Configure evaluators and evaluation rules
Use this page to tune evaluator settings and traffic selection. To create your first evaluation and review its results, refer to Set up and monitor online evaluation. Evaluators define the scoring logic, and evaluations define which traffic to score.
Before you begin
- Send generation data to Agent Observability. Refer to Get started with Grafana Cloud.
- You have the Agent Observability Admin role.
- For LLM judge evaluators, choose a provider and model available in your stack. You don’t need a judge provider for JSON schema, regex, or heuristic evaluators.
Choose a judge provider
In Grafana Cloud, you use Grafana-configured judge providers. When you create an LLM judge evaluator, select an available provider and model. You don’t supply your own provider credentials.
LLM judges send the content being scored to the selected provider. For details, refer to Privacy.
Handle an exhausted judge allowance
When your stack reaches its monthly LLM judge allowance, Evaluations displays Monthly LLM judge allowance reached. LLM judge evaluations stop running, but non-LLM evaluations aren’t affected.
Your allowance tracks estimated judge spend using catalog prices, including long-context rates when the judge’s input exceeds the model’s threshold. Long prompts can consume the allowance faster when those rates are higher. Your custom model prices don’t change this calculation.
Click Contact support to request a higher limit, or wait until the allowance resets at the start of the next month (UTC).
Create evaluators
Use Agent Observability or the evaluation API to create evaluators. Four evaluator types are available:
LLM judge
An LLM judge uses an LLM to score generations based on criteria you define in a prompt template.
Key settings:
providerandmodel: the LLM to use for judging. In the UI, choose a model from the LLM Model field on evaluator creation and editing, version publishing, template creation, and the test panel:- The field lists all models across every configured provider with vendor marks and human-readable names, for example,
Claude Haiku 4.5orGPT-4o Mini. - While the catalog loads, the field displays a loading indicator and still accepts a typed model.
- When models from different providers share a display name, the provider name appears in parentheses. When models from the same provider share a name, the list retains the snapshot date or version suffix (falling back to the raw model ID if there’s no suffix).
- Leave the field set to Default (or clear the selection) to use your organization’s configured default judge.
- If a model isn’t listed in the catalog, or if a provider’s model list is unavailable or returns no models, type a custom PROVIDER/MODEL identifier, for example,
openai/gpt-4o. - When you fork an LLM judge template, use the Model override field to select a model or keep the template default. Non-judge evaluator templates don’t show this field.
system_promptanduser_prompt: prompt templates with variables.max_tokens: set by Sigil. A value in a stored config is ignored. Judges run at the model’s output limit, up to16384.temperature: optional, evaluation API only. When omitted, the model provider’s default applies (for example,1.0for OpenAI and Anthropic). The UI doesn’t display a Temperature field, and saving an evaluator in the UI removes the setting. Set it only if the selected model supports it; an explicit0isn’t the same as leaving it unset.reasoning_effort: optionalnone,minimal,low,medium,high, orxhigh.nonedisables reasoning; omission leaves it unspecified. Provider APIs validate model support.timeout_ms: deadline for each judge attempt, in milliseconds. The default is120000. Judges run at the model’s output limit, so a slow reasoning model can need more; raisetimeout_msfor it.
JSON schema
Validates that the agent response matches a JSON schema. Returns true or false.
Regex
Checks the agent response against one or more RE2 regular expressions. Enter one pattern per line; any match counts. Patterns support RE2 inline flags such as (?i). Turn on Reject matches (reject: true) to invert the check, so content passes only when no pattern matches. Editing a regex evaluator or publishing a new version keeps its patterns, its Reject matches setting, and its generation field.
Heuristic
Applies a rule tree with AND/OR logic. Supported checks: not_empty, contains, not_contains, min_length, max_length.
Evaluator descriptions
When you create an evaluator in the Agent Observability UI, you don’t enter a description manually. Agent Observability generates a one-sentence description from the configuration the first time you save:
- When Grafana Assistant is available and the evaluator doesn’t have a description yet, it drafts a summary from the prompt templates, patterns, schemas, or heuristic rules and score contract.
- When a description is already stored, or Grafana Assistant is unavailable, times out after 30 seconds, or fails to generate text, Agent Observability keeps the stored description or applies a fallback sentence for that evaluator kind, for example,
Rates the evaluated content with an LLM judge.orFlags content that matches the configured pattern.
