title: "PII and secrets redaction | Grafana Cloud documentation"
description: "Scan and redact PII and secrets from LLM requests using Agent Observability SDKs and guards."
# PII and secrets redaction
Agent Observability provides two layers of redaction to keep sensitive data out of LLM provider requests and out of your generation history:
- **SDK-side secrets redaction** — your application SDK detects and redacts secrets before generation data is exported.
- **Server-side guards** — synchronous redaction rules and PII evaluators that run on the request path before each LLM call.
Use the SDK layer to keep credentials out of your traces. Use guards to apply organization-wide policies that scan and redact requests before they reach the model.
## Before you begin
- An Agent Observability SDK is installed in your application. Refer to [Get started](/docs/grafana-cloud/observe-and-act/agent-observability/get-started) for installation.
- For guard-based redaction, Agent Observability is enabled on your Grafana Cloud stack and receiving generation data.
## Redact secrets with the SDK
The Go, Python, JavaScript, and .NET SDKs include a built-in secrets sanitizer that runs in the generation pipeline. When enabled, the sanitizer scans message content, tool calls, tool results, and system prompts before the SDK exports the generation. Detected secrets are replaced with `[REDACTED:<category>]` placeholders, so credentials never reach Agent Observability storage.
Secrets redaction is opt-in. Enable it by passing the sanitizer to your client configuration.
### Review SDK support
Secrets redaction is available in the Go, Python, JavaScript, and .NET SDKs. Email address redaction is on by default in each SDK.
Expand table
| SDK            | Secrets redaction | Email redaction | Notes                                 |
| **Go**         | Available         | On by default   | `NewSecretRedactionSanitizer()`       |
| **Python**     | Available         | On by default   | `create_secret_redaction_sanitizer()` |
| **JavaScript** | Available         | On by default   | `createSecretRedactionSanitizer()`    |
| **.NET**       | Available         | On by default   | `SecretRedactionSanitizer.Create()`   |
### Review detected secrets
The SDK sanitizer ships with hand-curated patterns sourced from gitleaks. The same patterns are applied across Go, Python, JavaScript, and .NET.
Expand table
| Category                  | Patterns detected        |
| **Grafana**               | Grafana Cloud tokens (`glc_`), service account tokens (`glsa_`)                                                |
| **AWS**                   | Access keys (AKIA, ASIA, ABIA, ACCA prefixes)        |
| **GitHub**                | Personal access tokens, fine-grained PATs, OAuth tokens, app tokens                                            |
| **AI providers**          | OpenAI API keys, project keys, service account keys; Anthropic API keys and admin keys                         |
| **GCP**                   | API keys (`AIza`)        |
| **Cryptographic**         | PEM-encoded private keys        |
| **Databases**             | Connection strings for PostgreSQL, MySQL, MongoDB, Redis, AMQP                                                 |
| **Authorization**         | Bearer tokens in `Authorization` headers        |
| **Collaboration tools**   | Slack bot, user, and app tokens        |
| **Payments**              | Stripe live, test, and restricted keys        |
| **Email and messaging**   | SendGrid API keys, Twilio API keys        |
| **Package registries**    | npm tokens, PyPI tokens        |
| **Heuristic (env-style)** | `PASSWORD=`, `SECRET=`, `TOKEN=`, `KEY=`, `CREDENTIAL=`, `API_KEY=`, `PRIVATE_KEY=`, `ACCESS_KEY=` assignments |
| **PII**                   | Email addresses (toggleable, on by default)        |
The sanitizer applies a high-confidence pass to all assistant text and reasoning, and an extended pass (which includes the heuristic env-style assignments) to tool arguments, tool results, and system prompts. This split keeps false positives out of model reasoning while catching credentials in tool inputs.
The SDK sanitizer doesn’t detect names, addresses, government IDs, phone numbers, or other general PII. For that, use a guard.
### Enable secrets redaction
Pass the sanitizer to your client configuration. Once enabled, the sanitizer runs automatically on all generation exports.
#### Go
Go ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```go
import "github.com/grafana/agento11y/go/agento11y"
client := agento11y.NewClient(agento11y.Config{
    GenerationSanitizer: agento11y.NewSecretRedactionSanitizer(agento11y.SecretRedactionOptions{}),
#### Python
Python ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```python
from agento11y import Client, ClientConfig, create_secret_redaction_sanitizer
client = Client(ClientConfig(
    generation_sanitizer=create_secret_redaction_sanitizer(),
#### JavaScript
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import { Agento11yClient, createSecretRedactionSanitizer } from "@grafana/agento11y";
const client = new Agento11yClient({
  generationSanitizer: createSecretRedactionSanitizer(),
#### .NET
csharp ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```csharp
using Grafana.Agento11y;
var client = new Agento11yClient(new Agento11yClientConfig
    GenerationSanitizer = SecretRedactionSanitizer.Create(),
### Redact user input messages
By default, the sanitizer leaves user messages untouched so that intentional user-provided context, for example, a SQL query a user pasted into a chat, isn’t redacted. To also redact secrets from user messages, opt in:
- Set `RedactInputMessages: true` (Go), `redact_input_messages=True` (Python), `redactInputMessages: true` (JavaScript), or `RedactInputMessages = true` (.NET) on the sanitizer options.
