This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/connect-externally-hosted/data-sources/azure-monitor/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Azure Monitor data source
The Azure Monitor data source plugin allows you to query and visualize data from Azure Monitor, the Azure service to maximize the availability and performance of applications and services in the Azure Cloud.
Supported features
| Feature | Supported |
| Metrics | Yes |
| Logs | Yes |
| Traces | Yes |
| Alerting | Yes |
| Annotations | Yes |
Note
The Azure Monitor data source requires Grafana 12.3 or later.
Supported Azure clouds
The Azure Monitor data source supports the following Azure cloud environments:
- Azure - Azure public cloud (default)
- Azure US Government - Azure Government cloud
- Azure China - Azure China cloud operated by 21Vianet
Supported Azure services
The Azure Monitor data source supports the following Azure services:
| Service | Description |
| Azure Monitor Metrics | Collect numeric data from resources in your Azure account. Supports dimensions, aggregations, and time grain configuration. |
| Azure Monitor Logs | Collect log and performance data from your Azure account using the Kusto Query Language (KQL). |
| Azure Resource Graph | Query your Azure resources across subscriptions using KQL. Useful for inventory, compliance, and resource management. |
| Application Insights Traces | Collect distributed trace data and correlate requests across your application components. |
Get started
The following documents help you get started with the Azure Monitor data source:
- Configure the Azure Monitor data source - Set up authentication and connect to Azure
- Azure Monitor query editor - Create and edit queries for Metrics, Logs, Traces, and Resource Graph
- Template variables - Create dynamic dashboards with Azure Monitor variables
- Alerting - Create alert rules using Azure Monitor data
- Troubleshooting - Solve common configuration and query errors
Additional features
After you have configured the Azure Monitor data source, you can:
- Add Annotations to overlay Azure log events on your graphs.
- Configure and use Template variables for dynamic dashboards.
- Add Transformations to manipulate query results.
- Set up Alerting and recording rules using Metrics, Logs, Traces, and Resource Graph queries.
- Use Explore to investigate your Azure data without building a dashboard.
Pre-built dashboards
The Azure Monitor plugin includes pre-built dashboards organized by category:
Infrastructure monitoring:
- Azure / Infrastructure / Apps Monitoring
- Azure / Infrastructure / Compute Monitoring
- Azure / Infrastructure / Data Monitoring
- Azure / Infrastructure / Network Monitoring
- Azure / Infrastructure / Storage and Key Vaults Monitoring
Azure Insights:
- Azure / Insights / Applications
- Azure / Insights / Applications / Performance / Operations
- Azure / Insights / Applications / Performance / Dependencies
- Azure / Insights / Applications / Failures / Operations
- Azure / Insights / Applications / Failures / Dependencies
- Azure / Insights / Applications / Failures / Exceptions
- Azure / Insights / Applications Test Availability Geo Map
- Azure / Insights / CosmosDB
- Azure / Insights / Data Explorer Clusters
- Azure / Insights / Key Vaults
- Azure / Insights / Networks
- Azure / Insights / SQL Database
- Azure / Insights / Storage Accounts
- Azure / Insights / Virtual Machines by Resource Group
- Azure / Insights / Virtual Machines by Workspace
Other:
- Azure / Alert Consumption
- Azure / Azure PostgreSQL / Flexible Server Monitoring
- Azure Monitor / Container Insights / Syslog
- Azure / Resources Overview
To import a pre-built dashboard:
- Go to Connections > Data sources.
- Select your Azure Monitor data source.
- Click the Dashboards tab.
- Click Import next to the dashboard you want to use.
Plugin updates
Always ensure that your plugin version is up-to-date so you have access to all current features and improvements. Navigate to Plugins and data > Plugins to check for updates. Grafana recommends upgrading to the latest Grafana version, and this applies to plugins as well.
Note
Plugins are automatically updated in Grafana Cloud.
Related resources
Was this page helpful?
