title: "Azure Monitor query editor | Grafana Cloud documentation"
description: "Guide for using the Azure Monitor data source's query editor"
# Azure Monitor query editor
Grafana provides a query editor for the Azure Monitor data source, which is located on the [Explore page](/docs/grafana/next/explore/). You can also access the Azure Monitor query editor from a dashboard panel. Click the menu in the upper right of the panel and select **Edit**.
This document explains querying specific to the Azure Monitor data source. For general documentation on querying data sources in Grafana, refer to [Query and transform data](/docs/grafana/next/panels-visualizations/query-transform-data/).
The Azure Monitor data source can query data from Azure Monitor Metrics and Logs, the Azure Resource Graph, and Application Insights Traces. Each source has its own specialized query editor.
## Before you begin
- Ensure you have [configured the Azure Monitor data source](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/configure/).
- Verify your credentials have appropriate permissions for the resources you want to query.
## Key concepts
If you’re new to Azure Monitor, here are some key terms used throughout this documentation:
Expand table
| Term                           | Description        |
| **KQL (Kusto Query Language)** | The query language used for Azure Monitor Logs and Azure Resource Graph. KQL uses a pipe-based syntax similar to Unix commands and is optimized for read-only data exploration. If you know SQL, the [SQL to Kusto cheat sheet](https://docs.microsoft.com/en-us/azure/data-explorer/kusto/query/sqlcheatsheet) can help you get started. |
| **Log Analytics workspace**    | An Azure resource that collects and stores log data from your Azure resources, applications, and services. You query this data using KQL.        |
| **Application Insights**       | Azure’s application performance monitoring (APM) service. It collects telemetry data like requests, exceptions, and traces from your applications.        |
| **Metrics vs. Logs**           | **Metrics** are lightweight numeric values collected at regular intervals (for example, CPU percentage). **Logs** are detailed records of events with varying schemas (for example, request logs, error messages). Metrics use a visual query builder; Logs require KQL.        |
## Choose a query editor mode
The Azure Monitor data source’s query editor has four modes depending on which Azure service you want to query:
- **Metrics** for [Azure Monitor Metrics](#query-azure-monitor-metrics)
- **Logs** for [Azure Monitor Logs](#query-azure-monitor-logs)
- **Traces** for [Application Insights Traces](#query-application-insights-traces)
- **Azure Resource Graph** for [Azure Resource Graph](#query-azure-resource-graph)
## Query Azure Monitor Metrics
Azure Monitor Metrics collects numeric data from [supported resources](https://docs.microsoft.com/en-us/azure/azure-monitor/monitor-reference), and you can query them to investigate your resources’ health and usage and maximize availability and performance.
Monitor Metrics use a lightweight format that stores only numeric data in a specific structure and supports near real-time scenarios, making it useful for fast detection of issues. In contrast, Azure Monitor Logs can store a variety of data types, each with their own structure.
[Azure Monitor Metrics sample query visualizing CPU percentage over time](/static/img/docs/azure-monitor/query-editor-metrics.png)
### Create a Metrics query
**To create a Metrics query:**
1. In a Grafana panel, select the **Azure Monitor** data source.
2. Select the **Metrics** service.
3. Select a resource from which to query metrics by using the subscription, resource group, resource type, and resource fields. Multiple resources can also be selected as long as they belong to the same subscription, region and resource type. Note that only a limited amount of resource types support this feature.
4. To select a different namespace than the default—for instance, to select resources like storage accounts that are organized under multiple namespaces—use the **Namespace** option.
   > Note
   > Not all metrics returned by the Azure Monitor Metrics API have values.
   > The data source retrieves lists of supported metrics for each subscription and ignores metrics that never have values.
5. Select a metric from the **Metric** field.
Optionally, you can apply further aggregations or filter by dimensions.
1. Change the aggregation from the default average to show minimum, maximum, or total values.
2. Specify a custom time grain. By default, Grafana selects a time grain interval for you based on your selected time range.
3. For metrics with multiple dimensions, you can split and filter the returned metrics. For example, the Application Insights dependency calls metric supports returning multiple time series for successful and unsuccessful calls.
[Azure Monitor Metrics screenshot showing Dimensions](/static/img/docs/azure-monitor/query-editor-metrics-dimensions.png)
The available options change depending on what is relevant to the selected metric.
You can also augment queries by using [template variables](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/template-variables/).
