This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/ai-observability.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/ai-observability/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Menu
OpenLIT Observability
OpenTelemetry-native observability with distributed tracing across your complete AI stack. Monitor and visualize real-time performance of LLMs, vector databases, GPUs and MCP Servers (Model Context Protocol)
Overview
Grafana OpenLIT Observability is a complete solution designed to monitor and optimize your entire AI stack. It provides end-to-end observability across all components of your AI stack.
GenAI observability
- Performance tracking: Monitor LLM response times, throughput, and availability across providers
- Cost management: Real-time spend tracking, cost optimization, and budget management for LLM usage
- Token analytics: Track consumption patterns, efficiency metrics, and usage optimization opportunities
- User interactions: Gain insights into user interactions, prompts, and completions for performance understanding
GenAI evaluations
- Quality assessment: Automated hallucination detection, factual accuracy verification, and content quality scoring
- Safety monitoring: Continuous toxicity detection, bias assessment, and compliance tracking for responsible AI
- Evaluation scoring: Confidence levels, quality gates, and automated quality assurance workflows
- Problem identification: Detailed analysis and categorization of AI model issues and failure patterns
GenAI Agent Observability
- Invocation tracking: Monitor total agent invocations, usage distribution by source, and percentage breakdown across your agentic AI systems
- Cost management: Real-time tracking of total agent costs in USD, per-agent cost breakdown, and cost attribution for budget optimization
- Performance monitoring: Track 95th percentile operation duration, average latency by agent and provider, and operation throughput rates
- Logs and debugging: Integrated agent logs with OpenTelemetry trace and span ID correlation for distributed tracing and root cause analysis
VectorDB observability
- Query performance: Monitor similarity search response times, throughput, and query optimization
- Database operations: Track insert, update, and delete operations across different vector database providers
- Resource utilization: Monitor memory usage, storage efficiency, and infrastructure scaling needs
- Index management: Track index building, optimization, and maintenance for optimal search performance
MCP observability
- Protocol health: Track session management, connection stability, and protocol compliance metrics
- Tool analytics: Monitor tool usage patterns, performance, and availability across your AI ecosystem
- Transport monitoring: Analyze communication performance across HTTP, WebSocket, and other transport layers
- Integration insights: Track tool invocation patterns, payload analysis, and system reliability
GPU observability
- Performance monitoring: Track GPU utilization, compute efficiency, and processing throughput
- Thermal management: Monitor temperatures, cooling systems, and prevent thermal throttling
- Resource optimization: Analyze memory usage, power consumption, and multi-GPU coordination
- Infrastructure health: Monitor hardware status, driver stability, and predictive maintenance metrics
Explore
Introduction
Learn about how Grafana Cloud OpenLIT Observability can help you improve performance of your AI stack.
Setup Guide
Install the OpenLIT Observability integration and configure OpenTelemetry for your AI applications.
GenAI Monitoring
Monitor and evaluate your generative AI applications with comprehensive observability and quality assessment capabilities.
VectorDB Observability
Track vector database performance, query response times, and operational metrics across services and environments.
MCP Observability
Monitor Model Context Protocol usage, tool analytics, and transport performance for robust protocol monitoring.
GPU Observability
Track GPU utilization, temperature, memory usage, and hardware performance metrics across your infrastructure.
Was this page helpful?
Video
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
Video
Start with Grafana Assistant
Learn how Grafana Assistant helps teams get answers faster using AI—without writing PromQL. Join this webinar to discover prompting best practices and security FAQs.
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
Choose a product
Scroll for more