While drafting the description, the save button displays Generating description…, and controls such as Cancel and Back are temporarily disabled. Leaving the form while generation is in progress cancels the save.
The generated description appears in the evaluator library and alongside evaluation scores. When you edit an existing evaluator, saving keeps the existing description without regenerating it. When drafting an LLM judge system prompt, Grafana Assistant references the stored description. Evaluator templates continue to provide an editable description field.
Choose the content to check
JSON schema, regex, and heuristic evaluators evaluate the agent response by default. You can choose another field instead:
Under Content to check, select the Generation field for a JSON Schema or Regex evaluator. Heuristic evaluators select a field for each condition, so one check can combine multiple generation fields. In evaluator config JSON, continue to use the target field shown above.
Your application can send the system prompt in either of two ways, depending on the SDK and framework you use: in the generation’s own system prompt field, or as a message with the system role inside the chat history. The system_prompt target and the {{system_prompt}} template variable accept both. They read the system prompt field first, and the text of the system messages when that field is empty.
Use this for lightweight detection of injected content in generation input without requiring an LLM judge.
A tool’s result usually reaches the model as input to the next model call, so the tool_results target checks the generation that follows the tool call. The End of each turn trigger evaluates the final generation of a turn, whose input usually carries the turn’s tool results. The tool_results target joins results with line breaks in the order they were stored, includes results replayed from earlier in the conversation, and checks the results of every tool on the generation together. A JSON Schema check on tool_results passes only when the joined text is valid JSON, for example when the generation carries exactly one tool result.
Configure outputs and pass verdicts
Under Judge output (for LLM judges) or Output (for deterministic and human review evaluators), configure the emitted score and pass criteria:
- In Output key, enter the name of the score field, for example,
score. - Under Output type, select Number, Boolean, or String. Evaluator kinds with fixed schemas, such as JSON schema or regex, set this to Boolean.
- For numeric outputs, enter Min score and Max score (defaults to 1 and 10 for new evaluators). Changing the score bounds clamps the pass threshold to stay within the range.
- For LLM judges using a decision model, choose an Answer card instead. Each card is a question type with ready-made answers:
- Yes / No passes when yes has a probability of 50% or more.
- Choice (the default) offers fail, partial, and pass. The result is the option with the highest probability. The output passes when pass has a probability of 50% or more.
- Score rates from 1 to 5, with a description for each level. The result is the probability-weighted average level, so it can fall between levels. The output passes at an average of 4 or more.
- Under Advanced, change the output key, edit the options or levels, or change the pass rule. A Choice takes 2–255 options, each with an optional description of when the model should pick it. When several options pass, the output passes when they together have a probability of 50% or more. A Score takes 2–10 levels, lowest first.
- For other evaluators that already have a stored output description, the Output description field remains visible and editable.
- For string outputs, enter a comma-separated list of accepted values in Allowed values. Keep this list short, because each value becomes a metric label in Results.
- In the Passing result panel, toggle Mark output as pass or fail on or off:
- When disabled, Agent Observability records outputs neutrally without a pass or fail verdict, and omits the pass rule (
pass_threshold,pass_match, orpass_value) from the evaluator configuration. Forking an evaluator or template that has neutral outputs preserves pass/fail marking as off. - When enabled, configure the pass rule for your output type:
- Numeric outputs: enter a threshold in Pass at or above (defaults to 7 for new evaluators) or drag the synchronized score slider between the minimum and maximum scores. Scores at or above the threshold pass. Existing numeric outputs without score bounds keep their cutoff without the slider.
- String outputs: click allowed values under Choose which values pass to toggle passing status. Selected values display a checkmark. If you update the Allowed values list, Agent Observability automatically removes any passing selections that are no longer allowed. Existing passing values remain visible and removable when the evaluator has no allowed-values list.
- Boolean outputs: select true or false under Choose which result passes to select the passing outcome. Each choice displays whether the value counts as Pass or Fail.
Choose the transcript to share with a judge
Under LLM Judge configuration, the prompt field appears first. Directly below the prompt, Conversation transcript shared with LLM judge on the left and the LLM Model selector on the right share a single row. On screens narrower than 720 px, the two controls stack vertically.