### Format legend aliases
You can change the legend label for Metrics by using aliases. In the Legend Format field, you can combine aliases defined below any way you want.
For example:
- `Blob Type: {{ blobtype }}` becomes `Blob Type: PageBlob`, `Blob Type: BlockBlob`
- `{{ resourcegroup }} - {{ resourcename }}` becomes `production - web_server`
Expand table
| Alias pattern                  | Description        |
| `{{ subscriptionid }}`         | Replaced with the subscription ID.        |
| `{{ subscription }}`           | Replaced with the subscription name.        |
| `{{ resourcegroup }}`          | Replaced with the resource group.        |
| `{{ namespace }}`              | Replaced with the resource type or namespace, such as `Microsoft.Compute/virtualMachines`.             |
| `{{ resourcename }}`           | Replaced with the resource name.        |
| `{{ metric }}`                 | Replaced with the metric name, such as “Percentage CPU”.                                               |
| *`{{ arbitraryDimensionID }}`* | Replaced with the value of the specified dimension. For example, `{{ blobtype }}` becomes `BlockBlob`. |
| `{{ dimensionname }}`          | *(Legacy for backward compatibility)* Replaced with the name of the first dimension.                   |
| `{{ dimensionvalue }}`         | *(Legacy for backward compatibility)* Replaced with the value of the first dimension.                  |
### Filter with dimensions
Some metrics also have dimensions, which associate additional metadata. Dimensions are represented as key-value pairs assigned to each value of a metric. Grafana can display and filter metrics based on dimension values.
The data source supports the `equals`, `not equals`, and `starts with` operators as detailed in the [Monitor Metrics API documentation](https://docs.microsoft.com/en-us/rest/api/monitor/metrics/list).
For more information on multi-dimensional metrics, refer to the [Azure Monitor data platform metrics documentation](https://docs.microsoft.com/en-us/azure/azure-monitor/essentials/data-platform-metrics#multi-dimensional-metrics) and [Azure Monitor filtering documentation](https://docs.microsoft.com/en-us/azure/azure-monitor/essentials/metrics-charts#filters).
## Query Azure Monitor Logs
Azure Monitor Logs collects and organizes log and performance data from [supported resources](https://docs.microsoft.com/en-us/azure/azure-monitor/monitor-reference), and makes many sources of data available to query together with the [Kusto Query Language (KQL)](https://docs.microsoft.com/en-us/azure/data-explorer/kusto/query/).
While Azure Monitor Metrics stores only simplified numerical data, Logs can store different data types, each with their own structure. You can also perform complex analysis of Logs data by using KQL.
The Azure Monitor data source also supports querying of [Basic Logs](https://learn.microsoft.com/en-us/azure/azure-monitor/logs/basic-logs-query?tabs=portal-1) tables (if they exist in your Log Analytics workspace). This feature must be enabled in the data source configuration.
[Azure Monitor Logs sample query comparing successful requests to failed requests](/static/img/docs/azure-monitor/query-editor-logs.png)
### Logs query builder (public preview)
> Note
> The Logs query builder is a [public preview feature](/docs/release-life-cycle/). It may not be enabled in all Grafana environments.
The Logs query builder provides a visual interface for building Azure Monitor Logs queries without writing KQL. This is helpful if you’re new to KQL or want to quickly build queries.
**To enable the Logs query builder:**
1. Enable the `azureMonitorLogsBuilderEditor` [feature toggle](/docs/grafana/next/setup-grafana/configure-grafana/feature-toggles/) in your Grafana configuration.
2. Restart Grafana for the change to take effect.
**To switch between Builder and Code modes:**
When the feature is enabled, a **Builder / Code** toggle appears in the Logs query editor:
- **Builder**: Use the visual interface to select tables, columns, filters, and aggregations. The builder generates the KQL query for you.
- **Code**: Write KQL queries directly. Use this mode for complex queries that require full KQL capabilities.
New queries default to Builder mode. Existing queries that were created with raw KQL remain in Code mode. When you switch to Builder mode, the time-range setting automatically changes to **Dashboard** because the builder manages time filtering for you.
> Note
> You can switch from Builder to Code mode at any time to view or edit the generated KQL. However, switching from Code to Builder mode may not preserve complex queries that can’t be represented in the builder interface.
### Create a Logs query
**To create a Logs query:**
2. Select the **Logs** service.
3. Select a resource to query. Multiple resources can be selected as long as they are of the same type.
   Alternatively, you can dynamically query all resources under a single resource group or subscription.
