This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/troubleshoot-discarded-raw-samples.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/troubleshoot-discarded-raw-samples/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Troubleshoot discarded raw samples
Adaptive Metrics enforces constraints on the timestamps of incoming raw samples that are destined for aggregation. Specifically, all samples must arrive in Grafana Cloud no later than the aggregation delay to be processed successfully. Each aggregated series tracks the aggregation delay separately according to the latest sample. This means that an overall lag in sample ingestion is tolerable, as long as it affects all ingested samples equally. However, a large clock skew between incoming samples can cause some samples that are either too new or too old to be rejected.
Understand the types of discarded samples
In your Grafana Cloud stack, in the GrafanaCloud folder, go to the dashboard called Usage Insights - 5 - Metrics Ingestion.
The Discarded Samples / second panel shows the reasons that samples are discarded. For example:
sample-too-new-for-aggregation- this refers to samples that arrive too far into the future. Specifically, if the sample timestamp is more than one minute into the future, according to the current wall clock time in distributors.aggregator-sample-too-old- this refers to samples that arrive too late to be aggregated. Specifically, this happens if the sample timestamp is older than the aggregation delay of the most recently received sample for the corresponding aggregated series.
Debug the aggregator-sample-too-old error
Typically, the aggregator-sample-too-old error is caused by one or more hosts that are lagging behind in ingesting samples in Grafana Cloud.
The Ingestion Error Details panel shows a sample of recent errors, including the raw series label and timestamp that you can use to identify the source of the lagging data.
Debug the sample-too-new-for-aggregation error
Typically, the sample-too-new-for-aggregation error is caused by one or more hosts with system clocks in the future.
Grafana Labs recommends configuring NTP to keep each host’s clock synchronized.
In your Grafana Cloud stack, in the GrafanaCloud folder, go to the dashboard titled Usage Insights - 5 - Metrics Ingestion.
The Ingestion Error Details panel shows a sample of recent errors, including the raw series label and timestamp that you can use to identify the source of the future data.
Was this page helpful?