For an End of each turn or Whole conversation rule, the transcript picker offers three choices:
- Compact: the transcript for this trigger with tool calls, but without tool result payloads. Faster and cheaper.
- Detailed: the full transcript for this trigger, including each tool call’s arguments and each tool result. Best for judging quality.
- Custom: write the prompt yourself with template variables. Refer to Use template variables. When selected, the custom prompt editor opens directly below the transcript and model row.
A new judge starts on Compact. A decision model judge starts on Detailed, because it judges long agent sessions much more accurately with tool results included. Compact and Detailed follow the rule they run under, so the same evaluator reads one user turn under an End of each turn rule and the whole conversation under a Whole conversation rule.
An evaluator you created before these choices existed opens on Custom with its prompt unchanged, and a judge with no prompt keeps using the default. Per generation triggers don’t offer the choices and keep the prompt editor.
An evaluator’s own create and edit pages have no rule. There, Preview as chooses which trigger the transcript choices and the playground assume: Every agent generation, End of each turn, or Whole conversation. The edit page starts on the trigger that every rule using the evaluator shares. Otherwise it starts on the scope that the prompt’s variables name, or on End of each turn. The choice isn’t saved, and each rule still runs the evaluator with its own trigger.
LLM judge prompts support three explicit variable scopes. The prompt editor puts the scope that matches the rule trigger first:
{{conversation.transcript_detailed}} is the conversation transcript with each tool call’s arguments and each tool result, so a judge can check the agent’s claims against what its tools returned. {{turn.transcript_detailed}} gives the same detail for only the selected turn, without replayed earlier turns or the tool results those turns produced. Results correlate by tool-call ID, falling back to the tool name for providers that omit call IDs. Tool output captured as text on tool-role messages is preserved. Reasoning and media are replaced by omission markers. Explicit turn.* variables stay scoped to turn evaluations and resolve empty for a Whole conversation rule.
{{turn.transcript}}, {{turn.transcript_detailed}}, {{conversation.transcript}}, and {{conversation.transcript_detailed}} hold up to 32,000 bytes. A longer transcript is shortened from the middle of long messages, the agent’s earlier messages first. If that is not enough, whole messages are left out, user messages last and spread across the conversation, so the turns that remain still cover all of it. The latest exchange is always kept, and each cut is marked.
If a provider bundles tool results into messages with the user role, Agent Observability treats those messages as tool evidence rather than new requests. Both {{turn.transcript}} and {{turn.transcript_detailed}} retain the user’s original question, deduplicate replayed tool results, and exclude input from prior turns.
Note
If your provider bundles tool results into
user-role messages, this update changes the rendered{{turn.transcript}}prompt and the text thatlatest_user_messageresolves to in judges, regex, and heuristic rules. Evaluators that previously matched bundled instructions now match the user’s question, so historical scores aren’t directly comparable with scores after this change.
Use {{turn.tool_calls}} instead of {{generation.tool_calls}} when evaluating a final response: the final generation usually contains the response, while the tool calls occurred in earlier generations in that turn.
For End of each turn judges that use turn or conversation variables, capture related generations with the same conversation ID. If Agent Observability can’t load the required context or find the selected generation in that conversation, the evaluation reports an error instead of scoring only the final generation. The playground follows the same rule. Check that the conversation contains the expected generations before running the evaluator again.
Existing unscoped variables such as {{agent_response}} and {{tool_calls}}, underscore turn variables such as {{turn_tool_calls}}, and assistant_* aliases remain supported. Prefer scoped variables in new prompts because their meaning doesn’t change with the trigger.
Configure evaluation traffic
An evaluation connects one or more evaluators to generation or conversation traffic. Under When to evaluate, configure:
- Trigger: when evaluation runs. Each choice draws an example conversation of
three turns and marks the points it scores:
- End of each turn (
user_visible_turn): runs after each turn, on the answer the user sees. Useturn.*variables to include the turn’s intermediate tool steps. - Whole conversation (
conversation): runs once per conversation, after it stays idle. Set the idle window from the card’s subtitle, from 5 minutes to 24 hours. - Under Advanced triggers, because they run several times within one turn:
- Every agent generation (
all_assistant_generations): runs after every model call, including the steps inside a turn. - When a tool is called (
tool_call_steps): runs when a model call asks to use tools, before they run. - When a generation fails (
errored_generations): runs when a model call ends with an error.