   > Note
   > If a time span is specified in the query, the overlap between the query time span and the dashboard time range is used. Refer to the [API documentation for details.](https://learn.microsoft.com/en-us/rest/api/loganalytics/dataaccess/query/get?tabs=HTTP#uri-parameters)
4. Enter your KQL query.
**To create a Basic Logs query:**
1. Ensure that the data source has the **Enable Basic Logs** toggle enabled in the [data source configuration](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/configure/#enable-basic-logs).
2. In a Grafana panel, select the **Azure Monitor** data source.
3. Select the **Logs** service.
4. Select a single resource to query. Basic Logs queries only support a single workspace resource.
5. Switch the **Logs** toggle from **Analytics** to **Basic**. A confirmation dialog box displays to notify you of potential additional costs.
6. Enter your KQL query.
> Caution
> Basic Logs queries are billed on a per-query basis by Azure. Review the [Azure pricing documentation](https://learn.microsoft.com/en-us/azure/azure-monitor/logs/basic-logs-query?tabs=portal-1) before using this feature.
Basic Logs queries have the following restrictions:
- **Time range:** The dashboard time range is always used. You can’t specify a time range within the query itself.
- **Single resource:** Only a single Log Analytics workspace can be queried. Multi-resource selection isn’t supported.
- **Alerting:** Basic Logs queries aren’t available when creating alert rules.
- **KQL limitations:** Some KQL operators aren’t supported. Refer to the [Azure documentation](https://learn.microsoft.com/en-us/azure/azure-monitor/logs/basic-logs-query?tabs=portal-1#limitations) for a full list of limitations.
### Logs query examples
Azure Monitor Logs queries are written using the Kusto Query Language (KQL), a rich language similar to SQL.
The Azure documentation includes resources to help you learn KQL:
- [Log queries in Azure Monitor](https://docs.microsoft.com/en-us/azure/azure-monitor/logs/log-query-overview)
- [Getting started with Kusto](https://docs.microsoft.com/en-us/azure/data-explorer/kusto/concepts/)
- [Tutorial: Use Kusto queries in Azure Monitor](https://docs.microsoft.com/en-us/azure/data-explorer/kusto/query/tutorial?pivots=azuremonitor)
- [SQL to Kusto cheat sheet](https://docs.microsoft.com/en-us/azure/data-explorer/kusto/query/sqlcheatsheet)
> Note
> **Time-range:** The time-range used for the query can be modified via the time-range switch:
> - Selecting **Query** uses only time-ranges specified within the query.
> - Selecting **Dashboard** uses only the Grafana dashboard time-range.
> - If no time-range is specified in the query, the default Log Analytics time-range applies.
> For more details, refer to the [Azure Monitor Logs API documentation](https://learn.microsoft.com/en-us/rest/api/loganalytics/dataaccess/query/get?tabs=HTTP#uri-parameters). If you previously used the `Intersection` option, it has been migrated to `Dashboard`.
This example query returns a virtual machine’s CPU performance, averaged over 5-minute time grains:
kusto ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```kusto
Perf
// $__timeFilter is a special Grafana macro that filters the results to the time span of the dashboard
| where $__timeFilter(TimeGenerated)
| where CounterName == "% Processor Time"
| summarize avg(CounterValue) by bin(TimeGenerated, 5m), Computer
| order by TimeGenerated asc
Use time series queries for values that change over time, usually for graph visualizations such as the Time series panel. Each query should return at least a `datetime` column and numeric value column. The result must also be sorted in ascending order by the `datetime` column.
You can also create a query with at least one non-numeric, non-`datetime` column. Azure Monitor considers those columns to be dimensions, and they become labels in the response.
