This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/application-observability-kg/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Application Observability powered by the knowledge graph
Note
If your Grafana Cloud organization was onboarded before September 7, 2026, refer to the classic Application Observability documentation.
Application Observability powered by the knowledge graph is an application performance monitoring (APM) solution that uses the Grafana Cloud Knowledge Graph to provide deep visibility into your applications. It automatically discovers your services, surfaces performance insights, and connects metrics, logs, traces, and profiles in a unified view.
The knowledge graph-powered experience provides:
- Service catalog with RED metrics: View all your services with latency, error ratio, and request rate at a glance.
- Intelligent insights: Automatically detect saturation, anomalies, failures, and errors without writing custom queries.
- Instrumentation quality: Assess how well each service is instrumented and get actionable recommendations to improve coverage.
- Integrated signal exploration: Drill from a service into its metrics, logs, traces, and profiles without leaving the Application context.
- Root cause analysis: Jump to RCA workbench to investigate correlated issues across your stack.
Before you begin
To use Application Observability powered by the knowledge graph, you need:
- A Grafana Cloud account.
- At least one application instrumented with OpenTelemetry, sending data to Grafana Cloud.
For setup instructions, refer to Set up.
Explore
Was this page helpful?