- Matching conditions: which traffic to evaluate. New rules start with no conditions and display Matches all agent traffic to evaluate all traffic for the selected trigger. Click Add filter to narrow the scope by agent name, agent version, operation, model, provider, mode, tags, errors, or
conversation.tool_usedfor targeting conversations where a tool was called. Multiple conditions use AND logic, while multiple values within a condition use OR logic. Removing all conditions restores the Matches all agent traffic default. In the rules table, rules without conditions display All agent traffic in the Match column. For the tool filter, Any matches when one pattern hits a tool used in the conversation, and All matches when every pattern does. - Sampling rate: percentage of matching traffic to evaluate (0–100%) in % of matching traffic. For example, a 10% rate evaluates approximately one in ten matching items. Lower values reduce cost and latency.
- Evaluators: the evaluators to run.
The legacy turn selector remains accepted for existing API clients and stored rules, but it is not a separate authoring choice because it fires at the same event as user_visible_turn.
Create an evaluation
For the setup flow, refer to Create an evaluation. You can build an evaluation manually or use Grafana Assistant. To review existing evaluators first, open Evaluations, click More, and select View evaluators.
When you edit an evaluator attached to an evaluation rule in the builder:
- The editor pane matches the evaluator creation form’s grouped section layout, displaying the LLM Judge configuration and Judge output sections.
- The read-only Basics section (Evaluator ID and kind) is hidden because the card header already displays both.
Expose tags on evaluation results
Under When to evaluate, use Tags to expose for filtering to select up to 10 generation tag keys. These tags let you filter or break down evaluation score metrics; they don’t change which traffic matches the evaluation.
Each key appears in Prometheus with the agento11y_eval_tag_ prefix, for example, team becomes agento11y_eval_tag_team. Keep the number of distinct values small to limit metric series. For conversation-scope rules, Agent Observability uses the value from the last generation in the conversation that matches the rule.
Use score conditions to trigger actions
An evaluation action adds matching conversations to a saved collection. Use it to send failures, examples that need review, or scores that meet a threshold to a review queue.
Choose one of these triggers when you add an action:
- When passes: runs when every evaluator produces a passing verdict.
- When fails: runs when every evaluator produces a failing verdict.
- When output value: runs when one evaluator output matches a value that you choose.
For an output-value trigger, select the evaluator and output key, then choose a comparison and value. Numeric outputs support equality and greater-than or less-than comparisons. String outputs support equality and contains. Boolean outputs support equality. Use this trigger for a specific score, such as adding conversations whose toxicity score is greater than a threshold, even when the evaluator does not produce a pass/fail verdict.
Preview an evaluation before you save it
When you create or configure an evaluation, the rule builder shows a Playground beside the form so you can check your rule before you save it. The playground has two tabs.
What gets evaluated
This tab is a volume simulation: it applies your current criteria and sample rate to recent traffic (for example, the last 6 hours). It is not a forecast of future volume. On high-volume windows, the preview is based on a sample of that traffic. In that case, projected generation volume is labelled as an estimate, and actual volume may differ if the traffic mix changed. Whole-conversation estimates can differ from actual volume. Check actual volume and cost regularly after you enable the rule. Expand Sample conversations to see matching traffic grouped into conversations, then open a conversation to see each generation and whether it would have been evaluated, matched but sampled out, or did not match. Select an agent, model, or tag on a generation to add it to your match criteria. When the rule includes LLM judges, the playground also shows an approximate projected cost per day based on sample-rendered judge prompts, model pricing, and projected evaluation volume; real spend varies with transcript length and judge completions.
When the selector is conversation, the playground shows conversation-level simulation only: each card reports whether the conversation would be evaluated (one evaluation per matching conversation after the idle window) or was sampled out, and links out to the full conversation instead of a per-generation drill-down. For a capped scan, the playground estimates hourly and daily conversation volume. It compares the number of conversations in the scanned generations with the number of conversations in the whole window. The estimate can be low, because the scan sees only the newest turns of its oldest conversations. It can also read high on workspaces that run many evaluations, because the comparison counts Grafana’s own evaluation calls as conversations.