For example, this query returns the aggregated count grouped by hour, Computer, and the CounterName:
```kusto
Perf
| summarize count() by bin(TimeGenerated, 1h), Computer, CounterName
You can also select additional number value columns, with or without multiple dimensions. For example, this query returns a count and average value by hour, Computer, CounterName, and InstanceName:
```kusto
Perf
| summarize Samples=count(), ["Avg Value"]=avg(CounterValue)
    by bin(TimeGenerated, $__interval), Computer, CounterName, InstanceName
Use table queries with the Table panel to produce a list of columns and rows. This query returns rows with the six specified columns:
```kusto
AzureActivity
| where $__timeFilter()
| project TimeGenerated, ResourceGroup, Category, OperationName, ActivityStatus, Caller
| order by TimeGenerated desc
### Use macros in Logs queries
To help you write queries, you can use several Grafana macros in the `where` clause:
Expand table
| Macro                           | Description        |
| `$__timeFilter()`               | Filters the results to the time range of the dashboard. Example: `TimeGenerated >= datetime(2018-06-05T18:09:58.907Z) and TimeGenerated <= datetime(2018-06-05T20:09:58.907Z)`.        |
| `$__timeFilter(datetimeColumn)` | Like `$__timeFilter()`, but specifies a custom field to filter on.        |
| `$__timeFrom()`                 | Returns the start of the dashboard time range. Example: `datetime(2018-06-05T18:09:58.907Z)`.        |
| `$__timeTo()`                   | Returns the end of the dashboard time range. Example: `datetime(2018-06-05T20:09:58.907Z)`.        |
| `$__escapeMulti($myVar)`        | Escapes illegal characters in multi-value template variables. If `$myVar` has the values `'\\grafana-vm\Network(eth0)\Total','\\hello!'` as a string, use this to expand it to `@'\\grafana-vm\Network(eth0)\Total', @'\\hello!'`. If using single-value variables, escape the variable inline instead: `@'\$myVar'`.        |
| `$__contains(colName, $myVar)`  | Expands multi-value template variables. If `$myVar` has the value `'value1','value2'`, use this to expand it to `colName in ('value1','value2')`. If using the `All` option, check the `Include All Option` checkbox, and type the value `all` in the `Custom all value` field. If `$myVar` has the value `all`, the macro instead expands to `1 == 1`. For template variables with many options, this avoids building a large “where..in” clause, which improves performance. |
Additionally, Grafana has the built-in [`$__interval` macro](/docs/grafana/next/panels-visualizations/query-transform-data/#query-options), which calculates an interval in seconds.
## Query Azure Resource Graph
Azure Resource Graph (ARG) is an Azure service designed to extend Azure Resource Management with efficient resource exploration and the ability to query at scale across a set of subscriptions, so that you can more effectively govern an environment. By querying ARG, you can query resources with complex filtering, iteratively explore resources based on governance requirements, and assess the impact of applying policies in a vast cloud environment.
[Azure Resource Graph sample query listing virtual machines on an account](/static/img/docs/azure-monitor/query-editor-arg.png)
### Create a Resource Graph query
ARG queries are written in a variant of the [Kusto Query Language (KQL)](https://docs.microsoft.com/en-us/azure/governance/resource-graph/concepts/query-language), but not all Kusto language features are available in ARG.
An Azure Resource Graph query is formatted as table data.
If your Azure credentials grant you access to multiple subscriptions, you can choose multiple subscriptions before entering queries. It is also possible to run queries against the directory by changing the scope of the query.
> Note
> Some queries that function at a directory level may not work at a subscription level and vice-versa.
### Resource Graph query examples
The Azure documentation also includes [sample queries](https://docs.microsoft.com/en-gb/azure/governance/resource-graph/samples/starter) to help you get started.
**Sort results by resource properties:**
This query returns all resources in the selected subscriptions, but only the name, type, and location properties:
```kusto
Resources
| project name, type, location
| order by name asc
This query uses `order by` to sort the properties by the `name` property in ascending (`asc`) order. You can change which property to sort by and the order (`asc` or `desc`). This query uses `project` to show only the listed properties in the results. You can use this to add or remove properties in your queries.
**Query resources with complex filtering:**
You can filter for Azure resources with a tag name and value.
For example, this query returns a list of resources with an `environment` tag value of `Internal`:
```kusto
Resources
| where tags.environment=~'internal'
| project name
This query uses `=~` in the `type` match to make the query case-insensitive. You can also use `project` with other properties, or add or remove more.
**Group and aggregate the values by property:**
You can use `summarize` and `count` to define how to group and aggregate values by property.
