
      "k8s.pod.name",
### Send missing logs for your service
Your service is missing logs. Send logs to help you debug and monitor your service.
To capture and send your application logs to Grafana Cloud, use one of the following methods:
- Use the recommended [instrumentation setup](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/setup/instrumentation/) for Application Observability.
- Send logs to [Loki](/docs/grafana-cloud/send-data/logs/) or the [OTLP endpoint](/docs/grafana-cloud/send-data/otlp/send-data-otlp/).
### Send missing profiles for your service
Your service is missing profiles. Send profiling information to help you debug and monitor your service.
To capture and send your application profile data to Grafana Cloud, [instrument your application for profiling data](/docs/grafana-cloud/monitor-applications/profiles/send-profile-data/).
### Add missing host identification attributes
Your service’s telemetry is missing the resource attributes needed to identify which host it runs on. Without these attributes, the service isn’t counted for host-hours billing.
Application Observability checks the following attributes in priority order and uses the first match. You only need to satisfy one tier:
1. `k8s.node.name` (Kubernetes workloads)
2. `host.id` (cloud VMs, bare metal, and on-premises VMs that aren’t on Kubernetes)
3. `grafana.host.id` (last-resort fallback, such as Docker or any host where `host.id` isn’t available)
For environment-specific configuration, refer to the [host-hours pricing](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/pricing/) documentation.
### Don’t mix histogram types in a single service
Application Observability supports native and classic histograms without configuration. It allows you to mix histogram types, but each service must use only one type.
If a service uses both types, only data from the native histogram appears. Use one type per service.
A quality check and a warning banner appear when this issue exists. Both show which environments use each histogram type.
### Reduce high-cardinality span names
High-cardinality span names drastically increase storage costs for metrics and prevent Application Observability from grouping operations effectively. Span names are intended to group operations into meaningful categories, so they should follow patterns that reflect operation types rather than specific instances.
Use generic patterns such as `GET /user/{id}` instead of specific values like `GET /user/123`.
The quality check highlights examples of high-cardinality span names and suggests improvements.
> Note
> This is a best-effort analysis and may not detect all issues or be fully accurate.
To mitigate high-cardinality span names, use a transform processor to rewrite the span names:
Grafana AlloyOpenTelemetry Collector
Grafana Alloy OpenTelemetry Collector
```alloy
otelcol.processor.transform "generalize_span_name" {
  error_mode = "ignore"
  trace_statements {
    context = "span"
    statements = [
      `replace_pattern(name, "\\?.*", "")`,
      `replace_match(name, "GET /api/products/*", "GET /api/products/{productId}")`,
```yaml
transform/generalize_span_name:
  error_mode: ignore
  trace_statements:
    - context: span
      statements:
        - replace_pattern(name, "\\?.*", "")
        - replace_match(name, "GET /api/products/*", "GET /api/products/{productId}")
### Avoid duplicate span metrics
RED metrics (rate, errors, duration) in Application Observability come from a histogram named `traces_spanmetrics_latency`. Applications can produce this metric in two ways:
- **eBPF-based instrumentation (preferred)**: Use OpenTelemetry eBPF instrumentation or Grafana Beyla. eBPF instrumentation provides the metric directly and doesn’t rely on distributed tracing.
- **Generate metrics from spans**: When eBPF isn’t available, Grafana Cloud can generate the metric from your trace spans as they are written. This approach requires a 100% span sampling rate to ensure that all traffic is represented.
If your application uses both tracing and eBPF, you might produce the same metric twice from multiple sources. To prevent duplicate metrics, disable metric generation by adding the resource attribute `span.metrics.skip=true` to your trace data.
With standard OpenTelemetry instrumentation, set the following environment variable:
```bash
OTEL_RESOURCE_ATTRIBUTES="span.metrics.skip=true"
For more details on the cost impact of duplicate span metrics, refer to [Optimize costs](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/optimize-costs/).
## Next steps
- Address failing checks starting with those marked **Recommended** to get the most value from Application Observability.
- After making changes, revisit the quality report to verify improvements.
- Review the [Instrumentation quality](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/services/instrumentation-quality/) list to compare quality across all services.