Use this tab to tune your selector, match filters, and sampling rate without waiting for scores to arrive asynchronously.
How it’s evaluated
This tab shows what the LLM judge receives for a selected generation — or a selected conversation when the rule selector is conversation. Choose which attached evaluator to test, pick a Source (Matched traffic from the volume preview by default, or Saved conversations), then pick a generation or conversation. Inspect the rendered judge prompt with template variables filled in and highlighted. You can test different judge models using the LLM Model field before running the evaluation. Run evaluator evaluates the selection with that evaluator’s work-in-progress config so you can check pass/fail and rationale before saving. If the test indicates that the judge model ran out of tokens before finishing its response, shorten the prompt or ask the judge for a more compact answer.
The generation picker lists only generations eligible for your trigger, in chronological order. For example, When a tool is called lists generations with tool calls, and When a generation fails lists generations with errors. This applies to both matched traffic and saved conversations.
Click Open conversation to inspect the selected target’s full conversation in a new tab. Your unsaved evaluator changes stay in the builder.
Gate LLM judges with deterministic evaluators
When a rule contains more than one evaluator, choose Sequential gate to run them in the displayed order. Each evaluator must pass before the next evaluator runs. Use a deterministic evaluator first to filter out generations that don’t need an LLM judge.
Configure a pass condition for every output of each non-final evaluator. If a gate doesn’t pass, later evaluators don’t run. If a gate has an execution error, the evaluation retries according to its normal retry policy.
Choose Parallel when you want every evaluator to score the same matching traffic independently.
Gate evaluator scores control whether later evaluators run, but quality pass-rate reporting separates gate outcomes from the final quality evaluator outcomes.
Evaluate complete user turns
Turn-scope evaluators run when the agent produces its final user-visible response. They include the generations after the previous user-visible response through the final response, so a judge can evaluate a multi-step tool loop without including earlier user requests or waiting for the conversation to become idle.
Select the End of each turn trigger and use {{turn.transcript}}, {{turn.transcript_detailed}}, {{turn.agent_sequence}}, {{turn.tool_calls}}, or {{turn.tool_results}} in an LLM judge prompt:
- Use
{{turn.transcript}}for a compact transcript that records tool calls without call arguments or result payloads. - Use
{{turn.transcript_detailed}}when the judge needs each tool call’s arguments and result body to verify the agent’s claims against tool data for that turn.
In the prompt editor, click Insert {{turn.transcript_detailed}} in the variable picker or type {{turn. to choose it from autocomplete.
For example, to evaluate whether an agent’s response accurately reflects the tool data it retrieved in that turn:
Rate whether the agent response accurately reflects the tool execution results.
<evaluated_turn>
</evaluated_turn>
Criteria:
1. Did the agent execute the tool with appropriate arguments?
2. Does the agent response accurately summarize the tool result without hallucinating details?
Rate accuracy on a scale of 1-5.Use generation.* when you intentionally need only the final model call, or conversation.* when earlier turns also matter.
Existing prompts that use turn_* or unscoped variables continue to work. Prefer explicit dotted scopes for new prompts; they make the input boundary visible and let the editor warn about likely mistakes.
Evaluate conversations
Conversation-scope evaluators score a full conversation after it has been idle for a configured window. Use them when the quality signal depends on the complete interaction instead of a single generation, for example, whether the agent resolved the user’s request or followed a multi-turn policy.
Select the Whole conversation trigger and set the idle window from its card, where it reads “After 30 min of no activity”. In API configuration, use the conversation selector and min_idle_seconds. Agent Observability waits until no new generations arrive for that conversation during the window, then runs the evaluator with the full conversation transcript.
Use the {{conversation.transcript}} or {{conversation.transcript_detailed}} template variable in LLM judge prompts to evaluate the complete interaction.
Existing conversation-scope LLM judge prompts can also use {{conversation_transcript}} to include the full interaction. Generation-specific variables, such as {{agent_response}}, aren’t populated for conversation-scope evaluations.
The compact transcript removes conversation history replayed in later model inputs, so the judge doesn’t receive the same history for every call. It keeps genuinely repeated requests and new responses. This doesn’t change your stored generations.
