This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/manage-as-code/adaptive-metrics-terraform-provider.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/manage-as-code/adaptive-metrics-terraform-provider/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Adaptive Metrics Terraform provider
Use the Adaptive Metrics Terraform provider to configure aggregation rules, recommendations, and exemptions.
Prerequisites
Before you begin, you should have the following available:
- A Grafana Cloud account, as shown in Get started
- Terraform installed on your machine
Note
All of the following Terraform configuration files should be saved in the same directory.
Configure the Terraform provider
Create a file named
main.tfand add the following:terraformterraform { required_providers { grafana-adaptive-metrics = { source = "registry.terraform.io/grafana/grafana-adaptive-metrics" } } } provider "grafana-adaptive-metrics" { url = "<your-grafana-cloud-prom-url>" api_key = "<your-numeric-instance-id>:<your-cloud-access-policy-token>" }Replace the following field values:
<your-grafana-cloud-prom-url>with the URL of your hosted Prometheus endpoint in the formhttps://<something>.grafana.net. To find this URL, go to yourgrafana.comaccount and check the Details page of your hosted Prometheus endpoint.<your-numeric-instance-id>with the numeric instance ID where you want to use Adaptive Metrics. To find this value, go to your grafana.com account and check the Details page of your hosted Prometheus endpoint for Username / Instance ID.
<your-cloud-access-policy-token>with a token from a Grafana Cloud Access Policy. Make sure the access policy hasmetrics:readandmetrics:writescopes for the stack ID where you want to use Adaptive Metrics.
Add aggregation rules
This example Terraform configuration creates aggregation rules for test_metric_1 and test_metric_2 using grafana-adaptive-metrics_rule (Resource).
Create a file named aggregation-rules.tf and add the following:
resource "grafana-adaptive-metrics_rule" "test_metric_1" {
metric = "test_metric_1"
drop_labels = ["pod", "instance"]
aggregations = ["sum:counter"]
resource "grafana-adaptive-metrics_rule" "test_metric_2" {
metric = "test_metric_2"
drop_labels = ["pod"]
aggregations = ["sum:counter", "sum", "count"]
}Add recommendations exemptions
This example Terraform configuration creates an exemption for test_metric_1 using grafana-adaptive-metrics_exemption (Resource).
Create a file named aggregation-exemptions.tf and add the following:
resource "grafana-adaptive-metrics_exemption" "ex1" {
keep_labels = ["namespace"]
}You can also use the match_type attribute to exempt metrics by prefix or suffix. If not specified, the default is exact.
resource "grafana-adaptive-metrics_exemption" "ex2" {
metric = "http_requests_"
match_type = "prefix"
}Configure recommendations service
This example Terraform configuration brings the recommendations configuration singleton resource under Terraform management using grafana-adaptive-metrics_recommendations_config (Resource).
Create a file named aggregation-recommendations-config.tf and add the following:
resource "grafana-adaptive-metrics_recommendations_config" "singleton" {
}Note
The recommendations configuration is a singleton resource that always exists for every tenant. Creating it in Terraform adds it to Terraform state but the underlying resource already exists. Deleting it removes it from Terraform state but leaves the underlying resource.
Apply the Terraform configuration
In a terminal, run the following commands from the directory where all of the configuration files are located.
Initialize a working directory containing Terraform configuration files.
shellterraform initPreview the changes.
shellterraform planApply the configuration files.
shellterraform apply
Was this page helpful?
