title: "Configure recommendation generation in Adaptive Metrics | Grafana Cloud documentation"
description: "Customize how Grafana Adaptive Metrics generates recommendations using recommendation configurations."
# Configure recommendation generation in Adaptive Metrics
Grafana Adaptive Metrics decides how to generate aggregation recommendations on your behalf. By default, it treats every dashboard, every alerting and recording rule, and every query executed in the last 30 days as a signal that a metric is in use. These defaults work well for most organizations, but your priorities might differ.
Recommendation configurations let you define those priorities yourself. A recommendation configuration is a named set of options that controls how Adaptive Metrics generates recommendations for your metrics.
## Before you begin
To modify the usage sources, you need a role that includes the `grafana-adaptive-metrics-app.segments:write` action, such as **Admin** or **Segments Editor**. Without this permission, the **Dashboards** and **Queries** sources are read-only. For more information, refer to [Configure RBAC for Adaptive Metrics](/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/additional-configuration/adaptive-metrics-rbac/).
## Metrics usage sources
Metrics usage sources control which kinds of usage the recommendations service counts when it decides whether a metric, or one of its labels, is in use.
The recommendations service collects usage information from three sources. Each source captures a different kind of usage:
- **Dashboards**: A metric counts as used if it appears in the definition of any saved dashboard in your Grafana Cloud stack. The recommendations service scans every panel query, template variable, and annotation query in your saved dashboards. Because this scan reads the saved dashboard definitions, not dashboard views, a metric counts as used even if no one ever opens the dashboard.
- **Alerting &amp; recording rules**: A metric counts as used if it appears in the definition of any alerting or recording rule. This source is always enabled.
- **Queries**: A metric counts as used if it appears in your query history from the last 30 days. Query history contains every query that was actually executed, regardless of where it came from: queries that run when someone opens a dashboard, one-off queries in Explore, queries sent directly to the Prometheus HTTP API, and queries executed by any other tool or script.
The **Dashboards** and **Queries** sources overlap. When someone views a dashboard, Grafana executes the panel queries, and those executed queries also become part of your query history. As a result:
- A dashboard that nobody views is only counted by the **Dashboards** source.
- A dashboard that people view is counted by both sources: by **Dashboards** because of its saved definition, and by **Queries** because of the executed panel queries.
For more information about how the recommendations service analyzes usage, refer to [Understand recommended rules](/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/manage-recommendations/understand-recommended-rules/).
### How excluding a source changes recommendations
Excluding a usage source tells the recommendations service to ignore that kind of usage. Metrics whose only usage comes from excluded sources are treated as unused, so Adaptive Metrics can recommend aggregating them more aggressively.
- Exclude **Dashboards** to stop unused dashboards from holding back recommendations. Metrics that appear only in saved dashboard definitions no longer count as used. Dashboards that your team actively views remain protected through the **Queries** source, because viewing a dashboard executes its queries.
- Exclude **Queries** to stop one-off queries from holding back recommendations. A metric that someone queried once in Explore no longer counts as used. Metrics referenced in dashboards and rules remain protected.
> Note
> The recommendation configuration must always include the **Alerting &amp; recording rules** source. Aggregating or dropping a metric that’s referenced in an alerting or recording rule would silently break the rule, potentially causing missed alerts.
## Manage the recommendation configuration using the UI
Manage the recommendation configuration in the **Metrics usage sources** section of the **Configuration** tab. This configuration is the global default and applies across all segments.
1. Navigate to **Adaptive Metrics** &gt; **Configuration**.
2. In the **Metrics usage sources** section, select or clear the following sources:
   - **Dashboards**: Count metrics referenced in saved dashboard definitions as actively used, even if no one opens the dashboard.
   - **Queries**: Count metrics from every executed query as actively used, including queries that run when someone opens a dashboard, queries in Explore, and queries sent through the API.
   The **Alerting &amp; recording rules** source is always enabled and can’t be cleared.
3. Click **Save**.
Changes affect all metric rules across all segments the next time recommendations are generated. Expect differences in projected savings and in the number of generated recommendations.
## Next steps
- [Understand recommended rules](/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/manage-recommendations/understand-recommended-rules/)
- [Configure segmentation](/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/additional-configuration/adaptive-metrics-rule-segmentation/)
- [Configure auto-apply](/docs/grafana-cloud/adaptive-telemetry/adaptive-metrics/additional-configuration/auto-apply/)