For example, this query returns counts of healthy, unhealthy, and not applicable resources per recommendation:
```kusto
securityresources
| where type == 'microsoft.security/assessments'
| extend resourceId=id,
    recommendationId=name,
    resourceType=type,
    recommendationName=properties.displayName,
    source=properties.resourceDetails.Source,
    recommendationState=properties.status.code,
    description=properties.metadata.description,
    assessmentType=properties.metadata.assessmentType,
    remediationDescription=properties.metadata.remediationDescription,
    policyDefinitionId=properties.metadata.policyDefinitionId,
    implementationEffort=properties.metadata.implementationEffort,
    recommendationSeverity=properties.metadata.severity,
    category=properties.metadata.categories,
    userImpact=properties.metadata.userImpact,
    threats=properties.metadata.threats,
    portalLink=properties.links.azurePortal
| summarize numberOfResources=count(resourceId) by tostring(recommendationName), tostring(recommendationState)
In ARG, many nested properties (`properties.displayName`) are of a `dynamic` type and should be cast to a string with `tostring()` to operate on them.
### Use macros in Resource Graph queries
Expand table
| `$__timeFilter()`               | Expands to `timestamp ≥ datetime(2018-06-05T18:09:58.907Z) and timestamp ≤ datetime(2018-06-05T20:09:58.907Z)`, where the from and to date-time values are from the Grafana time picker.        |
| `$__timeFilter(datetimeColumn)` | Expands to `datetimeColumn ≥ datetime(2018-06-05T18:09:58.907Z) and datetimeColumn ≤ datetime(2018-06-05T20:09:58.907Z)`, where the from and to date-time values are from the Grafana time picker.        |
| `$__timeFrom()`                 | Returns the start of the dashboard time range from the Grafana picker. Example: `datetime(2018-06-05T18:09:58.907Z)`.        |
| `$__timeTo()`                   | Returns the end of the dashboard time range from the Grafana picker. Example: `datetime(2018-06-05T20:09:58.907Z)`.        |
| `$__escapeMulti($myVar)`        | Escapes illegal characters from multi-value template variables. If `$myVar` has the values `'\\grafana-vm\Network(eth0)\Total','\\hello!'` as a string, this expands it to `@'\\grafana-vm\Network(eth0)\Total', @'\\hello!'`. If you use single-value variables, escape the variable inline instead: `@'\$myVar'`.        |
| `$__contains(colName, $myVar)`  | Expands multi-value template variables. If `$myVar` has the value `'value1','value2'`, this expands it to `colName in ('value1','value2')`. If using the `All` option, then check the `Include All Option` checkbox and in the `Custom all value` field type in the following value: `all`. If `$myVar` has value `all`, this instead expands to `1 == 1`. For template variables with many options, this avoids building a large “where..in” clause, which improves performance. |
## Query Application Insights Traces
[Azure Application Insights](https://learn.microsoft.com/en-us/azure/azure-monitor/app/app-insights-overview?tabs=net) is a service that provides application performance monitoring (APM) features. Application insights can be used to collect metrics, telemetry, and trace logging data.
Application Insights stores trace data in an underlying Log Analytics workspace and traces can be [extended](https://learn.microsoft.com/en-us/azure/azure-monitor/app/api-custom-events-metrics) to provide additional supporting information as required by the application developer.
### Create a Traces query
**To create a Traces query:**
2. Select the **Traces** service.
   > Note
   > This query type only supports Application Insights resources.
4. (Optional) Specify an **Operation ID** value to filter traces.
5. (Optional) Specify **event types** to filter by.
6. (Optional) Specify **event properties** to filter by.
7. (Optional) Change the **Result format** to switch between tabular format and trace format.
   > Note
   > Selecting the trace format filters events to only the `trace` type. Use this format with the Trace visualization.
Running a query returns all trace data within the time span specified by the panel or dashboard time range.
## Use queries for alerting and recording rules
All Azure Monitor query types (Metrics, Logs, Azure Resource Graph, and Traces) can be used with Grafana Alerting and recording rules.
For detailed information about creating alert rules, supported query types, authentication requirements, and examples, refer to [Azure Monitor alerting](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/alerting/).
## Work with large Azure resource datasets
If a request exceeds the [maximum allowed value of records](https://docs.microsoft.com/en-us/azure/governance/resource-graph/concepts/work-with-data#paging-results), the result is paginated and only the first page of results are returned. You can use filters to reduce the amount of records returned under that value.
## Next steps
- [Use template variables](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/template-variables) to create dynamic, reusable dashboards
- [Add annotations](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/annotations/) to overlay events on your graphs
- [Set up alerting](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/alerting/) to create alert rules based on Azure Monitor data
- [Troubleshoot](/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/troubleshooting/) common query and configuration issues
