This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/additional-configuration/adaptive-metrics-rbac.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/additional-configuration/adaptive-metrics-rbac/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Manage access to Grafana Adaptive Metrics using role-based access control
Use role-based access control (RBAC) to manage permissions for users in Adaptive Metrics.
The following table shows the role names, descriptions, and associated actions that you can assign to users.
| Role | Description | Associated actions |
| Admin | Overall read and write access in Adaptive Metrics |
| Config Editor | Edit access to Adaptive Metrics plugin configuration |
| Config Reader | Read access to Adaptive Metrics plugin configuration |
| Exemptions Editor | Edit access to recommendation exemptions |
| Exemptions Reader | Read access to recommendation exemptions |
| Plugin Access | Access to the Adaptive Metrics plugin |
| Rules Editor | Read and write access to recommendations and rules |
| Rules Reader | Read access to recommendations and rules |
| Segments Editor | Read and write access to segments |
| Segments Reader | Read access to segments |
Note
You can assign users to multiple roles.
For a description of supported role-based actions in Adaptive Metrics, refer to Grafana Adaptive Metrics action definitions.
Assign users to a role
You can assign users to a role in the Grafana Cloud UI or using the HTTP API.
Refer to Assign fixed roles in the UI using the role picker and RBAC API for more information.
Was this page helpful?