- Or set the environment variable `AGENTO11Y_REDACT_INPUT_MESSAGES=true`.
Explicit options take precedence over the environment variable.
### View redacted content
When the sanitizer detects a secret, it replaces the matched substring with a tagged placeholder:
**Original tool argument:**
```none
{"command": "curl -H 'Authorization: Bearer ghp_aBcDeFgHiJkLmNoPqRsTuVwXyZ0123456789'"}
**Sanitized tool argument exported to Agent Observability:**
```none
{"command": "curl -H 'Authorization: [REDACTED:bearer-token]'"}
Placeholders follow the format `[REDACTED:<category>]`, where `<category>` identifies the pattern that matched, for example, `aws-access-token`, `github-pat`, `openai-api-key`, `anthropic-api-key`, `email-address`.
## Redact secrets with server-side guards
Guards run on the request path before each LLM call and return an allow or deny decision to the SDK. Two guard types are relevant to redaction:
- **Redact guards** apply regex patterns to redact content in messages, system prompts, tool definitions, and tool call arguments. The SDK uses the sanitized copy for the LLM call.
- **Evaluator guards** with the built-in `template.pii` LLM judge detect personally identifiable information based on a semantic policy rather than fixed patterns.
For the full guard configuration workflow, refer to [Set up guards](/docs/grafana-cloud/observe-and-act/agent-observability/protect-agents/guards).
### Detect PII with the `template.pii` evaluator
The built-in PII evaluator is an LLM judge. Because it uses semantic judgment rather than fixed patterns, it catches PII that regex misses, for example, an address written in natural language, at the cost of an additional LLM call per guarded request. To select an available provider and model, refer to [Choose a judge provider](/docs/grafana-cloud/observe-and-act/agent-observability/evaluate-and-improve/configure-evaluation/#choose-a-judge-provider).
It flags responses containing:
- Contact details, for example, email addresses or phone numbers.
- Postal addresses.
- Government-issued identifiers.
- Financial details.
- Credentials.
- Exact dates of birth.
- Combinations of attributes that identify a private individual.
### Redact with redact guards
Redact guards use regex patterns you define, for example, to redact US SSNs and phone numbers. Matches are always replaced with the fixed token `[REDACTED]`:
Expand table
| Regex                         | Replacement  |
| `\b\d{3}-\d{2}-\d{4}\b`       | `[REDACTED]` |
| `\b\d{3}[-.]\d{3}[-.]\d{4}\b` | `[REDACTED]` |
Redact guards scan system prompts, message text in user, assistant, and tool messages, tool call arguments (JSON serialized), tool result content, and tool definition descriptions and input schemas.
Redact guards don’t scan model thinking blocks, because changing them would invalidate the provider’s reasoning signature.
For the full redact guard workflow, refer to [Set up guards](/docs/grafana-cloud/observe-and-act/agent-observability/protect-agents/guards).
## Understand coverage and limits
The SDK and guard layers cover different paths. SDK secrets redaction sanitizes generation content before it leaves your application, so credentials don’t reach Agent Observability storage or traces. Redact guards and PII rules sanitize outbound request content before it reaches the LLM provider — the sanitized copy is what the model sees.
Redaction doesn’t cover:
- **Responses from the LLM provider** — generated text isn’t scanned by the SDK sanitizer or guard redactions. If a model emits sensitive data in its response, that content reaches your application and traces unmodified. For response-side checks, attach an evaluator guard that runs after generation.
- **Streaming responses** — postflight evaluation buffers complete responses today; Agent Observability doesn’t yet support per-chunk scanning of streaming responses.
- **Model thinking blocks** — redact guards skip thinking content to preserve provider reasoning signatures.
- **Reversal of redacted values** — the `[REDACTED]` token is permanent. Agent Observability doesn’t store a mapping back to the original value, so the model and downstream consumers both see the token. If your workflow requires the model to act on the original value, for example, processing a refund using the real SSN, redact in a layer that handles de-redaction separately.
If your security model requires that sensitive data never enters Agent Observability under any path, combine SDK-side sanitization for client-trusted data with server-side guards for any data that originates outside your control.
## Next steps
- [Set up guards](/docs/grafana-cloud/observe-and-act/agent-observability/protect-agents/guards) to configure server-side redaction policies.
- [Data handling and privacy](/docs/grafana-cloud/observe-and-act/agent-observability/privacy-and-access/privacy) for what Agent Observability stores and how to control retention.
- [Security and access controls](/docs/grafana-cloud/observe-and-act/agent-observability/privacy-and-access/security) for authentication and authorization.
