title: "Service detail | Grafana Cloud documentation"
description: "Investigate a service's performance, metrics, logs, traces, profiles, and instrumentation quality."
# Service detail
The service detail page provides a deep view of a single service. Access it by clicking a service name in the [services catalog](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/services/).
## Page header
The service detail header shows:
- The service name and namespace.
- **Service** / **View** toggle: switch between the service-focused view and additional views.
- **+ Add to RCA Workbench**: add this service to an [RCA workbench](/docs/grafana-cloud/knowledge-graph/troubleshoot-infra-apps/workbench/) investigation.
- **RCA Workbench**: open RCA workbench directly.
## Tabs
The service detail page organizes information across the following tabs:
Expand table
| Tab        | Description        |
| [Service overview](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/service-overview/) | RED metric charts, duration heatmap, and outbound connections.                |
| [Metrics](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/metrics/)                   | Service-scoped metrics explorer showing all available metrics.                |
| [Logs](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/logs/)                         | Embedded Logs Drilldown filtered to the service.                              |
| [Traces](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/traces/)                     | Embedded Traces Drilldown with error analysis and breakdowns.                 |
| [Profiles](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/profiles/)                 | Embedded Profiles (Pyroscope) view for CPU, memory, and other profile types.  |
| [Quality report](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/quality-report/)     | Instrumentation quality assessment with actionable recommendations.           |
| [Properties](/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/service-detail/properties/)             | Entity metadata and resource attributes as discovered by the knowledge graph. |
## Time controls
All tabs share a common time range selector in the top right. You can also enable **Comparison** mode to overlay a previous time period for trend analysis.
