title: "Use gcx to manage Adaptive Metrics resources | Grafana Cloud documentation"
description: "Use the gcx CLI to list, inspect, create, update, and delete Adaptive Metrics segments, aggregation rules, recommendations, and exemptions."
# Use `gcx` to manage Adaptive Metrics resources
[`gcx`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/) is a command-line interface (CLI) that you and coding agents can use to manage Grafana resources. Use [`gcx metrics adaptive`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive) to list, inspect, create, update, and delete Adaptive Metrics segments, aggregation rules, recommendations, and exemptions from the command line.
To manage Adaptive Metrics resources using the HTTP API or Terraform instead, refer to [Adaptive Metrics HTTP API](https://grafana.com/docs/grafana-cloud/cost-management-and-billing/adaptive-telemetry/adaptive-metrics/manage-as-code/adaptive-metrics-api/) or [Adaptive Metrics Terraform provider](https://grafana.com/docs/grafana-cloud/cost-management-and-billing/adaptive-telemetry/adaptive-metrics/manage-as-code/adaptive-metrics-terraform-provider/).
> Note
> `gcx metrics adaptive` manages Adaptive Metrics only. To manage Adaptive Logs, Adaptive Traces, or Adaptive Profiles from `gcx`, use `gcx logs adaptive`, `gcx traces adaptive`, or `gcx profiles adaptive` instead. The declarative `gcx resources pull`/`push` workflow supports Adaptive Metrics rules, segments, and exemptions, but the rule and exemption resource adapters only manage the default segment. Use the commands on this page to manage rules and exemptions in non-default segments.
## Before you begin
1. [Install `gcx`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/installation/).
2. [Authenticate `gcx`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/authentication/) with the preferred method for your Grafana Cloud stack.
3. To check which configuration `gcx` uses, run:
   Bash ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```bash
   gcx config view
Most `gcx metrics adaptive` commands take an optional `--segment <ID>` flag. If you omit it, the command operates on the default segment. To find a segment’s ID, use [`gcx metrics adaptive segments list`](https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/manage-as-code/use-gcx-to-manage-adaptive-metrics-resources/#manage-segments-with-gcx-metrics-adaptive-segments).
## Review and apply recommendations with `gcx metrics adaptive recommendations`
Use [`gcx metrics adaptive recommendations`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-recommendations) to list, preview, and apply recommendations. Coding agents can also use these commands to check which metrics have pending recommendations and estimate the series impact of applying them.
- [**List**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-recommendations-list) recommendations for the default segment:
  ```bash
  gcx metrics adaptive recommendations list
  Filter by action, sort, and limit the results:
  ```bash
  gcx metrics adaptive recommendations list --action add --action update --sort savings --top 10
- [**Diff**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-recommendations-diff) shows what applying one or more recommendations would change, without applying them:
  ```bash
  gcx metrics adaptive recommendations diff http_server_requests_seconds_sum
- [**Apply**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-recommendations-apply) one or more recommendations as rules:
  ```bash
  gcx metrics adaptive recommendations apply http_server_requests_seconds_sum
  Preview the effect first with `--dry-run`, or apply every pending recommendation in the segment with `--all`:
  ```bash
  gcx metrics adaptive recommendations apply --all --dry-run
  `gcx` asks for confirmation before it applies recommendations. To skip the prompt, add `--force`.
## Manage aggregation rules with `gcx metrics adaptive rules`
Use [`gcx metrics adaptive rules`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules) to create, inspect, update, and delete aggregation and drop rules:
- [**Create**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules-create) an aggregation rule that keeps only the `instance` and `pod` labels:
  ```bash
  gcx metrics adaptive rules create --metric http_server_requests_seconds_sum --keep-labels instance,pod --aggregations sum:counter
  To create a drop rule instead, which discards the metric entirely, use `--drop` on its own. It can’t be combined with `--keep-labels`, `--drop-labels`, `--aggregations`, `--aggregation-interval`, or `--aggregation-delay`:
  ```bash
  gcx metrics adaptive rules create --metric http_server_requests_seconds_sum --drop
- [**Get**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules-get) a rule by its metric name:
  ```bash
  gcx metrics adaptive rules get http_server_requests_seconds_sum
- [**List rules in a segment**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules-list):
  ```bash
  gcx metrics adaptive rules list
  This returns up to 50 rules by default and prints a truncation hint if there are more. Add `--limit 0` to return all of them.
- [**Update**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules-update) a rule’s aggregation functions or label policy:
  ```bash
  gcx metrics adaptive rules update http_server_requests_seconds_sum --aggregations sum:counter,count
- [**Delete**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-rules-delete) a rule by its metric name:
  ```bash
  gcx metrics adaptive rules delete http_server_requests_seconds_sum
  `gcx` asks for confirmation before it deletes the rule. To skip the prompt, add `--force`.
## Manage exemptions with `gcx metrics adaptive exemptions`
Use [`gcx metrics adaptive exemptions`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions) to create, inspect, update, and delete recommendation exemptions:
- [**Create**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions-create) an exemption that prevents recommendations from aggregating away the `instance` and `pod` labels on a metric:
  ```bash
  gcx metrics adaptive exemptions create --metric http_server_requests_seconds_sum --keep-labels instance,pod --reason "Preserve granularity for SLO dashboards"
  Use `--match-type prefix` or `--match-type suffix` to exempt metrics by name pattern instead of an exact match.
  Exemptions expire after 30 days by default. Use `--active-interval` to set a different duration (for example, `1h` or `90d`).
  To stop new recommendations for the matched metrics entirely, instead of keeping specific labels, replace `--keep-labels` with `--disable-recommendations`. The two flags are mutually exclusive:
  ```bash
  gcx metrics adaptive exemptions create --metric http_server_requests_seconds_sum --disable-recommendations --reason "Noisy metric, no longer needed"
- [**Get**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions-get) an exemption by its ID:
  ```bash
  gcx metrics adaptive exemptions get <ID>
- [**List**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions-list) exemptions in a segment, or across all segments:
  ```bash
  gcx metrics adaptive exemptions list --all-segments
- [**Update**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions-update) an exemption by its ID:
  ```bash
  gcx metrics adaptive exemptions update <ID> --reason "Updated justification"
- [**Delete**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-exemptions-delete) an exemption by its ID:
  ```bash
  gcx metrics adaptive exemptions delete <ID>
  `gcx` asks for confirmation before it deletes the exemption. To skip the prompt, add `--force`.
## Manage segments with `gcx metrics adaptive segments`
Use [`gcx metrics adaptive segments`](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments) to create, inspect, update, and delete segments. For more information about how segments work, refer to [Configure segmentation](https://grafana.com/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/additional-configuration/adaptive-metrics-rule-segmentation/).
- [**Create**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments-create) a segment for a team’s metrics:
  ```bash
  gcx metrics adaptive segments create --name billing --selector '{team="billing"}'
  Add `--auto-apply` to automatically apply recommendations for the segment, or `--fallback-to-default` to apply the default segment’s rules to metrics in this segment that don’t match any segment-specific rule.
- [**Get**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments-get) a segment by its ID:
  ```bash
  gcx metrics adaptive segments get <ID>
- [**List**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments-list) all segments:
  ```bash
- [**Update**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments-update) a segment’s name, selector, or auto-apply and fallback settings:
  ```bash
  gcx metrics adaptive segments update <ID> --auto-apply
- [**Delete**](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/#gcx-metrics-adaptive-segments-delete) a segment by its ID:
  ```bash
  gcx metrics adaptive segments delete <ID>
  `gcx` asks for confirmation before it deletes the segment. To skip the prompt, add `--force`.
