This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/ai-observability/mcp-observability.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/ai-observability/mcp-observability/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
MCP observability
MCP Observability provides comprehensive monitoring for Model Context Protocol (MCP) implementations, enabling AI models to securely connect to data sources and interact with external tools.
Overview
The MCP Observability dashboard monitors Model Context Protocol performance and usage:
- Protocol health - Session management and connection stability monitoring
- Tool analytics - Usage patterns and performance metrics for tool operations
- Transport monitoring - Communication layer performance across different protocols
- Performance tracking - End-to-end MCP operation latency and efficiency
Key features
Protocol metrics
- Session establishment - Connection setup success rates and duration
- Connection stability - Session duration and reliability tracking
- Protocol compliance - Adherence to MCP standards and version compatibility
- Message throughput - Communication volume and payload analysis
Tool usage analytics
- Tool invocation frequency - Most and least used tools and usage patterns
- Tool performance - Response times and success rates by tool type
- Tool popularity trends - Usage patterns and adoption over time
- Tool error analysis - Failure categorization and root cause identification
Transport performance
- Communication latency - Response times across different transport types
- Network reliability - Connection stability and retry patterns
- Client-server interaction - Communication patterns and optimization opportunities
Getting started
Was this page helpful?
